Question about IBM ThinkPad T20 2647 Notebook
IBM Thinkpad T20 - Model Type 264784U
Running smoothly w/o a problem. Moved recently and placed it on its side for about 3 weeks w/o using it, however I had it plugged in to keep it running.
Tried to take it out of the screen saver mode and the hard drive was making noise that it never made before.
Goes through the boot process - never makes it to windows - give an I/O error of   00000400.
What is my next logical step?
Don't want to spend a great deal of money on it. If it needs a new HD I will consider - what type of hard drive can it support?
In case this info is useful  System S/N 78PLL99
                                       Dyd Board S/N J1D8E022432
  • ssco1774 Oct 23, 2007
    Thanks for the info
    Yes it has a 20 gb original drive in it.
    In order to save time searching for the site you mentioned, would you mind providing?
    Also, if I have to eventually replace the drive - is it something that is intuitive?
    Will I be able to replace it myself?
    Should I assume that a 60 - 80gb drive will fit into the HD slot?
  • ssco1774 May 27, 2008
    I am ready to replace the hard drive in the ThinkPad described previously
    I will replaced it with an IDE HD
    Question: Can I then install Windows XP on this machine? And I guess I should add some RAM
Yes ssco1774 you may install up to a 120 Gig hard drive. Yes you may then install windows XP. XP will run if you have 128 meg of ram installed, but it runs better with 256 meg, or if you want to spend the money, 512 meg
Posted on May 28, 2008
I own 3 thinkpad T-20's, model 2647's. All of them originally came with 12 gb drives. In one of them I installed a 60gb Hitachi 5400 rpm drive, and in another one I just this past week installed a 120gb WD 5400 rpm drive. The 60gb drive and the 120 gb drive both detected properly and both are dual boot with windows 2000 and Mandriva Linux. Yes, you may install atleast up to a 120 gb hard drive in your T20 thinkpad with no problem. My 3rd T20 has a problem that I need help with. When I turn it on, the hard drive led flashes green then immediately goes off, as if a breaker is tripping. Since I have several of the same model laptops, I have swapped parts around with the ones that work to eliminated the battery, charger, and the on/off switch and keyboard assembly as possible causes. What else could be causing the problem ?
Posted on Dec 09, 2007
    Problem Solver:
  • 11 Answers
Hi
I wasn't aware that these thinkpads t20 can support 60gig+ hard drives. Has anyone got a thinkpad t20 out there in which they have installed a 60gig hard drive?
Thanks
dab
Posted on Nov 28, 2007
    Scholar:
  • 90 Answers
I would say the hard drive is failing. But need to run a diagnostic on it to be sure.
If you would like to know where to get the ibm / hitachi hard drive diagostic let me know. It's free for download and you can get a bootable ISO image to burn onto cd. Allowing you to boot from cd in order to test the drive.
As far as replacing, you should be good with a 60gb or 80gb. Did it orginally have a 20gb in it? I would say for most people, 60-80 is way more than enough. Unless you have a ton of music or pictures.
Posted on Oct 23, 2007
  • Chuck Gluth
    Chuck Gluth Oct 23, 2007
    The physical size is pretty standard. And yes, you should be able to easily install a new hard drive. Question is, are you wanting to attempt a recovery of your old data?? To do that you would need to send it out to someone who could do this for you. Otherwise, you could just install the new drive and reinstall your operating system or restore cd's if you have them.
    You can download the bootable cd image from http://www.hitachigst.com/hdd/support/do...
    Just need to burn it to cd, I hope you have the ability to burn an ISO image. If you use Nero, shouldn't be a problem. Just load Nero and choose the burn image option. Any other software for burning cd's should support burning this iso image. Don't just copy the ISO to the cd, it needs to be loaded as a cd image in your burning software. Then you can boot your laptop from this cd, which may require changing the boot order in the bios settings if its not allready set to boot from cd first. And the menu is simple to follow. Run the advanced test and see what it returns with.
  • Chuck Gluth
    Oh, and as far as replacing a hard drive goes.... you will need an IDE drive... don't buy a SATA drive. ;-)
    Just a few screws that holds it in.
IBM ThinkPad T20 date and time problems
Your CMOS battery is low you need to replace it ASAP
Apr 14, 2012 | IBM ThinkPad T20 Notebook
My new compatible battery 02K6626 is not charging in my T20.
You can buy a completely compatible IBM ThinkPad T20 battery. Search in Google for the model of you wanted battery,then you always can find some best online laptop battery shop which have a high fame and have running for some years ,they provide both good batteries and service.
Apr 29, 2010 | IBM ThinkPad T20 2647 Notebook
IBM T20 screen bad, IBM i1400 screen good-Compatible?
Yes, it's possible, but unless you are a qualified laptop technician, I recommend that you take both computers to a qualified technician, to get the job done properly and safely and correctly.
Dec 19, 2009 | IBM ThinkPad T20 2647 Notebook
Problem with a IBM ThinkPad T20 2647 PC Notebook
check ur hd for bad sectors...shutting down for no reason is usually this(bad sectors)
also check system information and check device manager..could be software problem/incompatabilty/no drivers installed/or two devices trying to use same resource and shutting down cos cant.
Jan 07, 2009 | IBM ThinkPad T20 2647 Notebook
I need to format the hard drive on a IBM t20
it seems that u are booting using windows and than trying to format it
u need to boot from a bootable cd and than format it
Nov 14, 2008 | IBM ThinkPad T20 2647 Notebook
IBM ThinkPad T20, Intel Pentium III 700MHz Upgrade to Pentium 4?
Max CPU for IBM T20, 21, 22 is Pentium III FCPGA2 1000MHz (1GHz). Max memory is 512MB (2 x 256MB PC100/100MHz). Max hard disc is 250GB ATA. Newest BIOS is from April 2004 at the homepage Lenovo.
Nov 06, 2008 | IBM ThinkPad T20 2647 Notebook
Graphic Card Driver for the IBM ThinkPad T20
Go to IBM web and find your Thinkpad model from Driver download option.
Oct 10, 2008 | IBM ThinkPad T20 2647 Notebook
Free ibm t21 2647-4bu restore cd download.
If your system is working and you can get the internet on it then you should be able to access all the required driver updates available via the Lenovo web site here :-
http://www-307.ibm.com/pc/support/site.wss/product.do?subcategoryind=0&familyind=50268&brandind=10&doccategoryind=0&modelind=79050&doctypeind=9&validate=true&partnumberind=0&sitestyle=lenovo&template=%2Fproductpage%2Flandingpages%2FproductPageLandingPage.vm&operatingsystemind=49979&machineind=78825
This Address is specifically for your machine type model.
Aug 21, 2008 | IBM ThinkPad T20 2647 Notebook
IBM Thinkpad T20 Type 2647
I currently own 3 Thinkpad T-20 Laptops. They all have a 700 mhz processor in them, and so will yours, more than enough to run windows xp, in fact, I am running Windows XP Profession on one of them. The PC100 is the type of memory it uses, not the processor speed. i recently installed a 120 gb drive in one of them so you will have no problem installing a 20 or 40 gb drive, or larger.
Dec 08, 2007 | IBM ThinkPad T20 2647 Notebook
IBM ThinkPad T20 2647 Notebook Logo
522 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
