Believe injection and firing off
If distributer has ever been out most likely it didnt get put back in same position. pull the #1 plug have some one cover plug hole with finger, by hand or with a socket on crank pully turn crank to your right( when facing engine) until you bring timing mark up to tdcas mark gets close air should blow by finger that way you know your on compression stroke pull distrib cap and see where rotor is pointing thats your new number 1 wire the rest accordingly
SOURCE: i need a diagram for the distributor cap and plug
On the distrubutor cap looking from front no 1 is around the 1 o'clock postion(usually marked on the cap with no. 1) the firing order is 13726548 counter clockwise.
cylinders are passenger side front to rear 1234 and drivers side 5678
SOURCE: wiring diagram for distributor cap
the old fashioned way to check this is to remove your distribution cap and watch the position of your rotor arm to see which position it is for cylindar 1. then take out the spark plug for cylider one and use a light to see inside you should be able to see the piston move up and down throgh the hole, now the piston only goes down twice in one cycle so by cranking the engine round by hand you can correspond where the piton just starts to go down is the point of ignition so the rotor arm should be at the same point lined up with the spark lead for cylinder one inside the cap. if it mile off then cylinder 1 is at the top of the induction stroke, so crank round again until the piston starts to go down again. then you have the distributor arm at the right position, then follow round the cap the firing order for your engine. and then wire up the cap the same way.
SOURCE: We know the firing order but need to know the
For 1992 Cadillac DeVille 4.9 liter V-8 VIN "B" check this ...
Hope helps (remember rated this).
SOURCE: distributor cap diagrahm for a 1992 dodge dakota
Here is a firing order diagram and note the distributor cap latch positions between terminals 1 and 2 and 5 and 4, and let me know if you need any help to understand this diagram or if you require any further assistance.
1-5-3-6-2-4 is the spark plug firing order for the 4.9 L ( 300 cubic inch ) straight 6
The distributor rotor turns CLOCKWISE
The marked # 1 position on the distributor cap is installed facing away from the engine
Hope this helps
