I have a dell e172fp 17 inch, it keeps blinking green light on the power button. the monitor blinks white once in a while. when i press the power button hard, it shows the screen once.
I have a dell e172fp 17 inch, it keeps blinking green light on the power button. the monitor blinks white once in a while. when i press the power button hard, it shows the screen once in a whileI have a dell e172fp 17 inch, it keeps blinking green light on the
The desk top picture appears for a second then goes black and the power button keeps blinking. It worked fine yesterday.The desk top picture appears for a second then goes black and the power button keeps blinking. It worked fine yesterday.
My flat panel screen does the same. The green power button blinks and the screen is black. In order to shut off screen I have to hold the blinking green power button for a couple of seconds then it shuts off. When I press to turn on I get the image of whatever is on the screen then it goes black and the power light starts to blink again. If anyone has a solution please let me know. My flat panel screen does the same. The green power button blinks and the screen is black. In order to shut off screen I have to hold the blinking green power button for a couple of seconds then it shuts off. When I press to turn on I get the image of whatever is on the screen then it goes black and the power light starts to blink again. If anyone has a solution please let me know.
AnonymousOct 28, 2008
I have the identical problem. Dell monitor E172FP goes blank (black) and button flashes green.
I have the same monitor and problem --has anyone successfully fixed it and what was it. Thanks RJI have the same monitor and problem --has anyone successfully fixed it and what was it. Thanks RJ
AnonymousMar 12, 2014
Blinking green light when I push power button on LT 565 computer monitorBlinking green light when I push power button on LT 565 computer monitor
Blinking green light when I push power button on 2002 mag LT 565 computer monitorBlinking green light when I push power button on 2002 mag LT 565 computer monitor
You can't post conmments that contain an email address.
yumaparkie, You mean to tell me you haven't been to YOUTUBE to see all the video clips of Dell E172FP, E173FP lcd monitors being repaired?? Do that first, then come back here if you still need help.
12fixlouie
Disconnect the display from the Computer and remove its power plug. While the display is turned off, press and hold the power button for 30 seconds. After two minutes connect the power cord and the display cord to the Computer and the power source and turn it ON.
If the power indicator on the display keeps blinking, then it's required to open it up to repair it.
You need to open the monitor and check to se eif any of the capacitors
on the power board are bad. Common problem for LCD monitors. The bad
caps usually vent at the top (they will look bad compaired to a good
capacitor).
If they look bad then they will need to be replaced. I've seen this in
Dell monitors, so there's a good chance this will fix the monitor.
Take it apart, get the values on the sides of the bad caps in the power
supply pcb. Buy new caps, and de-solder the old ones and replace them
with the new ones. Don't forget to trim the leads afterwords.
I buy and sell these monitors (Dell E17FP) the problem is with the transisters (Q739, Q740, Q759, Q760) they short out and the monitor will just blink on and off. You have to desolder them and test them with a simple battery and light circuit. The reason they blow is because of the dirty solder joints by the transformers. If only on pair of backlights work the problem maybe transisters Q751, Q743. I home this answers your questions.
Try these, changed them and sloved my problem.
http://cgi.ebay.co.uk/KIT-4-PCS-2SC5707-...
