Question about Refrigerators
Making a loud moaning noise
My refrigerator is making a loud moaning noise
  • 159 Answers
Remove from supply for 30 min
Posted on May 30, 2009
Why does my GE Arctica Side by Side refrigerator make groaning noise?
All new refrigeratos make some sort of groaning noise and this noise is heared at diffrent times of the day. This noise you are hearing is what we call refrigerant noise. As the liquid frigerant is moved through the system it gets to a point were it will enter the capillary tube at this point the frigerant flashes in to a gas (changes from a liquid to a gas) when this happens it tends to make moaning and groaning noises. There is no real fix for this noise.
May 02, 2012 | GE Refrigerators
GE SIDE BY SIDE ICE AND WATER. FRIG MAKES A LOUD MOANING SOUND . EVERYTHING WORKS OK, EXCEPT FOR THE NOISE.
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 27, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
My GE Fridge PSS26SGRD has a moaning howling
The fan is hitting on ice buildup...unit is not defrosting...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Our GE fridge makes a loud moaning noise
possible condenser fan ...remove rear cover to expose condensing unit and verify fan/compressor operation.
Jul 14, 2009 | GE Refrigerators
Moaning noise when I turn left or right in my 2002 VW Passat
Your power steering pump has gone bad. Consider replacing it. I had the same problem before.
It moans when u turn at a stand still but rolls freely when in motion?
Rate this fixya
Mar 24, 2009 | 2002 Volkswagen Passat
Our fridge/freezer is making a moaning sound. we
if the timer is making clock sound is the timer may be you have a fan making noise
Mar 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Moaning noise in steering column
The probably lubed the intermediat shaft conenction. The loud poping noise could be from them not sitting the boot back correctly. Inspect your boot. As for the moaning noise Only thing I can think of is a hydraulic noise.
Dec 11, 2008 | 2007 Saturn Outlook
Condensor sounds like it moans for a couple of seconds instead
Hello aeruslady1,
Do you mean the compressor? I'm sure you do. The condenser is the hot refrigerant line that comes off of the compressor.
It just sounds like you have an old compressor. I have seen them make noises for years before they take a dump. If it continues to run loud even after it starts however, then you may need to clean the condenser coil or replace the condenser fan motor. Another thing that might make it run loud is some refrigerant lines may be rubbing against something. This can be remedied by bending the lines.
Hopefully this helps.
Sincerely,
shays5415
Dec 03, 2008 | Refrigerators
Hotpoint side by side has recently bugun making a lot of noise
Check for frost in the freezer compartment that may suggest a defrost problem which would cause it to run for extended times and make more noise. The other possibility is that if the fan is making a up and down type of noise, it will need a new fan in the freezer section due to a faulty bearing in the motor.
Oct 23, 2008 | Hotpoint (HSM25IFTSA) Side by Side...
Fridge makes loud moaning sound
It is the control board. There is a recall on certain models and serial #'s that will cover the parts, but not all are covered. do a google search for hotpoint or GE howling noise. you will find out all the info you need.
Mar 14, 2008 | Refrigerators
Refrigerators Logo
940 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
