Question about BenQ Joybook 3000-01 Notebook
Wi-Fi connection cannot be setup
I am not able to setup Wi-Fi connection. It does not show the wireless access points visible. How to setup the connection?
    Problem Solver:
  • 21 Answers
Have you set up a wireless network yet? like in your network connections? If not you would have to do that first. I hope this helps.
  `Nbryson
Posted on May 31, 2009
HOW TO CHANGE THE INTERNET SETTINGS IN THE HTC WILDFIRE A3333
Wi-Fi provides wireless Internet access over distances of up to 100 meters (00 feet).
To use Wi-Fi on your phone, you need access to a wireless access point or "hotspot". The availability
and range of the Wi-Fi signal depends on the number, infrastructure, and other objects
through which the signal passes.
Turning Wi-Fi on and connecting to a wireless network
From the Home screen, press MENU, and then tap Settings > Wireless & networks.
Select the Wi-Fi check box to turn Wi-Fi on. The phone then scans for available wireless
networks.
Tap Wi-Fi settings. The network names and security settings of detected Wi-Fi networks
are displayed in the Wi-Fi networks section.
If the wireless network you want to connect to is not in the list of detected networks,
scroll down the screen, and then tap Add Wi-Fi network. Enter the wireless network
settings, and then tap Save.
Tap the Wi-Fi network you want to connect to.
If you selected an open network, you will be automatically connected to the network.
If you selected a network that is secured with WEP, enter the key and then tap
Connect.
Depending on the network type and its security settings, you may also need to enter more information
or choose a security certificate.
When your phone is connected to a wireless network, the Wi-Fi icon appears in the
status bar and tells you the approximate signal strength (number of bands that light up).
The next time your phone connects to a previously accessed secured wireless network, you
will not be prompted to enter the key or other security information again, unless you reset
your phone to its factory default settings.
Jan 28, 2015 | HTC Wildfire A3333 Cell Phone
Netis Wireless-N-Broadband Router
If you have communication on one computer, it confirms you are making proper connection; thus the second computer was not setup correctly. Take out the Manual and start from scratch and do a step by step setup function. Write down your administrative password and codes. Make certain you type in the data correctly and when done see if the communication paralells that of the first computer.
Jan 28, 2014 | D-Link Dlink Airplus Xtreme Dwl-2100ap...
Error 102-2931 on wiiu
  • Power cycle your home network.
  • If your wireless router or access point is unresponsive, power cycling these devices may resolve your connection issue.
  • Ensure you are using the correct password for your Wi-Fi network.
  • If your wireless router or access point is secured with a security key or password, review this password to ensure you have entered it correctly in the Wii U.
  • Create a new connection on your Wii U.
  • Create a new connection on your Wii U. This will ensure you are connecting to the correct Wi-Fi network and the Wi-Fi network is currently visible to your Wii U.
  • Check for wireless interference.
  • Wireless interference can result in a weakened connection between your Wii U and your wireless router or access point. Review your Wi-Fi network's setup to ensure an optimal wireless environment.
    Still Not Resolved:
    • If the issue persists, please contact at 1-800-255-3700. Specially trained representatives will be available to assist you, 6:00am - 7:00pm (PST), seven days a week.
Dec 02, 2013 | Nintendo Wii U
Wi-fi connection gets disconnected frequently and reconnects by itself. Tried to reinstall the wi-fi drivers but no improvement. The same laptop is working perfectly at another wi-fi environment.Tried to...
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls, mirrors, fish tanks and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Apr 01, 2013 | Computers & Internet
I do not know the PIN to connect to Wi - Fi of my STC modem
According to connection of wi-fi and stc modem you must configure the wi-fi access point and must provide the password wi-fi access point is connecting through it.Then you will be able to connect modem to it.
Feb 07, 2012 | Zhone Technologies Inc ADSL2+ BONDED...
Kindle new do i need wifi connection
The Kindle is available in two versions
1) Enabled with Wi-Fi only version
2) Wi-Fi plus 3G version.
In the case of the 3G-enabled Kindle, you do not need to do anything to connect to the Internet. The Kindle automatically connects to Amazon's 3G Whispernet network whenever it is within the coverage area. No membership or subscription fees are required in this particular version.
For a Wi-Fi only Kindle, you must select and connect to a public or private wireless network to access the Internet. You'll need to use your home Wi-Fi network or another access point to complete the initial setup and buy books and selling on amazon.
But The Kindle DX is only capable of with the use of a 3G connection.
Dec 27, 2011 | Amazon Stores
How do you get wi-fi
http://ds.about.com/od/nintendods101/ht/settingupdsiwifi.htm
If you go to this website above it shows you step by step what to do.
Turn on the Nintendo DSi
Click on the wrench icon to access "System Settings."
Select "Internet" on the third page of System Settings.
Select "Connection Settings" and tap the "None" bar in "Connection 1."
You have the option of setting up a connection manually, or searching for available connections in the area. You may also access your Nintendo Wi-Fi USB connector, if you have one (the product has been discontinued). The easiest thing to do is select "Search for an Access Point."
Your Nintendo DSi will list the names of any wireless access points in range. A gold, unlocked icon next to the connection's name signifies an unlocked WEP (Wired Equivalent Privacy) connection that can be accessed immediately. A locked gold icon signifies an encrypted WEP connection that requires a WEP key (password).
If you are accessing a locked/encrypted connection, enter your WEP key. You may also click "Change Security Settings" to enter a WPA (Wi-Fi Protected Access) key.
If your WEP key is correct, your Nintendo DSi should connect. You can test your connection to verify.
You're set! Now you can surf the Internet, purchase games and add-ons in the Nintendo DSi Shop, and play games that allow wireless access and competition (with WEP connections, only).
Tips:
If you need help with your router settings, visit Nintendo's router FAQ
Most Nintendo DS and DSi owners can get online by searching for an access point, but some might have to resort to manual setup. Visit Nintendo's manual setup guide if you have a unique situation and need help.
The Nintendo DSi can go online with a WPA connection, but actually playing DSi games online requires a WEP connection.
What You Need:
A Nintendo DSi
A broadband internet connection, such as cable, DSL or FIOS
A wireless router
A Nintendo Wi-Fi USB Connector (optional)
Dec 24, 2010 | Nintendo DSi White Console
Web setup
With a Wi-Fi compatible game inserted into your Nintendo DS, access the Nintendo Wi-Fi Connection Settings screen. Your game manual provides information on how to do this for the game you are playing.
  1. Tap Nintendo Wi-Fi Connection Settings
  2. Tap one of the Connection slots
  3. Tap "Search For An Access Point"
The Nintendo DS will then display the name of your wireless access point.
If your Access Point has a blue, unlocked icon, tap the Access Point name, and then 'OK.' The Nintendo DS will then establish a connection with your router. Back out to the main screen of your game and your ready to play online.
If your Access Point has a red, locked icon, the Nintendo DS has detected WEP key security on your router. Tap the Access Point name on the Nintendo DS and then enter the WEP key for your router on the following screen and tap 'OK' to save the settings.
Tap 'OK' again and the Nintendo DS will then establish a connection with your router. Back out to the main screen of your game and your ready to play online.
If your Access Point has a gray, locked icon, the Nintendo DS has determined your router's security settings are not supported by the Nintendo DS. In order to connect to the Nintendo Wi-Fi Connection, you will need to either switch to WEP security, or remove the security setting of your router when connecting with the Nintendo DS.
NOTE: All information taken from http://www.nintendo.com/consumer/wfc/en_na/ds/connect.jsp
Oct 09, 2010 | Nintendo DS Lite
What is wi fi whats does it do
Wi-Fi stands for wireless fidelity. The term Wi-Fi, which is alternatively pushed by the Wi-Fi Alliance, a trade group that pioneered commercialization of the technology. Wi-Fi is mostly about connecting to the Internet without physically attaching your computer to anything. Mostly it's about using laptop computers.
A Wi-Fi enabled device such as a personal computer, video game console, mobile phone, MP3 player or personal digital assistant can connect to the Internet when within range of a wireless network connected to the Internet. The coverage of one or more (interconnected) access points — called a hotspot — can comprise an area as small as a few rooms or as large as many square miles. Coverage in the larger area may depend on a group of access points with overlapping coverage. Wi-Fi technology has been used in wireless mesh networks, for example, in London.
In addition to private use in homes and offices, Wi-Fi can provide public access at Wi-Fi hotspots provided either free-of-charge or to subscribers to various commercial services. Organizations and businesses - such as those running airports, hotels and restaurants - often provide free-use hotspots to attract or assist clients. Enthusiasts or authorities who wish to provide services or even to promote business in selected areas sometimes provide free Wi-Fi access.
Routers that incorporate a digital subscriber line modem or a cable modem and a Wi-Fi access point, often set up in homes and other premises, can provide Internet-access and internetworking to all devices connected (wirelessly or by cable) to them. One can also connect Wi-Fi devices in ad-hoc mode for client-to-client connections without a router. Wi-Fi also enables places that would traditionally not have network access to connect, for example bathrooms, kitchens and garden sheds.
Good luck and have a nice day.
rating the solution is highly appreciated.
Jul 29, 2010 | RIM BlackBerry Curve 8520 Smartphone
Connecting a Ipaq RX3715 to a wireless router
First, you have to be sure your ipaq has wi-fi feature is on and you can check on network connectivity option for any wrong setup there. According to your information, your ipaq is not recognized by your router and I agreed that your router is working normally. Try to reboot your ipaq and be sure to get wi-fi to turn on and try to connect it again. I have my Dell Axim also used Windows Mobile like Ipaq and it connected easily with no issue. The message in your to show me that you need first to identify your ipaq before you you can get it to connect to your network. I hope this help.
Mar 05, 2007 | HP iPAQ RX3715 Pocket PC
BenQ Joybook 3000-01 Notebook Logo
222 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
