Question about Delta SA350K Shopmaster Boss 1/4 Horsepower 1,724 Rpm Benchtop Spindle Sander With Complete Spindle Sander Set
Changing the sanding pads
How do you change the sanding pads
  • 864 Answers
You use a 1/2 inch socket wrench to remove the nut at the top of the spindle shaft, slide the old sanding sleeve off and the new one on.  Replace the nut.  You may also have to insert a different size table insert if you are changing the sleeve size.
Instruction manual is available free at: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Delta/a20932,sa350k.pdf
Posted on May 30, 2009
On my e500 mercedes the brakes are making noise not right away but when I am almost stopped, I did change the rotors and pads?
Did it make the noise and THEN you changed the pads? Or did you change the pads and then it started making the noise?
If it started after changing the pads, try sanding the pad surfaces lightly with sandpaper. If they are too smooth, it will cause a squeak.
Mar 08, 2015 | Mercedes-Benz E-Class Cars & Trucks
How to change sanding pad
Here is a link to the manual to your Royobi p400. You can download it. Tried to copy & paste the illustrations but they did not show up. Go to page 14 of the manual. Looks pretty easy, just peel down from top. Good luck. & happy Sanding.
CHANGING SANDING SHEETS AND PADS
HOOK-AND-LOOP
See Figure 8.
PAD
The sander is packed with sanding sheets and scrubbing
pads designed for a variety of uses. To change sheets and
SANDING
pads, simply pull the used sheet off the base and attach the
SHEET
desired sheet by pressing the sheet or pad onto the base
of the sander.
ROTATING THE SANDING SHEETS
See Figure 9.
The majority of wear in a precision sanding application occurs
at the tip of the sanding sheet. The unique Tri-Flex design of
the sanding sheets allows you to detach and rotate the top
two thirds of each and extend the life of the sheet.
To rotate the top of the sheet, simply remove the top two
thirds along the perforation. Rotate the sheet so that a clean
corner is located at the tip of the base. Press the sheet firmly
onto the pad.
NOTE: Scrubbing and polishing pads are not perforated
and cannot be rotated.
Apr 24, 2014 | Ryobi P400 18 Volt Corner Cat S
How to Change pad on green Stayer RO 150 orbital
Slim 17mm spanner between dust skirt and backing pad ( might need to jiggle pad about to get spanner to lock shaft ) then simply unscrew pad
Jan 26, 2013 | Festool Ro 150 Random Orbit Sander...
How do i change the sanding pad Ingersoll Rand Ingersollrand Dual Action Air Sander - 6
It simply unscrews. The pad is held on by a small bolt length attached to the pad. Unscrew it.
Jan 15, 2012 | Ingersoll Rand Ingersollrand Dual Action...
I just changed front and rear rotors and pads on my 2004 hyundai santa fe. i am getting a squeky noise when i make hard right or left turns. i am looking for some possible solutions. thanks.
Sounds like a missing brake spacers and brake pad clips when you installed the new ones.
Check again the brake pads and make sure you have sand down the rotors w/ 220 grit sand paper.
Hope that helps you out.
Thanks for asking FixYa!
Aug 06, 2011 | 2004 Hyundai Santa Fe
Hi can I use my Dewalt polisher and change to sandpapper if so what parts will i need for instance glue new flexable pad sticky 220 papper can you please elaberate a little what in going to need thanx ...
I'm not sure I understand your question, but I'll give it a go.
The DW421 is a sander already. If you want to change it to a polisher, you can buy polishing pads to go on it.
If you have a Dewalt polisher and want to convert to a sander, you can buy sanding disks to fit your polisher. They are installed on the spindle and I believe you can get a backing pad for it also.
Hope that helps
Mar 19, 2011 | Dewalt DW421 5'' orbital sander
Sand paper pad no longer holds the sanding disk
If pad is hook and loop style use compressed air or clean nylon brush to clean debris from hooks.If using adhesive backed dics try wiping a little alcohol across the pad surface to clean it.
Jan 09, 2010 | Dewalt DW421 5'' orbital sander
Back wheel tight after changing brake pads,
adjustment needs to be backed of to the maximum,and if still draging sand the shoes
Oct 25, 2009 | 2007 Pontiac G8 Sedan
My rear brake squeaks after you drive the bike for about 30 minutes and only when you slow way down coming to a stop. I have had the pads changed at my dealer. I think it needs a new rotor.
Most of the time when this happens, it's because the owner is using that S-100 spray on their black painted calipers. Any type of wax like that gets on your rotor or pads, they will squeal. You may be able to stop it by removing your brake pads and lightly sanding them. Put a sheet of sand paper on a flat surface, place the pad on it face down, and lightly sand the face of the pads. Next, get yourself a can of "BrakeKleen" and clean your rotor thoroughly. Make sure all your hardware for you brake pads is in good shape, the little metal clips that go in the caliper to hold the pads and such.
Sep 21, 2009 | 2008 Harley Davidson FLHX Street Glide
Changing the rubber pad on the Bosch PEX 12 AE
I'm not familiar with that particular model, but they are virtually all replaced the same way. There are a few screws through the pad into the base. Simply remove them and screw the new pad on. You'll see that it's quite simple once you get the new pad in your hands.
Just be careful not to strip the head of the screw: use the right size screwdriver tip.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Feb 01, 2009 | Bosch Power Tools Sanders Orbital Sanders
Delta SA350K Shopmaster Boss 1/4 Horsepower 1,724 Rpm Benchtop Spindle Sander With Complete Spindle Sander Set Logo
198 people viewed this question
Top Delta Tools & Hardware - Others Experts
Andrew Taylor
Andrew Taylor
John Trevino
Are you a Delta Tool and Hardware - Other Expert? Answer questions, earn points and help others
