Fan just trys to come on but humms
The humming may be the compressor running. The fan on top of your A/C outside tower is the condenser cooling fan. If the fan motor will start when you give the fan blades a push, then the start capacitor is bad & needs replacing. If the motor won't start when you give the blades a push, the start windings on the fan motor are burned out, and the motor needs to be replaced. Don't let your compressor run without the cooling fan, or you'll likely have to replace the compressor too.
Check for bound motor
The click, is it faint, such as a relay energizing?
It sounds like the fan motor start capacitor is bad (if it has one) -- I can't find any schematics for this unit -- do you know where to find one on-line?
