Question about Homelite Garden
Starts but when throttled continues to die
Homelite weedeater starts, but when throttled dies
  • 1,040 Answers
You have a dirty carburetor or a carburetor in need of new parts. Disassemble carburetor. Clean with carb. cleaner and use a Den Tek Brush, (used for cleaning teeth), for the small portals. Check the small screen in carb., making sure that it's free of debris. Reassemble and see if it works properly. If it doesn't, then you will need to buy a carb. kit and replace the small screen, needle valve, appropriate gaskets, and diaphragm. This should do it.
Jim
Posted on May 30, 2009
  • Jim Parker
    Jim Parker Jun 04, 2009
    Did this solution solve the problem?
    Jim
HUSQVARNA 128LD WILL START RUN FOR A FEW SECONDS AND DIE.
You need to adjust your idle screws. Start at 1 and a half turns out for High and Low then go from there.
Aug 22, 2014 | Husqvarna 128 LD Weedeater
Homelite trimlite weedeater will start and idle in full choke position only. Cannot use any throttle or it dies. Cannot switch out of full choke or it dies. Cannot use any throttle to start it as well, if...
Fuel starvation either too the carb or in the carb itself, start with a simple cheap fix, replace the fuel filter in the tank on the end of the fuel hose.
Aug 16, 2013 | Garden
Husqvarna weedeater repair
Husqvarna 128 ld weedeater only runs when spark detector is hooked up. Otherwise it dies.
May 20, 2013 | Cars & Trucks
When i try too start the weedeater it either doesn't start or it acts like it is only firing half the time. Then it dies out.
check your compression on the weedeater needs to a min of 110 psi to run properly..email me with any questions on how to check the compression..whitejeff74@yahoo.com
Jul 25, 2011 | Homelite Garden
Weedeater dies when you open choke
After you start it and are in the second stage of the choke (half choke ) let it run for awhile until it warms a bit then try openning choke and going to full throttle.
May 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Homelite whipper wont start. Replaced the primer
check your gas and oil mix remove the plug take some carb cleaner spray in plug hole pull start replace plug pull start if it fire you mix is wrong.....Good Luck
Aug 15, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Briggs & Stratton 135212/0129 - Homelite HL2500
the choke should be in the off position when running. YOU put the choke on to start it then when it starts u turn it off. If the choke is on the engine will die when reving
Aug 02, 2009 | Electrical Supplies
Stihl weedeater starts but won't run at high speed
This sounds like a timing problem.
It is too far retarded, and needs advancing a couple of thou.
There you go:)
Jul 25, 2009 | Garden
Starts then dies stihl fs45/weedeater
I sounds like it sucked up some debris in the bottom of the fuel tank and obstructed fuel flow somewhere. Start by blowing out the in-tank fuel filter (You will have to fish it out with something), then load the line with carb cleaner (wear safety glasses) put fuel filter back in line and crank it a few times to pull the carb cleaner into the carb. This may dislodge the obstruction. If this doesn't work, you will have to remove and cleant he carburator. Hope this helps.
Jul 04, 2009 | Homelite Mighty Lite Lawn Trimmer
You have carburetor problems. You will need to take the carb. off and disassemble. Clean the carb. with carb. cleaner and use a Den Tek Brush, (used for cleaning teeth), for the small portals. Check the small screen in carb. to make sure it isn't clogged. The smallest of particals can cause the carb. problems. Check the gaskets as well. Depending on how old your trimmer is, you may have to buy a carb. kit and replace the Needle valve, appropriate gaskets, diaphragm, and small screen.
Jim
May 30, 2009 | Homelite Garden
Garden Logo
463 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
