Question about Dryers
My dryer does not spin
My 60 series kenmoor dryer does not spin anymore, what do I need to do?
    President:
  • 1,136 Answers
Hi, first thing I need to know is, does the motor run but no tumbling? If the motor runs and this is the model with the lint screen on the top, follow these instructions: Normal 0 UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off.
There should be instructions that came with the belt. I will try and explain how this goes on. The idler pulley fits in a slot right in front of the motor. Put the belt over the drum with ribs touching drum. Now, thread the belt through the idler pulley wheel and bracket and set the belt on the motor pulley. The ribs should rest in the grooves on the motor pulley. Reverse the process to put the dryer together.
If this is not the model with the lint screen on top, please let me know.
I hope this helps you. If I can assist you further, please let me know. Please rate me performance so that others as well as myself will know how I am doing.
Thanks
Vic
Posted on May 30, 2009
Where's the fuse of the kenmoore dryer 80 series?
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Jan 01, 2010 | Kenmore Dryers
Kenmoore 80 series heavy duty (gas dyer) no heat.
If you still need help please post your model number. Gas/Electric?
Eric
May 25, 2009 | Kenmore 63942 Dryer
Kenmoore Dryer will not start
ok im with you,,send me the model #..and check your door switch..i want to veiw schematic on this,,,we have a defective part..
Jan 17, 2009 | Kenmore 63942 Dryer
Can't get replacement parts back on Kenmore 60 series dryer.
The belt has groves, right? Make sure the groves go over the motor pulley from the right. The idler pulley is spring loaded. Place the belt around the idling pulley with the smooth side of the belt on the pulley. This should work.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Manual for a Kenmoore 60 series soft heat large capacity dryer.
Here is the website for Kenmore driers and the manuals to download for free in Adobe format. They are only listed by model number.
http://www.kenmore.com/shc/s/search_10154_12604?vName=Kenmore&cName=Washers+%26+Dryers&keyword=kenmore+drier&sLevel=0
Dec 22, 2008 | Kenmore 63942 Dryer
Drum won't turn
sounds like a broken belt, common kenmoore belt number 341241.
Nov 03, 2008 | Dryers
Kenmoore wont spin front end loader
won't spin on the spin cycle it just has a grinding sound
Sep 10, 2008 | Kenmore Elite 45986 Front Load Washer
Dryers Logo
80 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
