How to find tally 9 short-cut keys
Tally short-cut keys
  • 66 Answers
Tally 9 short-cut keys appear on the right-side of the tally screen. see the button names in the button bar.
few short-cuts:
Keys
Functions
Alt + 2
To Duplicate a voucher
Alt + A
To Add a voucher
To Alter the column in columnar report
Alt + C
To create a master at a voucher screen (if it has not been already assigned a different function, as in reports like Balance Sheet, where it adds a new column to the report)
To access Auto Value Calculator in the amount field during voucher entry
Alt + D
To delete a voucher
To delete a master
To delete a column in any columnar report
Alt + E
To export the report in ASCII, HTML OR XML format
Alt + I
To insert a voucher
To toggle between Item and Accounting invoice
Alt + N
To view the report in automatic columns
Alt + P
To print the report
Alt + R
To remove a line in a report
Alt + S
To bring back a line you removed using ALT + R
Alt + U
To retrieve the last line which is deleted using Alt + R
Alt + W
To view the Tally Web browser.
Alt + X
To cancel a voucher in Day Book/List of Vouchers
Alt + Y
To Register Tally
Ctrl + A
To accept a form – wherever you use this key combination, that screen or report gets accepted as it is.
Ctrl + Alt + B
To check the Company Statutory details
Ctrl + G
To select the Group
Ctrl + Alt + I
To import statutory masters
Ctrl + Q
To abandon a form – wherever you use this key combination, it quits that screen without making any changes to it.
Ctrl + R
To repeat narration in the same voucher type
Ctrl + Alt + R
Rewrite data for a Company
Posted on May 30, 2009
    Sniper:
  • 108 Answers
The shortcut keys appear in button names in the button bar (right side of the Tally screen). You can either click the button from the button bar or press the relevant function key or character underlined/double- underlined.
The buttons have a function key before the button names ( Eg: F1: Select Cmp) which means you need to press F1 key (Function Key) to select the 'Select Company' screen
The buttons have an underlined character ( Eg: F3:Cmp Info), which means you need to press ALT + F3 to select the 'Company Info' screen.
Some buttons have a double-underlined character (Eg: As Voucher) which means you need to press CTRL + V to select the 'Voucher' in voucher mode.
The shortcut keys available in Tally are listed in the below table:
Function Key Combination
WindowsFunctionalit yAvailability
F1To select a company
To select the Accounts Button and Inventory buttonsAt all masters menu screen
At the Accounting / Inventory Voucher creation and alteration screen
F2To change the menu periodAt almost all screens in TALLY
F3To select the companyAt almost all screens in TALLY
F4To select the Contra voucherAt Accounting / Inventory Voucher creation and alteration screen
F5To select the Payment voucherAt Accounting / Inventory Voucher creation and alteration screen
F6To select the Receipt voucherAt Accounting / Inventory Voucher creation and alteration screen
F7To select the Journal voucherAt Accounting / Inventory Voucher creation and alteration screen
F8To select the Sales voucherAt Accounting / Inventory Voucher creation and alteration screen
F8 (CTRL+F8)To select the Credit Note voucherAt Accounting / Inventory Voucher creation and alteration screen
F9To select the Purchase voucherAt Accounting / Inventory Voucher creation and alteration screen
F9 (CTRL+F9)To select the Debit Note voucherAt Accounting / Inventory Voucher creation and alteration screen
F10To select the Reversing Journal voucherAt Accounting / Inventory Voucher creation and alteration screen
F10To select the Memorandum voucherAt Accounting / Inventory Voucher creation and alteration screen
F11To select the Functions and Features screenAt almost all screens in TALLY
F12To select the Configure screenAt almost all screens in TALLY
Special Key Combination
ALT + 2To Duplicate a voucherAt List of Vouchers € ¦'¶ creates a voucher similar to the one where you positioned the cursor and used this key combination
ALT + ATo Add a voucherAt List of Vouchers € ¦'¶ adds a voucher after the one where you positioned the cursor and used this key combination.
ALT + CTo create a master at a voucher screen (if it has not been already assigned a different function, as in reports like Balance Sheet, where it adds a new column to the report)At voucher entry and alteration screens, at a field where you have to select a master from a list. If the necessary account has not been created already, use this key combination to create the master without quitting from the voucher screen.
ALT + DTo delete a voucher
To delete a master
(if it has not been already assigned a different function, as explained above)At Voucher and Master (Single) alteration screens. Masters can be deleted subject to conditions, as explained in the manual.
ALT + ETo export the report in ASCII, SDF, HTML OR XML formatAt all reports screens in TALLY
ALT + ITo insert a voucherAt List of Vouchers € ¦'¶ inserts a voucher before the one where you positioned the cursor and used this key combination.
ALT + OTo upload the report at your website At all reports screens in TALLY
ALT + MTo Email the reportAt all reports screens in TALLY
ALT + PTo print the reportAt all reports screens in TALLY
ALT + RTo remove a line in a reportAt all reports screens in TALLY
ALT + STo bring back a line you removed using ALT + RAt all reports screens in TALLY
ALT+ VFrom Invoice screen to bring Stock Journal screenAt Invoice screen € ¦à Quantity Field € ¦à Press Alt + V to select the Stock Journal.
ALT + WTo view the Tally Web browser.At all reports screens in TALLY
ALT + XTo cancel a voucher in Day Book/List of VouchersAt all voucher screens in TALLY
ALT + RTo Register TallyAt Licensing Menu in TALLY
CTRL + ATo accept a form € ¦'¶ wherever you use this key combination, that screen or report gets accepted as it is.At almost all screens in TALLY, except where a specific detail has to be given before accepting.
CTRL + BTo select the BudgetAt Groups/Ledgers/ Cost Centres/ Budgets/Scenarios/ Voucher Types/ Currencies (Accounts Info) creation and alteration screen
CTRL + CTo select the Cost Centre
To select the Cost CategoryAt Groups/Ledgers/ Cost Centres/ Budgets/Scenarios/ Voucher Types/ Currencies (Accounts Info) creation and alteration screen
At Stock Groups/ Stock Categories/ Stock Items/ Reorder Levels/ Godowns/ Voucher Types / Units of Measure ( Inventory Info) creation/alteration screen
CTRL+ ETo select the CurrenciesAt Groups/Ledgers/ Cost Centres/ Budgets/Scenarios/ Voucher Types/ Currencies (Accounts Info) creation and alteration screen
CTRL + GTo select the GroupAt Groups/Ledgers/ Cost Centres/ Budgets/Scenarios/ Voucher Types/ Currencies (Accounts Info) creation and alteration screen
CTRL + ITo select the Stock ItemsAt Stock Group/ Stock Categories/ Stock Items/ Reorder Levels/ Godowns/ Voucher Types / Units of Measure ( Inventory Info) creation/alteration screen
CTRL + LTo select the LedgerAt Groups/Ledgers/ Cost Centres/ Budgets/Scenarios/ Voucher Types/ Currencies (Accounts Info) creation and alteration screen
CTRL + OTo select the GodownsAt Stock Group/ Stock Categories/ Stock Items/ Reorder Levels/ Godowns/ Voucher Types / Units of Measure ( Inventory Info) creation/alteration screen
CTRL + QTo abandon a form € ¦'¶ wherever you use this key combination, it quits that screen without making any changes to it.At almost all screens in TALLY.
CTRL + Alt + RRewrite data for a CompanyFrom Gateway of Tally screen
CTRL + SAllows you to alter Stock Item masterAt Stock Voucher Report and Godown Voucher Report
CTRL + UTo select the Units At Stock Groups/ Stock Categories/ Stock Items/ Reorder Levels/ Godowns/ Voucher Types / Units of Measure ( Inventory Info) creation/alteration screen
Ctrl + VTo select the Voucher TypesAt Groups/Ledgers/ Cost Centres/ Budgets/Scenarios/ Voucher Types/ Currencies (Accounts Info) creation and alteration screen
Special Function Key Combination
ALT + F1To close a company
To view detailed report
To explode a line into its detailsAt all the menu screen
At almost all report screen
ALT+ F2To change the system periodAt almost all screens in TALLY
ALT + F3To select the company info menu
To create/alter/ shut a CompanyAt Gateway of Tally screen
ALT + F4To select the Purchase Order Voucher TypeAt Accounting / Inventory Voucher creation and alteration screen
ALT + F5To select the Sales Order Voucher Type
To view monthly and quarterly report At Accounting / Inventory Voucher creation and alteration screen
At almost all report screens in TALLY
ALT + F6To select the Rejection Out Voucher Type
To change the Sales Order Voucher TypeAt Accounting / Inventory Voucher creation and alteration screen
ALT + F7To select the Stock Journal Voucher Type
To accept all the Audit lists At Accounting / Inventory Voucher creation and alteration screen
At TallyAudit Listing screen
ALT+ F8To select the Delivery Note Voucher Type
To view the Columnar reportAt Accounting / Inventory Voucher creation and alteration screen
At Ledger Voucher screen
ALT + F9To select the Receipt Note Voucher TypeAt Accounting / Inventory Voucher creation and alteration screen
ALT + F10To select the Physical Stock Voucher TypeAt Accounting / Inventory Voucher creation and alteration screen
ALT + F12To filter the information based on monetary valueAt almost all report screens
CTRL + ALT + F12Advanced ConfigAt Gateway of Tally
Key Combination used for navigation
PgUpDisplay previous voucher during voucher entry/alterAt voucher entry and alteration screens
PgDnDisplay next voucher during voucher entry/alterAt voucher entry and alteration screens
ENTERTo accept anything you type into a field.
To accept a voucher or master
To get a report with further details of an item in a report.You have to use this key at most areas in TALLY
At the receivables report € ¦'¶ press Enter at a pending bill to get transactions relating to this bill (e.g., original sale bill, receipts and payments against this bill, etc)
ESCTo remove what you typed into a field
To come out of a screen
To indicate you do not want to accept a voucher or master.At almost all screens in TALLY.
SHIFT + ENTERCollapse next level detailsAt Voucher Register screen and Trial Balance report
SHIFT + ENTERTo explode a line into its detailsIn almost all Reports:
CTRL + ENTERTo alter a master while making an entry or viewing a reportAt voucher entry and alteration screens
please vote
regards
murali
What is the short cut key for make a new ledger
Posted on May 23, 2014
I need tally erp 9 licence key to register
I'm sorry but this is not a warez site...We can't give out activation keys or access codes.
Aug 20, 2012 | Microsoft XP Computers & Internet
I need to install a tally on windows server 2008R2.... so pls suggest me, which version of Tally is a recommended...... Thanks
Hiiii,
Server 2008 R2 is not available for tally its need TAlly patch so reinstalled Tally ERP 9
Regards,
Jagjit Mishra
May 18, 2011 | Computers & Internet
HEN I WAS OPENING TALLY ERP 9 I HAVE BEEN FACING
Step 1
Windows Key+R
in the Run Box
Type your Tally Folder Path as following
Eg. D:\Tally.erp9\tally.exe data 0
when open Tally Getway
use Ctr+Alt+R
Rewrite All Company
Enjoy....
IF Problem is same
then in the data folder company number folder
delete all tsf file and attem step 1 again
Problem is 100% solved.
AYS, Beawar,
Thanks to Mir -- Manish JI Garg..
Mar 26, 2010 | Tally LA650 Matrix Printer
Serial no and activation code for TALLY ERP 9
i need a serial no. & activation key of tally erp 9.
plz help me.
Feb 25, 2010 | Sony Computers & Internet
Tally 9 serial number?
how to download the free version of tally 9
Dec 11, 2009 | Tally T2245 Matrix Printer
I need tally erp 9 serial no when i activate tally erp 9
Hiii i need tally 9 erp seriol no. when i active it....
Dec 11, 2009 | Computers & Internet
Cant change the date in tally 7.2
i have tally 7.2 software and i working on tally 7.2 bur before some software was lost and now i have install again tally 7.2 but i have chage the date period 1-4-2010 o 31-3-11 but it accep only 1 and 2 date it is not accepting 3 to 31 date so pls reply solution for this problem my emailid vatsnaina72@yahoo.in
Aug 03, 2009 | Tally T2250 Matrix Printer
Computers & Internet Logo
1,598 people viewed this question
David Payne
David Payne
