Question about Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE5 inoperable and F70 error code.
Unit is about 2 years old and has just failed to operate and is displaying "F70" error code. Tried leaving unplugged for extended period - no help, same problem.
  • ltbs2 May 30, 2009
    Thanks so much for the comment - I appreciate your help - service has been scheduled. Life is tough without a dryer!!!!
  • 6,784 Answers
HI, this error code represent a major control issue within the main control. simply replacing the main control will fix this issue. the logic chips are damaged.
Posted on May 30, 2009
  • tony santistevan Oct 08, 2011
    thanks, was going crazzyy, now I just need a service manual.
  • Michael Masters
    Michael Masters Oct 09, 2011
    Hello. If you would be so kind to provide a valid e mail address, i would be more than happy to provide a proper service guide to help with your DIY endeavors. i will send a service manual(PDF file) to your e mail box.
What does F70 flashing mean?
The F70 is an internal control problem. It can be caused by a failed central control board or an interface problem. The way to determine which part is bad when the error occurs is as follows:
  • If the error occurs when the machine is running then the problem is the interface.
  • If the error occurs when the washer is not running the problem is the central control unit.
Nov 23, 2010 | Kenmore HE5 Electric Dryer
I have a Kenmore Elite HE5 and it displayed the error code "F70". I unplugged the washer for 30 min and plugged it back in - and now it won't even turn on.
The F70 and F71 error codes on this model of washer indicates a communication problem between the user interface control board and the central control unit (main control board). These error codes can sometimes be caused by a power surge or glitch through the electrical lines. Try unplugging the washer to completely disconnect electrical power. Wait 1 minute and then plug the washer back in to the see if the fault code clears. If it does, then the washer may work normally.
If the code reappears, then you could have a wire harness connection problem, a failed user interface control board or a failed central control unit. I recommend calling a service technician to properly diagnose and repair this type of problem so that the correct component can be replaced.
Be sure your unit is plugged into a 3 prong grounded outlet as well.
F71 is a "heatbeat failure" which means that your front interface control board is shorted and will need to be replaced. it's actually fairly easy to replace and can definitely be done by yourself. To access the part, just pull the unit forward and remove the 3 screws coming in from the back of the top panel. Remove the top panel by pulling it back, up, and off. Then remove all the screws going into the top of the control panel. Remove the dispenser drawer and remove the screws coming in through the dispenser. Remove the screws coming from the inside of the dryer going forward into the control panel, then remove the control panel (it's just clipped in on the bottom. After that you can disconnect the wire harnesses to the front interface control board and replace that part.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 29, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore ELITE HE 5t 47086 frontload errror code F70
Feb 26, 2010 | Kenmore Elite 45986 Front Load Washer
My Dryer Kenmore Elite HE5 show the Code F70...
Dec 31, 2009 | Kenmore Elite HE4 Electric Dryer
What is the code F70? Kenmore Elite HE5 dryer
Nov 08, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore He5 dryer, a service code f22
just remember error codes are always going to be stored on every machine ,, shoukd not have a problem ,, but does it work
Nov 29, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE5 Electric Dryer
I have a Kenmore HE5 Steam: after a power failure last week, now when you turn the dryer on and push"start" the cycle stops emediately and flashes PF...
May 07, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite eletric dryer model 8708
I've never heard of an F70 I have heard of an F07 which is possibly a motor controller error.
Nov 28, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
1,181 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
