Question about O2 Xda Trion Smartphone
RESET phone solution.. pls help..
  • i bought an O2 xda trion pc phone.. then i clicked the reset button then when it turned on the window said "tap the screen to set up your Windows Mobile-based device" so i tapped the screen and it went to "align screen" and it says "Tap the target firmly and accurately at each location on the screen. The target will continue to move until the screen is aligned" but I have been tapping it several times around the screen but nothing happens. what do i need to do? pls help.
  • 4 more comments
  • jeet12345 Feb 26, 2008
    Same problem am facing.....when i started phone its showing" tap the target firmly and acurately at each location on the screen. The target will continue to move untill the screen is alignen in o2 mobile"
    Can anyone suggest what should i do?
  • Anonymous Apr 20, 2008
    same problem here.. pls update..
  • Anonymous Sep 28, 2008
    pop-up menus
  • codruta_clau Nov 28, 2008
    i have the same problem
  • shrinivas123 Jan 18, 2009
  • Anonymous Feb 22, 2009
    Tap the target firmly and accurately at each location on the scren.The target willcontinue to move until thescreen is aligned X1SONY ERIKSON
  • 490 Answers
   u just do one thing..restart ur phone again..& when it asks u to set up ur windows..than tap on the black spot firmly ...u just need to tap on than spot only..nthing else after that leave..it will start processing..& ur phone will be on.
Thanks
Gizmo1
Posted on Oct 23, 2007
Woh same problem guyz ..can u help me ...the phone said ..
tap the targey firmly and accurately at each location on the screen the target will continue to move until the screen is aligned
...woh pls2x help me ..
Posted on May 15, 2011
My phone not show screen because i reset my phone how i can show my screen on my phone
Posted on Aug 14, 2012
Thank you ejbaguio. It worked. One just need to tap firmly on + mark displayed.
Posted on Dec 09, 2011
Thaks alot ..he..he..hee...
Posted on Oct 25, 2008
My screen is broken on my trion and i cannot unlock the screen is there any other method off opening the phone
Posted on Aug 18, 2008
2 Suggested Answers
SOURCE:
SOURCE: Xda mini S Pocket PC problem
your phone is being reset if the situation is like that. get your pen and push the button beside the charging socket and press the power button also simultaneously.
Posted on May 25, 2008
Hello sir how r u. i have a o2 xda orbit phone. i forget handset password. pleass help me and tell me how i can unlock my handset
Chances are Hard resetting your phone, but take note that all data will be lost.
Here is the Procedure
1. Press and hold GPS/Messaging and the Internet Explorer button,and at the same time need a stylus to press the reset button at the bottom of your phone.
2. Released the reset button but continue the two keys, until you see a message on the screen that all of your data will be deleted.
3. released the two buttons and then press SEND button on your device to perform the hard reset or you may even cancel the reset by pressing a button.
For more illustration and clear visualization, you can view this link;
http://www.hard-reset.com/o2-xda-orbit-2-hard-reset.html
good luck...
Jun 27, 2011 | O2 Xda IIs Pocket PC
How will i install my O2 stealth to my pc... i don't hav the disc for installer because it was just given to me by my friend... im running windows Xp.. please help
Free tech support for O2 Xda Stealth Smartphone and help with O2 Xda Stealth ... power device not boot soft reset o2 xda stealth hard reset o2 stealth white ... My O2stealth does not boot! All you see is the O2 welcome. ... dear friend, i just bought O2 stealth, and i want
Oct 29, 2009 | O2 Xda Stealth Smartphone
O2 Trion/HTC Hermes startup fault
i trun on my phone its stay on windows mobile sceen will not do anything els
May 29, 2009 | O2 Xda Trion Smartphone
Xda trion turns into white screen
You need to return it to an o2 store for repair. If it's not under guarantee, I'd be very wary of spending any money on it as I had exactly the same problem and my phone has been back time and again for repair and still isn't right. Could be very costly.
Apr 06, 2009 | O2 Xda Trion Smartphone
My o2 xda trion will not sync up to my pc. any ideas???
Hiya,
the software that came with the trion is out of date, it offers microsoft active sync 4.0 or 4.2.
Go to Microsoft site and get Microsoft active Sync 4.5.
It worked for me
Good Luck
barneyyeoman
Feb 23, 2009 | O2 Xda Trion Smartphone
My o2 xda atom doesn't turn on.
try to press record button+camera+soft reset....after you can choose froml there what you want to do.
Dec 17, 2008 | O2 Xda Atom
May 22, 2008 | O2 Xda II mini
My o2 celphone won't turn on
O2 XDA Atom / O2 XDA Atom Pure / HP rw6828:
To perform a hard reset, use the stylus while pressing into the reset hole, press the power on/off button at the same time. Screen will prompt you to press the Green call and Red end call button together to confirm on hard resetting the device.
*Note: Hard resetting the device will cause the device to be reset back to its original factory default settings and all data will be lost.
i hope it will help your prob.
Dec 01, 2007 | O2 XDA Mini S Smartphone
O2 Xda Trion Smartphone Logo
2,356 people viewed this question
Top O2 Computers & Internet Experts
xxxxxx xxx
Sheldon Dedek
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
