Question about Nokia N70 Cellular Phone
Fit new earpiece - Nokia N70 Cellular Phone
  • cherrylyn Mar 03, 2008
    cannot switch on the device
  • 490 Answers
With N70 u can put ur earphone at the bottom of ur handset, it must be a pin kind of structure which u have to properly put in the socket.everything else is the work of earphone,
Posted on Oct 23, 2007
Broken earpiece
contact the manufacturer for assistance
Apr 24, 2013 | Logitech Radio Communications
Lost manual need to charge my earpiece
Need more information...what earpiece are you using? Does it have the same charging port as your phone? Chances are your earpiece charges through a micro-usb port. If this is the case, you can easily find a new charger that is of size micro-usb (that is the same size as the charger of most new cellphones).
Feb 28, 2011 | Cell Phones
Sound problem
Make sure that the serrated opening to the speaker/earpiece is not clogged orr dirty. Use a good brush to clean and open up any dirt accumulation.
Next make sure that the earpiece is working , test with a meter to check the sensitivity.
If there is good response from the headphones then it is possible that the speaker is faulty and should be replaced with the same type/size fittings.
Dec 09, 2010 | Sony Ericsson W910i Cellular Phone
Nokia 1208 earpiece problem
Hi, Earpiece can get damaged if there is dirt or the earpiece is totally damaged.
You can clean up the earpiece and see if it will work, if it doesn't work, you will need to replace it.
Thanks for using fixya.
Sep 30, 2010 | Nokia 1208 Cellular Phone
My LG enV seems to think there is an earpiece attached to the phone when there is not. I can't hear anything on the phone right now. How do I correct this? Thanks!
I had the same problem. Because it was the only thing I had on me at the time that would fit....I took a wooden matchstick and jiggled it around a bit inside the earpiece jack. Obviously the part that lights on fire was not inserted into the phone. Only the wood end was inserted. After a few tries, my phone beeped and went back to normal. could then hear again through the main speaker. For some reason my EnV decided to think the earpiece was in when it hadn't been for a week. This matchstick method seemed to fix it and I have not had any problems since. You may just want to insert the actual earpiece headset in and out a few times until you get it to go back to normal.
Sep 12, 2009 | LG enV VX9900 Cellular Phone
Trying to connect my bluetooth to a new cell phone
turn on your cell; go to settings; find bluetooth settings;turn on bluetooth; find audio device choose search; then turn off the earpiece the light will be red next: turn on the earpiece again the light will flash blue and, the cell will find the earpiece the earpiece will flash blue slowly; once a minute
close the cell; use the earpiece
Sep 01, 2009 | Plantronics Explorer 220 Bluetooth Headset...
I have a blackberry 8330. does the jupiter fit in
I assume you mean the Jupiter Jack and not the planet. The Jack fits into the 2.5 mm round earpiece hole on the side. The planet is huge and will not fit into a blackberry.
Aug 24, 2009 | Cell Phones
Changing phones but same Bluetooth earpiece
apparently deleting the earpiece from my SE devices did fix the problem, i just hadn't realised. thanks
Dec 07, 2008 | Lands Phones
Can't hear anything from earpiece when I'm on the phone with someone
Is the earpiece designed for your model? have the airpiece tested at a local phone shop and while your at it test the phone in the shop also with other earpieces if they let you.
Jun 08, 2008 | O2 Xda Atom
I have the same problem with my pebl which occured when i had a replacement cover fitted. I believe there should be a copper wire attached to the earpiece inside which has gone missing during the process. as of yet unsure where to attach the new one.
Aug 05, 2007 | Motorola Mobility RAZR V3
Nokia N70 Cellular Phone Logo
41 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
