Question about Brother MFC-8440 All-In-One Laser Printer
Parts Search I am looking to just purchase the hinge for the top. It is the spring loaded hinge. larger looking of the two. Can you please refer me the best practice for purchasing parts for this unit. I am in the Atlanta are.
  • Brother Master
  • 1,113 Answers
Re: Parts Search
You can purchase the hinge to suit from HERE $25
Posted on Dec 16, 2007
0 characters
3 Points
Left hinge broke on lexmark pro 905
Not a perfect fix, but this is what I did: There are 2 spring-loaded pistons located on the printer side of the hinge that cause this problem. I think there should be another piece of plastic that holds the top of the printer hinge down on these springs, but when this hinge is gone, the top of the printer is held upward by them. If you use some pliers to gently pull these spring-loaded pistons upward, you can easily pull them out, followed by the springs they cover. Once removing these, the top of the printer lies flat. The top is still unstable, but mine will now feed paper just fine and closes. Hope this helps! WebRepOverall ratingThis site has no rating(not enough votes)
Oct 23, 2012 | Lexmark Platinum Pro905 multifunction...
Lexmark pinnacle pro adf cover hinge won't close
Go to this link on You Tube and watch the revised video. It will correct the problem for you.
Jun 03, 2012 | Lexmark Pinnacle Pro901 All-in-one Inkjet...
Hinge Replacement, Thule Thule Atlantis 688T 2100 Cargo Cariier
Hi Erroll,
What I believe you're referring to is the 'locking hook' -- the piece attached to the lid that slides into the lock mounted on the bottom segment of the cargo box. While it acts like a hinge in respect of the closed side of the Thule, what the mfg refers to as the hinge (or also referred to as a strut) is the spring mechanism at the front and back used to hold the lid up.
You can acquire this locking hooks online - attached a link for your convenience.
Good luck.
THULE ATLANTIS 200 from Exeter Roofracks Roofboxes
Apr 28, 2012 | Printers & Copiers
Broken hinge where do i find areplacement lexmark x7675
You can download the Manual to dis-assemble the Printer and purchase Parts for your Printer fro the below link:
Please let me know if I was Helpful...
Mar 05, 2011 | Printers & Copiers
Mess. saying cover open i cant seem to close the top down. the top cover seem to be off track or broken
I have a Lexmark X6570 All In One Wi-Fi model. Just had the problem where I went to print and received an error message saying that the cover was open (when it wasn't). I noticed that the back right hand corner had slightly popped out of place for no apparent reason. Tried to pus it back into place with no luck.
Here's what happened and how to fix it:
There are two plastic hinges at the back of the 6500 series printers that allow the top cover to open for access to the ink cartridge carriage. The lower ends of the hinges are cylindrical shaped and each contains a very stiff steel spring inside. They are designed to prop the cover of the printer up and hold it open when opened. As the plastic material ages, it may weaken and the tension of the internal spring may break the round end of the hinge off. This causes the printer cover to not fully close (even though it may appear so). There is a switch in the main printer body that detects when the top cover it open (even partially), and the printer won't work in this condition.
To fix this, open the top cover and carefully disconnect the 3 wire harnesses and the ribbon cable that run from the top cover to the base of the printer. Then remove the 'paper jam' hatch cover from the back of the printer. There are two phillips screws on the back panel of the pinter (one is located behind the paper jam hatch cover). Remove these screws (they secure the plastic hinges in place). You should now be able to lift the complete top cover/ scanner table assembly off the rest of the printer. Look for a steel spring about 3 inches long...remove this along with the round base of the hinge which may have broken off and remained down inside the printer. Glue this piece back onto the end of the hinge, but leave the spring out. Now reassemble the printer in the reverse order of disassembly and you should be good to go. Note that the top cover or the printer will not stay propped open on it's own with the spring removed, but this is not really an issue.
I am not sure if new replacement hinges are readily available from Lexmark or other sources.
Feb 05, 2011 | Lexmark X6570 InkJet Printer
Need 2 cassette lift springs for kyocera ecos fs- 3900cys
Hello, the parts you are looking for is called the Spring Bottom Part Number 302F809010.
They may be hard to come by, A Kyocera Printer Dealer may be able to purchase them from the Kyocera Parts Dept. Use this link to find a dealer within the USA I hope this helps and good luck with your parts search.
Jan 14, 2011 | Kyocera Printers & Copiers
Brother MFC-8840d ADF feed problem
Hi, the left hinge is spring loaded to keep the lid open. This applies a lot of pressure on the pivot point of the hinge (steel pin/plastic hinge) that elongates the plastic holes and raises the lid from the scanner. As the paper leaves the scan window, a ramp next to the scan window sends the paper up to the tray, just past that ramp under the lid is a lip that guides the paper to the tray. With the hinge stretched, the lip is too high and catches the end of the paper at the rear only, and jams the paper. If you press on the cover (with the new hinge) and it does not catch then you have installed a bad hinge. Also ensure that the top part of the hinge is on the guide pins under the cover.
Jul 29, 2009 | Brother MFC-8840D All-In-One Laser Printer
Parts for Brother MFC 8200D
Yes, I had the same problem in Sept 2006 - a broken left hinge that needed fixing. Ordering the part was easy. I was able to install it myself, but it required some attention to detail.
I called Brother International at 800-284-4357, Option 1, then 2. I ordered the left hinge - Part No: LP-2403001 - described as ADF Hinge Assembly (left). If you broke the right hinge, the part number may differ slightly, but person on phone should be able to assist. It cost me $11.55 including shipping.
Feb 28, 2008 | Brother MFC 8820D All-In-One Laser Printer
Brother MFC-8440 Doc. Cover Open Error Message
I had the same problem, found your site and all of your suggestions. I ordered the same left hinge assembly from Vance Baldwin Electronics
Part #LP2403001 for $11.03, shipping from FL to OK was $9.23 UPS, so less than $20 and my MFC-8440 is working again! I did have difficulty placing the screws without a second pair of hands so have someone help you hold the lid. Make sure you removed the set ***** from at least the back of the left hinge assembly so that you can remove the "case" that holds the springs and sticky white parts. (Yes, I am a girl) :-). My husband will be so suprised when he gets home and sees that it works now because it was on his honey do list this weekend. Also, make sure that you replace the set screws and clean the scanner appropriately before use. I really like this site, it saved me a lot of money this time. Take Care!
Aug 22, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-8440 All-In-One Laser Printer Logo
57 people viewed this question
Top Brother Printers & Copiers Experts
Jim Yeh
Level 1 Expert
Jesus  Colon
Jesus Colon
Level 1 Expert
Rick Johnson
Rick Johnson
Are you a Brother Printer and Copier Expert? Answer questions, earn points and help others
