Question about Electric Rc Airplane 12v Fuel Pump W Nozzle & Clunk
Fuel pump out in my 2003 olds alero
I was rear ended and my car dont start afterward they asy its the fuel pump did the accident cause this cause it ran fine till then
  • shnookybubs May 30, 2009
    so do insurances pay fort that
  • 864 Answers
Electric fuel pumps are located in the gas tank or under the trunk near the rear.   The accident Could have damaged it or the wiring to it.
Posted on May 30, 2009
  • 74 Answers
Hi there mave a look in your ownes manual for a fule cut off switch it needs reseting its ment to cut the fule pump out when you have a bump you will only need to press the button on it the pump should start again
regards JR
  • John Gwilliam May 30, 2009
    its just a button to be pushed does it need the insurance to do it could take 5 minutes to find and push it then you can use the motor
2003 olds alero 2.2 will not start
Try banging on your gas tank if it starts then you can almost be positive it's a fuel pump
Jul 17, 2012 | 2003 Oldsmobile Alero
My 2003 cavalier was rear ended yesterday. It started the first couple of times then it started, stalled, then started. I drove it ten miles. Turned it off and now it turns over but won't start. Any...
Alot of times after an accident fuses and bulbs start to blow. Impact issues. Slim possibility of the fuel pump 'kill' switch which shuts electricity off to pump in the event of an accident.
Dec 18, 2010 | Chevrolet Cavalier Cars & Trucks
Shutting down
Try replacing the air filter.
Dec 21, 2009 | 2003 Oldsmobile Alero
I was rear ended hard and five miles down the road my car shut off the auto shop says its the fuel pump. Can the fuel pump be damaged cause of the accident it worked fine till then?
think you have knocked out the safety switch and it needs resetting to start vehicle,Dont know where this is on this vehicle though but it could be in the boot or under the bonnet but some vehicles have them behind the centre pillar cover or in the front footwell,it should be a smallish square thing with a red rubber cover ,just push the rubber cover down and it should click back on
May 30, 2009 | 2002 Oldsmobile Alero
2003 OLDS ALERO WONT START
find the buzzing noise...likely its the fuel pump relay.
May 28, 2009 | 2003 Oldsmobile Alero
Fuel pump relay
GM relays don't reset. My guess would be the electric fuel is not operating, For openers , I would start with the FUSE for the fuel pump. In a fuse panel UNDER THE HOOD. Should be marked. Probably a 30-40A maxi fuse. CHECK WITH A 12 VOLT TEST LIGHT. If that area passes all the tests, I would check for power to the fuel pump ( with the ign key on. 12 volt test light will go ON then OFF ) Could be a faulty fuel pump, Hope this helps
May 07, 2009 | 2003 Oldsmobile Alero
2003 Cavalier, fuel problem after accident
there is no fuel pump cut off switch on this car, it is possible the fuel pump module was damaged from this accident, u will have to have the fuel pump circuit tested for faults before replacing the pump, don't guess, this is an expensive repair
Mar 09, 2009 | 2003 Chevrolet Cavalier
2003 oldsmobile alero fuel pump
relieve fuel pressure (pull fuel pump fuse run car until it quits,) siphon fuel from tank, drop tank, remove wires and hoses,fuel pump is in tank, to remove, use snap ring pliers to remove pump retaining ring, pull up on pump, be carefull not to damage screen or sending unit in tank when pulling out.
Oct 23, 2008 | 2003 Oldsmobile Alero
Electric Rc Airplane 12v  Fuel Pump W Nozzle & Clunk Logo
148 people viewed this question
Top Electric Toys Experts
Robert A. Watson
Robert A. Watson
Tom Chichester
 Russ Hill
Russ Hill
Are you an Electric Toy Expert? Answer questions, earn points and help others
