Question about Creative Labs ZEN SLEEK MP3 Player
Stuck on "re-building library"
When switch on the player goes through the Zen sleek screen and then freezes on "re-building library". I can hear the hard drive running but nothing else happens. I have tried re-setting but it just goes through to the same screen and then freezes and you can't turn it off, you have to leave until the battery runs flat.
  • 1 more comment
  • Anonymous Nov 10, 2007
    same thing
  • Anonymous Nov 17, 2007
    my player is stuck in rebuilding library and the computer does not recognize it.
  • patriotsfan Jan 15, 2008
    my zen will start up then go right to the re-building screen..and its really loud and it takes forever...then it goes to the main screen and says to select music from my library and over half of my music disapered...and when i do select a song it will play it but not show any information about the song...and when i hook it up to my computer it says its docked but my computer doesnt read it...what do i do???
    President:
  • 4,402 Answers
I decided to open it up to check out the hard drive to see what kind I would need so I could try replacing it. The data plug that attaches to the hard drive itself was partially unplugged. So, I pushed it back in all the way, put it all back together again, and turned it on just to see if something different might happen. (I had it set in my mind that the hard drive failed and I would need a new one, so I didn't expect anything different to happen) And to my surprise, it worked just like new again.
Before you go off and invest in a new hard drive, I suggest opening it up and make sure that plug is in all the way. Since you'll be opening it up in any case, it wouldn't hurt.
Posted on Jan 15, 2008
Water Damage, screen freezes, reset means rebuilding library.
http://www.fixya.com/support/r3771170-phone_water_damage
Sep 11, 2009 | Creative Labs ZEN SLEEK MP3 Player
Sync problem
My Zen sleek can't connect the computer
Aug 22, 2008 | Creative Labs ZEN SLEEK MP3 Player
Frozen screen
My screen freezes when i try to play a song and reset will not work
Aug 06, 2008 | Creative Labs ZEN SLEEK MP3 Player
Why zen sleek photo won't download music
i have a zen sleek and every time i turn it on it says rebuilding library. It completes this but deletes the last album etc that i put onto it. back down to the last album i put on before it started doign it. So i cant put anymore mousic on becuase it deletes it..Any Help?
Apr 17, 2008 | Creative Labs Zen Sleek Photo MP3 Player
Sleek Photo not rebuilding library
Read your manual or go to: http://support.creative.com/Products/Products.aspx?catid=213&catName=MP3+Players
Mar 31, 2008 | Creative Labs ZEN SLEEK MP3 Player
Does not work
I have the sleek photo and mine bugged out. It would go to the splash screen and then go blank and just sit there. Nothing would respond. I tried reset, reboot and other things too. My pc also would not recognize the player. To make a long story short, I tried other suggestions I found on the web. They didn't work and my player would now only go to a garbled splash screen and go right to the recovery screen.
I had the new firmware, but I couldn't use it because the pc wouldn't detect the goofy player. Then I ran across a site that mentioned that Windows Media Player can cause player recognition problems. I removed both WMP (mine was 11) and WMP runtime using the add/remove programs option on the control panel. I restarted the pc and BAM! the player was now recognized. I ran the new firmware application and the player works fine now. The key for me was getting rid of WMP and the WMP runtime.
Feb 10, 2008 | Creative Labs ZEN SLEEK MP3 Player
Zen frozen on one screen even after I've restarted it.
hard drive sounds bad. has it been dropped?
try to do a cleanup
  1. Detach the Zen player from your PC , and ensure that the Zen Sleek is turned off.
2. Connect the power supply to the player.
3. Hold down the Play/Pause button while inserting a paper clip into the Reset hole
underneath your player, beside the data/power connector. Keep on holding the
Play/Pause button while you release the Reset button. The Rescue Mode screen will
then appear.
4. After the recovery mode has started, release the Play/Pause button
It will display the following options.
Clean Up Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All) Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
Dec 04, 2007 | Creative Labs ZEN SLEEK MP3 Player
Freezes, reset button does not work
****, no solutions? I just had this same problem start happening.
Jun 01, 2007 | Creative Labs ZEN SLEEK MP3 Player
It Freezes Before It Goes To The Menu
This is important; because, if you cannot get into Recovery Mode, then this is a sure sign of a bricked player. You could try a forced hard reset by going in and disconnecting the battery, but chances are, the player is bricked.
try updating the firmware.
Oct 28, 2006 | Creative Labs ZEN SLEEK MP3 Player
Creative Labs ZEN SLEEK MP3 Player Logo
49 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
