Question about Gigabyte GA-8IGX Motherboard
Change sd ram to ddr ram
I have a P4VMM2 1.7 board with sd ram now trying to put in new ddr ram but not working is there something i have to change on the board a jumpper or something i have to change .
  • newroad Oct 23, 2007
     I changed the jumpers and got  it working .thanks
    Scholar:
  • 155 Answers
Because you didn't indicated the version of you motherboard I need you to go to the ECS website http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=190&DetailName=New&DetailDesc=&CategoryID=1&MenuID=6&LanID=0
On your left select product category motherboards, socket 478, model P4VMM2, the right version and download the manual for your motherboard.
If you look the manual there are few jumper that you need to change.
Usually JP1, j2 and J3 like on this picture.
Let me know if you have problem with the manual, you can give me the version type and I'll find it for you.
Posted on Oct 23, 2007
SOURCE:
Hey All, THIS IS URGENT. My PVCLE266M-L V3.0a will not boot into any OS. I have 2 identical boards. I can navigate BIOS on both of them with the DDR400 512MB RAM stick I have put in. (The specifications...
Your mainboard PVCLE266M-L does not support the DDR 400 Mhz RAM (PC3200) ie @ 400Mhz frequency. For the memory specfications it support "2 x 184-pin DIMM sockets support two2.5V DDR SDRAMs (DDR266)" maximium is 2GB or DDR PC2100 ie @ 266Mhz frequency.
PC133 is the SDRAM so it will not fit the DDR RAM slot.
You should not use the 400MhzDDR memory RAM on a Mainboard with a FSB(Front Side Bus) of 133 Mhz and the 400Mhz DDR Ram is not compatible with the mainboard.
Get the DDR 266 with double side chipset i.e.DDR1 RAM (DDR PC2100) RAM and it will be compatible with your mainboard. Sometimes single side chipset DDR1 RAM will not work on older mainboard.
Hope it helps.
Jul 10, 2011 | Mercury Computers & Internet
How to replace SDRAM to DDR
sdram has two slots in the module where as ddr ram has only one and there are no jumper settings
Jul 30, 2010 | Mercury Electronics KOB 630e CFSFx...
Istall the ram but do not desplay ram is out of socket and than buzzer 3 bip I was install Ram to other mother board Ram is ok please solve the problem
It is the wrong speed ram for the other motherboard for instance 133 sdram, 100 sd ram, pc2700 ddr ram, pc3200 ddr ram etc. you will have to see what type of ram is acceptable in your new board.
Feb 15, 2010 | Intel D845GLLY Motherboard
I have intel 845 glly desktop board with 256 mb SDR. When I added 128 mb SDR in the second slot it is not recognising it. How to add 128 mb SDR with 256 mb SDR. When I fix 128 mb ram in first slot and...
1st try to exchange the cards in the slot.
2nd try another card
3rd ur RAM slot may not be ok
4th ur RAMs may not be compatible
5th ur new RAM card may not be ok
use same type of RAMs, and same size...
if u have 256, add 256
if u ahve 128 add 128
if u have SDR then dont add DDR
getting compatibility is little difficult...
some times no combinations can work...
note...technology keeps changing...so a old RAM card that was bought years ago may not be compatible with a new RAM card....
even i got all my old RAM cards(256+128) removed and got 2 - 512mb of the same type fixed...even i had issues with my RAMs for 6 months...
Dec 27, 2009 | Intel D845GLLY Motherboard
Ram compatabilty for k7s5a motherboardand can I run a 1gig of ram with this board
A really unique MB since Each DIMM slot can accommodate DIMMs up to 512 MB in size, although both DDR and SD-RAM are supported, but any one at time, i.e. one among consisting of a bank of 2 DIMM slots(blue pair & black pair having the pairs 2 slots each) for DDR or 2 DIMM slots for DDR or SDR memory cannot be used at the same time. Thus the board supports either 1 GB of PC133 SDRAM, or 1 GB of DDR sdRAM, but not both at the same time.
I hope you got the Catch 22 here !! Nice low costs for doing simple work?
but it's a Catch 22 situation{either choose the Devil or Hell !) ................. sodeep
Oct 25, 2009 | EliteGroup Computers & Internet
I can't recognize what specific RAM this motherboard accepts..
Dear sir,
In reply to your post- Generally now a days we use DDR400 RAM(DDR 1) for this type of motherboard.So DDR 400 RAM is More compatible then other RAM,you can use this RAM for your motherboard to obtain good performance.
good luck
chandrashekhar
Aug 04, 2009 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
Ram compatibility
No Sir, it will only support DDR / SD RAM. You can see the complete specs of your Board here.
If i was helpful, kindly do Rate! Regards.
Jul 31, 2009 | Computers & Internet
Ddr not detected
if you want to use ddr ram with p4vmm2 mother bord you must replace the jumper near by the ddr2 slot
then your computer starts to work with ddr ram at 266Mhz also 400 Mhz too.
Feb 09, 2009 | EliteGroup P4VMM2 Motherboard
Prolem with DDR RAM 400
Hello, you might want to check hear http://www.crucial.com/ there is a good chance that you put the wrong type of ram in this computer.And it might need a new motherboard.
Oct 01, 2008 | Compaq Presario 5000 PC Desktop
Pentium 4 comptability with SD Ram
If you know what mother board you have you could check what RAM it can use.
All RAM is installed in the same way, but different types of RAM are keyed differently. That basically means that one type of RAM (for example SD RAM) will simply not fit into another type of RAM slot (for example a DDR RAM slot).
To install ram on a PC
Please note - do NOT touch the connector side of the RAM, handle it only by holding the side or top edge
1. check that you have the right type of RAM. do this by lining up the RAM above the RAM slot and making sure that the RAM is the same length as the RAM slot AND ALSO that the RAM's key (the little hole or notch in the RAM) lines up with the key in the RAM slot. Note there might be more than one key
2. open both clips of the RAM slot by pushing them down and out from the center of the RAM slot
3. gently insert the RAM into the RAM slot
4. check again that the RAM and the RAM slot's key's line up, if they do, firmly press down on the RAM on both corners until both clips automatically click shut on the RAM
That's it! :-)
-Magnon
May 13, 2008 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
Gigabyte GA-8IGX Motherboard Logo
543 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Thomas F. Schneider
robert roberts
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
