Question about Spectroniq PLTV3250 32 in. LCD TV
Tv wont turn on worked fine last night
My Olevia Tv wont turn on worked fine last night when shut off I tried to turn on this morning and there is no power to the tv I tried different source of power same problem
  • Anonymous Mar 13, 2014
    turned off tv last night was fine turned on this morning white screen it says power only vol. 18.00 remote will not turn it on or off
  • Anonymous Mar 30, 2014
    tv working ok yesterday. Tried to turn on this morn ing but no power. the set is dead. Tried changing fuse in plug etc but still the tv will not come on
  • Spectroniq Master
  • 19,396 Answers
If there is no power at all, then the problem is likely the power supply unit.
The PSU must be tested, then eventually replaced.
Posted on May 30, 2009
Olevia 232-s12 not powering on
u have a bad mainboard or power supply board most likely the mainboard
Mar 02, 2013 | Olevia Televison & Video
RCA D52W20 HDTV TRIES TO TURN ON 3 TIMES BUT WONT POWER UP
remove all the electrical wire connections from the back of the tv .remove the power plug from the electrical outlet and wait for two minutes and replug the wire and then ckeck.it should work.
reply.
Oct 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My olevia LT23HVX does not power on
Try unplugging and replugging after waiting.
Jun 13, 2008 | Olevia LT23HVX 23 in. LCD Television
Last night the tv was fine i turned it on this
Unplug 20 minutes. Make sure there is adequate ventilation around the set.
Try with the original manufacturer remote to view setup menu.
Power outages come at night. This sometimes resets the TV and other devices. .
Mar 25, 2010 | Insignia 42" LCD Flat-Panel HDTV
LG 32LP1D TV no power
Check the fuse on the power board. If ok change the power board.
Nov 01, 2009 | Televison & Video
Tv repair
I soudcs like the backlight inverter board is bad or the power supply is npt supplying 24vdc to the inverter board.
Oct 31, 2009 | Olevia LT37HVS 37 in. LCD HDTV
No power no led's
check there is a problem with SMPS and fuse/power socket problem thank u
May 24, 2009 | Spectroniq PLTV3250 32 in. LCD TV
TV turns itself off after a few seconds, no picture at all
As far as fixing goes, you might as well get a new TV... Unless its a LARGE EXPENSIVE HOLY $%^# TV, It will cost more to fix, than to just buy a new one, unless its under warranty, which being an older model as that (or so im reading) It may not be covered.
Try unplugging the TV, and while unplugged, hold down the power button for a full minute (yes, with the plug NOT in the wall) after a minute, plug it back in, and try. Its a hard reset. If it still does not work, and you've tried different outlets, It's probably a repair issue, and you'll need to get someone to fix it, or just junk it :-/
Nov 11, 2007 | Sylvania SST4322 32" TV
Spectroniq PLTV3250 32 in. LCD TV Logo
955 people viewed this question
Top Spectroniq Televison & Video Experts
Frank Zabroski
Frank Zabroski
Jayesh Panchal
Jayesh Panchal
Are you a Spectroniq Televison and Video Expert? Answer questions, earn points and help others
