Question about Frigidaire GSTF1670A Front Load Washer
WASHER WONT DRAIN
Frigidare front load washer wont drain. GSTF1670AS. Washed a couple of blankets...think the dog hair clogged the drain or pump. How do i access this to fix.
  • 56 Answers
Take off the lower panel ( 2 screws on bottom) pullout and down to remove. Make sure unit is unplugged pump is on the right hand side one hose coming from bottom of tub and the other goes out the back to the drain. Take off the hose from the bottom of the tub and be ready to catch alll the water in the tub suggest you use shop vac and remove all water first. look in the impellar in pump should be a clog right there then put everything back the way you toook it off and be careful to get the hose back on the way you took it off there is a slot in the hose and a tab on the pump for alignment.
Posted on May 30, 2009
Wont spin or drain
Does the machine agitate if so this eliminates the motor coupling could be a bad timer place unit in spin if motor hums then power going to motor eliminates this check the drain pump it is white and attaches to the motor with 2 spring clips if there is something stuck in it or a bad bearing won't drain if a washer cannot drain it will not spin hope this helps.
Jan 19, 2014 | Amana NTW5400TQ Top Load Washer
My frigidare front loading washer wont do anything! The lights are on, but it won't start. There is water in the washer and it won't drain. HELP!!!
Sounds like a programmer fault , is it stuck , is it a geared one , ie can you turn it by hand to select next cycle. if so give it a gentle turn .. could be the pump clogged .
pete
Nov 17, 2010 | Frigidaire ATF6000ES Front Load Washer
Daughter washed a feather pillow which fell apart in front load frigidare washer now it wont spin and drain can u help plz?
The drain is plugged...
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 30, 2010 | Frigidaire ATF6000ES Front Load Washer
Not spinning water out of clothes
CHECK OUT THE DRAIN MOTOR PUMP , it cpould be clogged , located where the drain hose is connected inside , youre gonna see 2 hoses connected to thi small motor , hope it helps , AJ
Nov 16, 2009 | Frigidaire GLTR1670A Front Load Washer
It won't drain correctly and doesn't spinn. I think the inside drain is clogged with dog hairs.
sounds like the transmission drive has gone bad in unit it runs pump and spins drum
Jul 06, 2009 | GE WBVH6240F Front Load Washer
My whirlpool washer wont drain.
Check the following text to address this issue.
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 10, 2009 | Whirlpool Washing Machines
WONT DRAIN
clean the pump and also make sure that the pump motor is powered during draining
May 30, 2009 | Frigidaire GSTF1670A Front Load Washer
Front load washer won't drain
Possibly a blocked pump. Sounds about right if it has only happened after that item was washed.
Oct 30, 2008 | Washing Machines
Frigidaire GSTF1670A Front Load Washer Logo
164 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
