Question about GE GSS25JEMWW Side by Side
The freezer is working fine but the fridge side is about 60 degrees no matter what the temp setting. I have removed the plastic cover on the back of the fridge (where the "tunnel" between the fridge and freezer is and there is no air flow between the two units (with the freezer door closed). The fan in the back of the freezer is running just fine but I am not getting a "wind" from the freezer side into the fridge. I think if I can solve why there is no airflow between the two sides, I'll have my problem solved. Have I perhaps removed a plastic baffle or something that redirects the air? Is the fan at the back of the freezer supposed to blow or **** (relative to standing in front of the unit? Thanks
  • len_morgan May 30, 2009
    Thanks for the quick reply. The first problem I've got is that the model is wrong. I was searching for my model but this one came up and I couldn't change it.
    The actual model is TFX22PME (also GE). Also, in your symptoms summary, you typed "freezer NOT working." This is not true. The freezer is working just fine. The fan that is behind the icemaker is turning fine but I don't feel any air moving. I can feel good air movement on the right hand side of the fan (when looking from the front of the unit) which I would think should translate into a nice cool breeze blowing through the hole between the freezer and fridge. This is NOT happening. I can't feel anything moving from one side to the other even with the styrofoam gasket piece removed from the back of the fridge.
    Do the comments you mentioned in your first answer still apply? Does the icemaker cable come from all the way in the bottom of the freezer?
  • 3,741 Answers
Check out the air dampner between freezer and refrigerator section.if that is blocking the air beteen this two this has to be replaced.
Start out with the easy stuff first...make sure the lights go out when you close the door(s), make sure the doors are closing properly and the gaskets are closing fully and not torn. Check to make sure the evaporator fan in the freezer is working, this fan blows the cold air around. If the fan is not working, possible bad fan motor - check for power to the fan motor and also check the fan switches around the door openings, ( if your fridge has these switches, not all do ). A common problem cropping up in the last several years has been the air damper not opening up and allowing the cold air from the freezer to be blown into the fresh food section For many years the air damper was manually operated and now we have motorized controlled or temperature controlled or thermister and electronic boards controlling air dampers, and if this device sticks closed the FF section will normally warm up. An example picture of "one" style and an air damper ( called a diffuser by Whirlpool ). Next would be to check the condenser tubing, a good place to start is to make sure the condenser coils are not built up with dust!! Make sure the condenser fan motor is also working properly. Check for any "clicking on and off" noises from the compressor, is the compressor running.
you can get the required parts at
www.repairclinic.com
thank you for using fixya.please do rate the solution.keep updated.thanks.
Posted on May 30, 2009
    Brigadier General:
  • 3,917 Answers
Its the fan or the motor.
Symptoms: fresh chamber just cool, freezer not freezing, no normal whirrr sound or air-blast inside, but a drop of frost in the center-top of the fresh compartment. It makes cold, but isn't moving it to food.
GE model # GSS25JEMWW
Open freezer. Clear it out.
Two plastic buttons in front lip of freezer floor, pry out.
Two phillips screws, remove.
UN-plug the refrigerator !!!!
Slide freezer floor forward about 4 inches.
The icemaker wires will stop you. Reach back and lift their cover.
Slide freezer floor forward another 6 inches.
Fan is in center rear under floor level.
Plug in the refrigerator.
If there is no air-blow, gently feel fan.
(If fan is stalled, it won't cut your finger,
but if fan is up to speed and blowing, it will hurt!)
If it "wants to turn", but hits something:
- put your fingers behind both sides of fan blades,
- pry fan forward about 1/4"
- it should turn and blow
- if that makes it worse, try sliding fan rearward.
Slide freezer floor back, guiding the icemaker wires and cover
Re-screw and button-up.
I'm thinking the fan.
As you say, it gets cooler, or not, when you adjust the control, so the thermostat works and it is making cold freon.
However this model, like most frost-free, use an air fan to move cold air from an internal cold-coil to the frozen and fresh compartments. When this fan (and motor) quits, the coil is cold but that cold air only dribbles into the fresh compartment, and your icecream is soup.
If you have to ask, you probably don't want to replace the fan motor yourself. Anyway it looks like it is $75 just for the motor!!!! (Part Advantage price; you might check GE and Sears.) Add whatever for the cost of a service call, you are well on your way to a new small icebox.
Thank You
Igloo refrigerator's freezer: -16 deg. Fridge: 60 deg. No evap fan & duct from freezer to fridge. Cond coil clean. Discharge line warm. T/STAT@coldest temp. Fridge gasket seals. Condensate drain clear
freezer is working fine, refrigerator won't go above 60 degrees.
www.shopyourway.com > Manage My Life > Questions
Freezer is working fine but fridge won't go about 60 degrees. Cleaned out pass through from freezer to fridge, clean vents, and cleaned coils. All to no avail.Missing: gloo
Beckly Powerful Suction Cup Handle No Tools Necessary!
www.amazon.com > ... > Bathtub Appliques
Amazon.com, Inc.
Rating: 3.6 - ‎85 reviews
Just Turn 60 Degrees and place on any Flat Smooth surface. For Bath Safety and Cabinet Doors Also Fridge Accessory. Beautiful ... No tools, no glue! No need ...
[PDF]Operate Refrigerator In Room Warmer Than 60°F
Jan 03, 2016 | Refrigerators
Why won't my refrigerator and freezer stay below 50 degrees?
Barbara, does it stay at 50 degrees even if you set it lower? I have a similar problem but temps. look ok.
Jul 30, 2014 | Maytag Refrigerators
True T-49 refrigerator/freezer temperature calibration
Contact the manufacture, it is most likely going to be covered under warranty. If the knob is not removable, (check for a set screw on the side of the knob it will take a small allen wrench) Then the thermostat (temp controller) will need to be replaced, if it isn't a style that you can calibrate.
Jan 30, 2014 | True Refrigeration True T-49 2 Door Bottom...
Fridge won't cool below 60, freezer won't go above 20
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 08, 2011 | Refrigerators
Warm refrigerator compartment
There is a fan that blows the cold air down from the freezer to the fridge compartment. It is usually called a freezer fan. Most of them are behind the plastic lining in the freezer. I just noticed that your fridge is a side by side. I have never wored on a side by side but I imagine there is fan in them as well.
Jul 06, 2009 | GE GSH25KGRWW Side by Side Refrigerator
Freezer works but refrig has 60 degree temp .evap coil is caked
Hi: Did you check the defrost heater itself? I checked Jennair and Sears parts to no avail. If you didn't check the heater it will be at the bottom of the freezer behind where you removed the back cover. A glass tube with a coil in it. If the coil or tube is broken replace that insead. I hope I helped, Jeff I found a website with the defrost timer, but not the location of the timer on the fridge. http://www.appliancepartsworldwide.com/store_SearchResults.aspx?S=1131392&ST=PBM
May 31, 2009 | Jenn-Air JCD2389G Side by Side...
Internal temp of fridge and freezer are different from bottom top
Hi, Is the evaporator fan motor running in the freezer? Was the fridge setting any length of time unplugged before you got it?
May 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung rs2533sw fridge not cooling
it sounds like the refrigerator evap is frozen up causing the compartment to get too hot. shut the unit off and let it thaw out. then take the screws out of the cover to check the stryrofoam on the back side of the cover to see if theres broken spots on it causing the air to bypass the evap causing it to freeze. Theres two screws behind the light cover and two at the very bottom of the cover and two behind the decorative plugs about 1/2 way
Dec 20, 2008 | Samsung RS2534 Side by Side Refrigerator
Whirlpool side by side refrigerator not cooling
Hello danielscynt,
Welcome to Fixya,
You said, freezer is fine the refrigerator is 50-65 does not get colder than 50.the evaporator fan is working but it seems to be blowing very little air
Have a 1998 Hotpoint Model # CTX16CAZDRAD Serial # ZS738209. The refrigerator is not cooling. Temp is at 66 degrees with setting at 5. The Freezer is working, but it seems to be running all the time. Please help!
There are a few things that come to mind!
The Freezer is working, but it seems to be running all the time, you said!.
This could be a bad thermostat!
But lets try some simple maintenance first!
Is your freezer packed too the hilt with packages???????
Where the articles cover the air vents in the freezer?
The freezer and the fridge share the cold air and the passages must not be blocking the cold air from moving out of the freezer!.Search your freezer !
Also your fridge is 10 years old!
Did you ever remove the plastic grille at the bottom of the fridge along the front, and GENTLY run a refrigerator brush along the black metal tubes running back and forth under the fridge?
( You can buy this brush at any hardware store $10.)
They must not be covered in ten years of lint and dust. These narrow tubes carry the freon and run in this parallel fashion back and forth, so they are cooled by the air being **** through them.
if not and they overheat your fridge will get warm.
If the tubes are found to be covered or submerged in dust sometimes I have found them one to two inches thick in dust, and sometimes they are even not visible until you clean the dust out.
Then it will take 10 to 24 hours for the system to get back to full working temperature again. As long as the heat did not cause permanent damage!
if these are not the answer, then you may need a hands on diagnoses!
BUT, most of the time these two things are what I find!
Let me know how it goes!!!!!!!!
Thank You for asking my advice!
Huuum
Please remember to leave a rating for me!
Oct 08, 2008 | GE Hotpoint Top-Freezer Refrigerator
Burnt smell inside freezer.
Generally speaking it is the refrigerator control that controls the compressor operation. Refrigerator is cooled by air from the freezer. When the refrigerator gets down to its designed temperature it shuts off the compressor. The freezer control determines how much air is allowed to flow into the refrigerator section and there-by controls the freezer temperature.
Mar 18, 2008 | Frigidaire FRS26ZSG
GE GSS25JEMWW Side by Side Logo
75 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
