Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer Leaking
My 3 year old duet wash has been leaking water and water has been accumulating in the drum. I have an extended warranty from Best Buy and they've been out 2 times this week. First time, he found a sock between the drum and below and declared problem solved. 2nd time he cleaned out a valve next to the water pump and declared problem solved. I ran a load of laundry yesterday and the drum was filled with approximately 3 inches of water and clothes were wet. I ran the drain and Spin mode and the drum cleared. This morning I went to dry the clothes that were in the washer and again the drum was filled with water and had leaked. I have the same problem with my GHW9100LW2. It will magically fill up overnight, but only sometimes...I thought I had elves living in my garage! It doesn't do it every day--in fact, it can go a few weeks without doing it...junk...I regret buying this machine.
  • rsouza3 May 30, 2009
    Thanks Vic! That's what i was guessing it was. I think my hard water is the culprit, as the valve is only 3ish years old. At least it is easy to access.
    Now I just need to shop for the part.
    Thanks again for the quick response!
    Reece
    Quick and helpful response! I wish all help sites were this quick!
  • 3 Answers
Hi; I HAD A SIMILAR ISSUE; VERY HARD WATER CAUSED MIXING VALVE TO CLOG AND REMAIN OPEN. Mine cost about $50 to repair, and I did it myself.
Good Luck! Paul
Posted on Jun 11, 2009
    President:
  • 1,136 Answers
Hi, If you are getting water in the washer without it running, the inlet mixer valve is going bad. When you run a load, does it finish spinning and all the water is out? I hope this helps you. It is not an expensing repair. I can walk you through the repair if you would like.
Please let me know if I can assist you further.
Thanks
Vic
Posted on May 30, 2009
  • Victor
    Victor May 30, 2009
    You are very welcome.
    Please feel free to rate my response so that others as well as myself know how I am doing.
    Thanks
    Vic
  • Victor
    Victor May 30, 2009
    My pleasure
Whirlpool duet front lading washer, GHW9150PW4
Could be drum bearings gone Quite a big job hence costly with around 3 hours labour plus parts, some models need half drum as the bearings are loaded in here,leak could be door boot seal at 7 yrs old not sure if worthwhile as its about the end of its working life.Good luck
Apr 06, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Water seeps into Whirpool Duet washer
If your washer is leaking water when it is not in use, the following link explains how to troubleshoot to isolate the cause:
http://www.fixya.com/support/r3753262-front_load_washer_fills_when_not_in_use
The problem is either attributed to a defective pressure switch or a water inlet valve that is leaking by. The link I provided will explain how to determine which one.
If you still require assistance, please let me know.
Jan 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport washing machine with a leaking door.
You need to check if the door is not loose on the washer, make sure you tighten all the screws on the door
Jan 07, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Duet GHW9150W0 Washer - Stainless Steel Washer Bin Arms Broken
I HAD THE SAME PROBLEM. I CALLED THE 800 NUMBER AND HAD WHIRLPOOL SEND ME ALL OF THE PARTS THAT WERE STILL UNDER THE EXTENDED WARRANTY THAT I PURCHASED. WHIRLPOOL SENT ME EVERY PART, INCLUDING THE STAINLESS TUB, THAT WAS STILL UNDER WARRANTY. I NOW HAVE REPLACED ALL INTERNAL PARTS EXCLUDING THE MOTOR.
Jun 07, 2009 | Whirlpool GHW9150 Duet Washer
Whirlpool duet washer leaking water into the drum when not used
water leakin in tho the drum is sign of a faulty water inlet valve, not shutting off water supply to machine, it continues to trickle in , in beween washes. you can turn off the water supply between washes see if this helps, and if it does then youll know its the water valve
Jan 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Leaking whirlpool duet washer front load
remove and clean any obstruction or deposits around the inner door seal use H.E. detergent over sudsing can cause that too.
Mar 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
For those wondering about replacing the water inlet valve - this is a very simple undertaking.  You can find the part online for around 40 bucks.  All you have to do is unplug the washer, detach the hot and cold supply hoses, remove the lid (3 torx bits on my model) unhook the water line from the old inlet valve (conveniently accessible at the top right of the unit from the rear), unhook the electrical connections (be sure to label these for later re-attachment), unscrew the 1 screw holding the valve in place, and reverse the process with the new valve.  I'm hoping this will stop water accumulating in the drum - I'll update later if it does not.
Jan 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer leaking from bottom back..
sounds like you need to check your back drain could be the drain is clogged.Fill with water and see if it comes from the drain
Nov 06, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
573 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
