Question about Dryers
Dryer quit working. Completely dead
Outlet putting out 110 on both sides, 220 together. THere is no response from the dryer at all. It just quit.
  • 1 more comment
  • Tim Weaver
    Tim Weaver May 30, 2009
    THe white piece I pulled out had two wires going to it, an inch long, and is blackened on the backside of it. Would this be considered the fuse?
  • Tim Weaver
    The piece that the door depresses to start the dryer was broken off. The door was closed so I ASSumed that wasn't the problem. Dryer works great. Thanks for your guys' comments and suggestions. Thank you very much!
  • Samuel Charles Spriggs May 11, 2010
    If you turn the timer (if it has a mechanical timer), can you hear the clock motor turning?
    Does the cord have any scorch marks on the plug or the prongs?
    President:
  • 1,136 Answers
Hi, If this is a whirlpool model dryer, try this: Normal 0 UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it. If this is another brand dryer, please let me know the model # so I can assist yyou further.
Thanks
Vic
Posted on May 30, 2009
  • Victor
    Victor May 30, 2009
    yes that is the fuse. It should have continuity (closed).
  • Victor
    Victor May 30, 2009
    You are welcome.
    Brigadier General:
  • 8,619 Answers
Hi!
If your dryer doesn't work at all, it could be because of problems with:
Power from the house: Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch: If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse: On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring: Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
How to get 220 from breaker box
You are measuring in the wrong place! If you have a double breaker in the circuit breaker box, measure the voltage at the dryer outlet. You should have 110, 110, 220 at the different terminals.
If that isn't the case, then replace the circuit breaker (assuming that you have the right input voltage into the house)
Jan 01, 2012 | Dryers
My 70 series dryer the heating element is not working. I checked the heating coil for continuity and it is holding 12 ohms, the fuse has continuity and it has power. Flipped the breaker to se If that was...
your voltage is not right as it should be 220 volts, check the outlet to see if you have 220 if you do then its the cord, if not then it is either the outlet or the breaker-panel, to check panel remove panel and test both legs of the breaker you should have 220 if not then replace the 30 amp breaker. Tim
http://www.ehow.com/how_7403710_replace-kenmore-70-series-dryer.html
May 27, 2011 | Kenmore Dryers
We had an older dryer, and it got to the point that it would run a couple minutes, then quit. We bought a brand new Kenmore Elite dryer... model 110.64994300... and it does the same thing. We thought it...
if you have a volt meter u can check power coming in should b 220 volt put one meter leave on black wire an the other on red wire meter should read 220 volt an if u go front black to white it should read 110 votl u could have a bad outlet dose outlet look like it been burn if best if you dont know how read meter to just call your appliance repair service ok be safe an turn power off to dry b4 you start test it out ok hope this help you out
Jun 02, 2017 | Kenmore 64992 Electric Dryer
Electrical issue...220 dryer outlet problem
ok start at the pannel is there a double breaker there
usually a 30 amp two pole breaker this is how a pannel works first breaker pulls 120 off of one side of pannel second breaker pulls off 120 off the other side of pannel if you look the buss bars you will see that they interchange from one side of the pannel to the other so at the breaker you are checking make sure you have 120 v on output of one half of breaker and 120 on second half of breaker when you use a volt meter put one side to gng the other side to wire comming out of breaker you should have 120 on both sides if not you have a bad or tripped breaker
Apr 24, 2010 | Hammering
Dryer will not start door is closed
Carefully check your 220 outlet. You can check a 220 buy a volt meter. Make sure your volt meter is set over 220 range and put the red lead into the slot and black lead into the L shape. It could be you are not getting 220 power out of your outlet. We all know on a 220 outlet both legs have 110 on each side. A dryer takes 110 for the motor, and takes 110 for elements.
Dec 03, 2009 | Estate TEDX640JQ Electric Dryer
Dryer won't start - how do I trouble-shoot to determine if its the switch or something more complicated?
First trouble shooting is to make sure you are getting 220 to the outlet not 110; We all know that on a 220 outlet there is 110 on each side and if you are not getting 110 from each side, the dryer motor won't turn on. If you are getting 220, then try manual start. Hold in on the door switch and push the start switch. If that don't work then it is the motor.
Nov 20, 2009 | Kenmore Dryers
110 volt/amp dryer
yes ,i see some on line at living direct.its an Haier,they call it a portable.it was about 300$ and that included shipping.if you can't find .i googled 110 volt dryer and their was the link too [living direct] have fun,God bless,tom
Jan 23, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Dryer 697267
Most dryers are 220 so they can produce the amount of heat required to properly dry clothes. I would Not recommend trying to convert the dryer to 110 voltage. This may cause you alot of unwanted problems. I would find a Qualified electrician to install a 220 outlet at the location of the dryer .
Apr 26, 2008 | Dryers
Dryers Logo
96 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
