Question about Dell Dimension 2400 PC Desktop
No monitor signal when powered on, pre-bios failure??
I've got a Dell dimension 2400 which i've had in the antic for a while and now decided to use again. When i power it on nothing happens. There is a led working on the motherboard and the fans are working but thats about it. Ive looked it up and all i can find is that it might be a pre-bios failure. what do i need to do to fix this?
  • 1 more comment
  • giacomocarat May 30, 2009
    :) Yeh monitor still works. ive tested it on another computer
    No its an on board graphics card.
  • meteshadow May 11, 2010
    yo are sure your anctic :) monitor works still ?
  • 489 Answers
Is the graphic card is on boarded or external ? if it is external try it with another computer. if the problem still exists you have problem with mainboard or Cpu.
Posted on May 30, 2009
  • meteshadow May 30, 2009
    it looks like mainboard issue. it a on board. you said.
    hope helpful.
I have a Dell Dimension 2400 desktop. It needs a monitor. I tried new ones from Best Buy and Office Max but they say no signal when I hook them up..I tried this computer with monitor in the following
Thank you for replying,
As per the diagnostic LED's, it is an issue with Video initialization failure. Your computer has onboard Graphics which is built into the Motherboard.
Video Initialization failure could happen if there is :
Unseated AGP card
Bad AGP card
Bad motherboard
As per your Svc Tag your system doesn't have AGP Graphics Card, Probable issue with MOBO.
This computer doesn't have a AGP Slot (Graphics Card Slot) to try connecting Graphics Card.
Need to repair/replace MOBO.
Thanks.
Feb 25, 2014 | Dell Dimension Computers & Internet
Dell dimension 2400 freezes up shortly after boot. I replaced cooling fan but error log shows keyboard failure.
if you see lights get on Keyboard.. your motherboard is fine.. else it is your Keyboard or Super I/o Chip that is not working..
Mar 27, 2013 | Dell Dimension 2400 PC Desktop
DMA Initialization Failure
Sounds like you have no power. No signal to monitor means the computer has no power.
Jan 22, 2012 | Dell Dimension 5100 (D51L1) PC Desktop
Hi - our dell dimension c521 is stuck in power save mode. The light on the monitor is solid orange and will not respond to the keyboard or mouse
A solid amber light indicates a pre-POST failure has occurred. The system has received a Power Good signal from the power supply so it's not a power supply issue. HERE is the documentation that tells what the lights mean and possible solutions.
Aug 26, 2010 | Dell Dimension C521 PC Desktop
I have an older Dell Dimension 2400 series. I have tried running the monitor with it. I will get it up and running only after numerous restarts. Most of the time when I start up my system the monitor...
If it's an older 2400 series and you suspect it doesn't have a good signal going to it, I would try the monitor on a different tower to see if it's the monitor. If it isn't, I would recommend that you try to disable and change the VGA card in the Dell, if possible to a known good VGA card.
Also, try wiggling the connections at the monitor and graphics card, if this applies.
Or else, it might be a lost cause for that tower.
Good luck on getting the Princeton monitor working with your Dell Dimension 2400 series.
Aug 17, 2010 | Princeton Digital VL2018W Monitor
Dell dimension 2400 diskette drive 0 seek failure
Check your BIOS setting to see if it detects the hard drive (Primary disk 0). If it can't detect the hard drive then the hard drive maybe faulty. Open the case unpluge the IDE cable from the hard drive and reconnect it again, also unplug the IDE cable at the motherboard and reconnect it again including the power connector on the hard drive.
There maybe an option to test the hard drive in the BIOS, if so use it to test the hard drive.
If the hard drive is faulty, you need to replace it and install Windows, the various device drivers and your programs to get a functioning computer again.
You might consider buying a new computer (it will be faster & better than the old Dell) and you have your new monitor to go with it.
May 21, 2009 | Dell Dimension 2400 PC Desktop
Diagnostic Indicator
Beep codes and power LED status are pre-post errors. Usually beep codes indicate a problem with a memory module. Power LED is solid green for normal operation. Solid or blinking Amber color power LED indicates a power distribution problem.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 13, 2008 | Dell Dimension 2400 PC Desktop
Dell dimension 2400
Click this link:
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/advtshoo.htm
It contains the list of the beep codes for dell dimension 2400.
There is also a guide on how and what to troubleshoot. Motherboards use beep codes to indicate what error might caused the system to malfunction.
Dec 17, 2007 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
427 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
