Question about HP LaserJet 3055 All-In-One Printer
My hp3055 all-in-one laserjet has no power and no lights are lit on the control pannel, no worming up..
Hp 3050 all-in-one has no power and no lights are lit on the control pannel, no warming up sound... is absolutely K.O? may u help me to solve this kind of serious problem?
  • meteshadow May 11, 2010
    have you tired it with another power cable ? or adapter ?
  • 66 Answers
Check the wall socket power, if all is ok there then check power cable (use your computer's power cable to test).
If still its cold then most likely its internal fuse has blown or some issue in its power section.
get hold of a experienced person.
Posted on May 30, 2009
Cant find scanner driver or software for hp 3055
Hi
Use a Normal TWIN driver that appears in any software that allows you to scan or in Windows click on Start, Device and Printers, Select your HP3055 and SCAN
Dec 09, 2014 | HP LaserJet 3050 All-In-One Printer
49 error on HP laserjet 3050
Internal Embedded Software Error. Manual says to power off for 30 seconds. Power it on and let it initialize. If the error persists you will need a tech.
Aug 15, 2011 | HP LaserJet 3050 All-In-One Printer
Unable to print to HP3055 connected through network. Has orange light on the back. All of the lights on netgear switch going crazy, but go normal if I unplug HP3055. Worked perfectly until yesterday when...
check the cable with cable tester ensure good or try with another cable
there is an ip address setting pls check it
if the printer in warranty period try with hp
Jul 15, 2009 | HP LaserJet 3055 All-In-One Printer
how do I change the language? everything is in German.
Nov 11, 2008 | HP LaserJet 3050 All-In-One Printer
I purchased a HP LaserJet 3050
The instruction to use scanner in HP Laserjet 3050
Click Start, click All Programs or Programs, and then click HP. Click HP LaserJet
3050/3052/3055/3090 all-in-one, and then click Scan.
Click Setup.
Select Change the destinations that show up on the all-in-one control panel when I press
the Scan To button, and click Next.
Select Allow me to scan by pressing the Scan To button on the all-in-one....
Move the destinations from the PC window to the All-in-one window.
Click Update. See the online User Guide for complete information
Source : Manual for HP Laserjet 3050
Thanks for using Fixya
SAM ANDERSON
Sep 11, 2008 | HP LaserJet 3050 All-In-One Printer
Replacing Print Cartridge
Turns out there was an easy solution. I filed a support case and had an answer in half a day:
"Often this issue is caused by a sensor. â Therefore the first thing we should do is try to trigger the sensor.
1 Turn off the HP LaserJet 3050
2 Remove the toner cartridge from the HP LaserJet 3050
3 Remove all of the paper in the paper tray
4 Check the entire paper path for any obstructions
5 Reseat the toner cartridge and paper
6 Power on the HP LaserJet 3050
If the issue is still not resolved we will need to try some resets on the HP LaserJet 3050.
1. The first reset we can try is a soft reset, it is done by pressing the MENU key then holding *# together. â This will bring you into a Developers Menu. â Scroll through the options until you find reinit FFS and then press the ENTER key.
2. If this reset doesn't clear the issue we can try a harder reset. â We can do this by pressing MENU, scrolling over to SERVICE, pressing ENTER, scrolling over to RESTORE DEFAULTS and pressing ENTER to restore the defaults and ENTER to confirm.
WARNING: Restoring the defaults will clear your fax settings, phonebook numbers and headers so you may want to print a phonebook report and Config Report first. â We can do this by accessing the Reports menu.
3. If these two resets do not help there is a third reset we can try.This reset will completely put the HP LaserJet 3050 back to factory defaults.WARNING: Before doing this reset we will need to disconnect the power cord, the phone cable, and the USB cable from the back of the HP LaserJet 3050.We can do this reset by unplugging the power cord from the back of the HP LaserJet 3050 then holding down the MENU/ENTER key and * symbol at the same time,then powering the HP LaserJet 3050 back on with the keys compressed.We will release the keys as soon as PERMANENT STORAGE INIT appears on the display screen."
I tried all the steps in sequence; it took #3 to fix it. Fortunately I didn't have a big fax address book or custom settings, so a factory defaults reset didn't cause any extra problems. It retained the time and date, and now it works fine.
Mar 12, 2008 | HP LaserJet 3050 All-In-One Printer
Hp laserjet 3050 all in one
Ok fine the same prolem with 3050 . Is haviong the some manufating defect . check your usb cable, reinstall the new driver from the hp site. if the problem dose't fixs pls call the hp help for replacment
Thank you
Mar 02, 2008 | HP LaserJet 3050 All-In-One Printer
HP Laserjet 3050 won't print - os X
Power off printer, disconnect all leads such as USB, network, etc and power on again.
Does it power on to the normal state?
Are there any messages on the control panel or light patterns (eg off, on, flashing etc)?
Dec 30, 2007 | HP LaserJet 3050 All-In-One Printer
Drivers instalation
Hp Laserjet 3050 Drivers for 3050 Series Printer Download
Easy come
Oct 05, 2007 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
147 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
