Question about Sharp AL-1641CS All-In-One Laser Printer
Toner issue with several third party toner cartridges
We have a AL-1641 CS.  It will not print and has a indicator light suggesting it needs a new toner cartridge.  We just put one in several weeks ago.  So there should be plenty of toner in it.  The machine turns on hums for a long while then begins to show the toner light.
This has happed before but at a $100+ a pop the tone is costing us greatly.
It is in our church office located in central Florida.  It doesn't get used much but the office is pretty much un cooled and somewhat humid.
Thanks
  • 62 Answers
Their is a chip screwed on the back of the toner remove it and this will fix your problem.
Posted on Oct 29, 2007
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
Here is the manual for that machine ( incase you don't have it, check out page 59
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=fcb5a95908d7e226bcd8ab88b0637b4f&q=Sharp+AL-1641CS
$100 for toner, wow, try these guys, I've used them and their services are good. Not sponsoring.
http://www.precisionroller.com/k_sharp_al-1641-cs_toner_cartridge/m180d4669c36/
  • CheckitRight
    CheckitRight Oct 29, 2007
    I live in south florida myself, humidity will affect copy quality and paper jamming, not toner itself.
Meaning H 4 appear alternative Sharp Al-1641 CS
H4 is nothing but an error code that appears due to power fluctation(in absence of a stabilizer). You please enter # interrupt-C interrupt -14-start to clear to clear the error
Jan 12, 2011 | Sharp AL-1641CS Laser Digital Copier
Help! My machine won't copy or print
check the old cartridge was empty or it was just showing wrong indication.( flashing ).
Aug 29, 2008 | Sharp AL-1540CS All-In-One Laser Printer
I have a Samsung ML-2525 BW laser printer. Recently, the red bar second from the top started flashing and then it went solid. I thought this was because of the ink toner, and the cartridge was running low...
I guess it FixYa didn't accept my (very long, but totally correct) solution that I took the time to type. Because I refused to "sign in".
Here's the short version. Load Paper. The same thing happened to me. I replaced the toner cartridge with a new one (because of a FLASHING red light for several weeks) after the red light went to STEADY red. But it still would not print. The paper was "out". When I'd refilled the paper-tray, it printed fine. I had just ASSUMED that the steady-red light meant toner was finally OUT. WRONG! That steady-red light had nothing-to-do with toner; it meant "you're out-of-paper". Don't get confused like I did. Refill the paper-tray. Then take that expensive NEW toner cartridge OUT, and put the OLD toner cartridge back in. And keep using the "dregs" of the toner out of the old cartridge for several more weeks. And DON'T get confused by the paper-is-out condition making that red light STEADY.
Nov 01, 2010 | Samsung ML 2525 BW laser Printer
HP Model C309g. When printing in color, there are stripes on the document. I removed printer head, cleaned and replaced with all new toners. Three times. System has recalbriated several times. How di...
First of all, this is an inkjet printer - it doesn't use toner. It uses ink cartridges.Toner is used for laser printers. Are you using a genuine HP cartridge replacement and paper? Third party sources are not recommended for these printer because of issues you stated. The cartridge and paper combination are specifically designed by HP to work together. Other brands sometime don't work.
Oct 26, 2010 | HP Office Equipment & Supplies
I changed the toner drum in my Dell lasaer printer and now all I get is an error message with a flashing toner. How can I get the printer to print? Thanks,
Did you use a factory new toner cartridge or a refilled/third party cartridge.
If it is a factory new cartridge, contact Dell and let them know you were issued a defective cartridge.
If it is refilled or third party, try to get your money back and hope that you have not damaged your printer.
Then go get a factory new cartridge.
Don
Oct 20, 2010 | Dell 1700n Laser Printer
Instale cartucho
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled (the absolute worst possible choice) or third party cartridges (2nd. Worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Mar 09, 2010 | Canon MultiPASS MP390 All-In-One InkJet...
Blank, Cyan and Magenta are printing, Yellow not printing
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
Don
Feb 21, 2010 | Brother Multi-Function Center® MFC-215C...
The printer keeps on displaying the usupported
Don
Feb 18, 2010 | Dell 924 All-in-One InkJet Printer
Poor print quality after several cleanings and alignment tests. prints the alignment page fine and when I print a regular word doc. the text is misaligned
Don
Feb 17, 2010 | Dell 922 All-In-One InkJet Printer
Sharp AL-1641CS All-In-One Laser Printer Logo
87 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
