Question about Pool & Spa
Redundant limit switch wires in my telladyne laar pool heater
My redundant limit switch wires in my telladyne laars pool heater are disconnected, (yellow wires) not sure where to reconnect them?
  • 139 Answers
Some years ago factory suggested bypassing the redundant limit.dont worry theres two more limits in case things go south
Posted on Jun 20, 2009
Where is the hi temp limit switch located?
where is the high temp limit switch located on my laars 44000 pool heater
Jun 02, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
(natural gas) the heater comes on for 3-5 minutes and then shuts off, and won't work again for hours. this is a shred heater between the pool and hot tub, but never used for the pool.
Check your high limit switch inside of the heater. Usually when the high limit switch pops it will take about 4 to 6 hours for it to reset itself without you resetting the system.
May 16, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot will light but main burner will not light
if burner lights after jumping valve you have something wrong in thermostat loop. disconnect the 2 thermostat wires on gas valve and use multimeter on continuity setting. if all wires ,connectors and components are good,you will get a tone.since you have jumped out each component in thermostat loop with no success ,i would suspect a bad wire or oxidation on a terminal .
Sep 24, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
I have a laars swimming pool heater, there is gas coming into the valve unit but it will not pass the valve block to light the pilot light.
Disconnect the pilot tube from the valve and pass a thin wire through it to make sure it is not blocked. Spiders have been known to nest in tubes off-season. If the tube is clear and the gas still won't flow through then the valve block probably needs to be replaced. If the high temperature limit has been tripped the valve will have to be replaced as high limit safety does not reset.
Aug 13, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars Lt heater will not start- pressure switch light
it is time to check your filter make sure is not dirty and if your filter is clean and still doing this then the problem can be with one of the safety sensors they do have 2 hight limit switch located in the heater heather they re round with two wires on each one turn power off to heater and get a voltemer reader and check the hight limits for continuty they should read zero on your metter it can be your temp sensor heaters are so complicated that it is always good to have a pool tech service it I was a pool tech in california but now I am located in georgia
Jun 13, 2009 | Jandy Laars Lt 250,000 Btu Heater
Hi limit switch code,on a laars lx pool heater, I think there is a manual reset somewhere. can anyone help?
mine were corroded, but passed a continuity test. removing the corrosion opened a hole in one of the cases. $30/ea to replace (parts only). then i read how the brass 'screw' they contact with are prone to corrosion (salt pool), not listed in the parts manual, but are available as part# R0383200 (another $6/ea). not a happy jandy/laars/teledyne owner.
Jun 09, 2009 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Laars LX400P pool heater Hi Limit Switch light is on? ???Fix?
This indicator normally means that your water temperature in the pool heater exceeds the internal limit. The corrosion should not be causing this problem. Since the high temperatures can be dangerous, you will probably have to contact a pool professional to service the machine.
May 31, 2009 | Teledyne Laars Laars Lx Pool Heater /...
Pilot light on but heater will not start
check the high-limit switches. Under the inlet/outlet header. if either is open it will not allow you to fire up. my 150 degree switch was corroded and after jump9ng out, bam it worked.
May 25, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pool & Spa Logo
130 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
