Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
Wireless doesn't work
I have three laptops, two of which are HP, one is a Presario V3000, the other a Pavillion 6500... and also a Sony Vaio PCG-R505TFP.
For the Pavillion, the wireless internet works fine but the others don't work. They say that media is disconnected, and I'm not sure how to fix it.. both say that the signal is fine.. they can find my network no problem, but it can NEVER connect. I tried pinging.. and lan works, but wireless doesnt.
For the Presario, it could connect via lan, but never the wireless... and when it's plugged into the lan, the wireless works.
Please help me!!!
    Guru:
  • 523 Answers
Hi Friend,
Kindly check the below given instructions,
To access the WIRELESS (WLAN) settings window, click on the Wireless Setup button in the SETUP directory.
WIRELESS NETWORK SETTINGS
1.Click on the Enable Wireless box to allow the router to operate in the
wireless environment.
2.The SSID identifies members of the Service Set. Accept the default
name or change it to something else. If the default SSID is changed, all
other devices on the wireless network must also use the same SSID.
3.Enable Auto Channel Scan so that the router can select the best
possible channel for your wireless network to operate on.
4.The Wireless Channel can let you select the channel of your access
point. Channel availability is different for different countries due to their
regulation.
5.Select 802.11 Mode to operate in b/g/n mode. Or select specified mode
to use.
6.Channel Width, Maximum rate for 20 MHz is 130 Mbps. Maximum rate
for 40 MHz is 270 Mbps.
7.Transmission Rate, suggest keeping the Best (automatic) selection.
8.Click on the Hide Wireless Network box to allow the router to stop broadcasting its SSID.
WIRELESS SECURITY WIZARD
1.Click on the Security My Wireless Network button to enter the
2.SECURE MY WIRELESS NETWORK window.
1.Input the SSID.
2.Select the Wireless Channel.
3.Select the Encryption type. WPA-PSK is more secure than WEP 64 bit.
4.Click on the Apply Settings button to apply the settings
WIRELESS SECURITY MODE - WEP
1.WEP (Wireless Encryption Protocol) encryption can be enabled for
security and privacy. WEP encrypts the data portion of each frame
transmitted from the wireless adapter using one of the predefined keys.
2.The router offers 64 or 128 bit encryption with four keys available.
Select WEP Key Length from the drop-down menu. (128 bit is stronger
than 64 bit)
3.Specify the encryption key from the Current Network Key drop-down
menu.
4.Enter the key into the WEP Key field 1~4. (Key length is outlined at the
bottom of the window.)
5.Select Authentication type from the drop-down menu. (Shared is
better than Open)
6.Click on the Apply Settings button to apply settings.
Check and revert back
Regards,
Ayyasam
Posted on May 30, 2009
I cant connect to my home wireless broadband after i format my laptop, how can i down load network driver for COMPAQ PRESARIO V3000 notebook.
You can download the LAN and device drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the Windows drivers you require and install them. Click on this link to download the drivers: -
www.compaq.com/country/cpq_support.html
Feb 11, 2013 | HP Compaq for Presario V3000 Motherboard
Compaq Presario V3000 SUDDENLY DEAD
Remove the battery and try on the AC adaptor only. if it still doesn't work try a new adaptor.
Apr 06, 2012 | HP Compaq for Presario V3000 Motherboard
I want audio driver to my laptop sony vaio vgn-t90ps
Cant find that model on the sony site, follow the instructions on the site to get the correct model number
http://support.vaio.sony.eu/computing/vaio/index.aspx?l=en_GB&m=0&s=VGN-T
Aug 06, 2010 | HP 417065-001 - HP Compaq Presario V3000...
Can this HP Pavilion DV9000 laptop adapter fit for Compaq Presario V3000 laptop? I doult that HP Pavilion DV9000 laptop adapter on website:http://www.laptopbatteryshop.ca/hp-pavilion-dv9000-ac-adapter.htm...
Have a look at the label on the bottom of the V3000 laptop and check the voltage and amps power rating of the laptop.
If the DV9000 adapter has the same voltage and current rating (amps) or higher amp rating then it is suitable for the V3000 laptop, provided the power plug fits the V3000 power socket.
Jan 15, 2010 | Dell Inspiron 1525 Laptop
Can this HP Pavilion DV9000 adapter fit Presario V3000 laptop
just see it from http://www.udtek.com/hp-pavilion-dv9000-ac-adapter-90w-185v-49a-p-2970.html.may this is good for you.
Jan 15, 2010 | 2wire (1000-000005-002) 802.11g/b Wireless...
Where do you get the bluetooth driver for Compaq Presario v3000?
Here you go. Just enter your full laptop model number, and you will find all relative drivers.
http://www.hp.com/#Support
Mar 20, 2009 | HP Compaq Presario V3000T Notebook
Monitor wont respond to hp pavillion
HP has identified a hardware issue with certain HP Pavilion dv2000/dv6000/dv9000 and Compaq Presario V3000/V6000 series notebook PCs
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us〈=en&product=1842189&dlc=en&docname=c01087277#c01087277_identify
Jan 22, 2009 | HP Pavilion dv9000z Notebook
HP Pavillion Dv 9000 stopped recognizing wireless networks.
make sure ya have a VISTA compatible Driver for ya wifi ... go to manufactures web site and DL latest one for VISTA..
Remove and reinstall most up to date driver... then use ya connection program to set it up.
Jun 23, 2008 | HP Pavilion dv9000z Notebook
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
255 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
