Question about Maytag MDG2600BWW Gas Dryer
Maytag gas dryer runs but does not heat
How do we know if it is a thermostat or igniter. When we first noticed the gas thhe clothes were cold. Now when we tried to see what was wrong there was no gas smell at all with dryer running
  • 864 Answers
If yo smelled gas then the ignitor may not be working.
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it)  It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off.  If the ignitor does not glow then the thermostat is bad.  If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced.   If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Posted on May 30, 2009
Hello I have a GE gas drtier nthat only heats on permanent press what should I check first? Dave
Posted on Dec 31, 2009
Why does it start to heat up, then goes cold and won't dry the the clothes?
Basic gas dryer failure elements are the igniter, the thermocouple, and the gas valve. Even a cracked igniter that appears sound can cause the problem you describe.
Mar 19, 2013 | Maytag Neptune MDG5500AW Gas Dryer
Maytag DG410 gas dryer-no flame, no heat. I replaced the ignitor - that apparently isn't the problem. Other ideas?
Motor runs, but main burner will not ignite
1.heat switch set wrong---correct switch setting
2.defective timer or timer circuit---check timer wiring--replace timer motor or switch as needed
3.defective centrifugal switch in motor---clean switch or replace as needed
4.gas supply valve closed----open gas valve
5.inoperative solenoid coil---test coil for open circuit & the voltage to it
Pilot burner goes out
1.insufficient gas supply---- low gas pressure or clogged pilot filter or partially closed gas valve
2.carbon deposit on thermocouple tube---clean tube & check pilot burner for proper combustion
3.improperly adjusted pilot flame--adjust pilot flame until faint yellow tip begins to appear
4.faulty ignition or reset valve or thermocouple---replace
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag PYG4500A Gas Dryer
Matag Gas Dryer not heating up
Check the glowbar igniter at the gas valve. When calling for heat(turned on and running) it should register 3 amps or more on a clamp on amp meter. If 120 volts of power is going to the glowbar and it does not glow,it is bad. All thermostats and relays should be checked for continuity. If any read 0 it is a bad part.
Nov 08, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer not releasing hot air
if its an all electric dryer then you may have an open heating coil or a bad contact on the timer that supplies power to the heating element .. a few dryers have a fuse that could be blown ..
if you have a gas dryer then you may have a bad solonoid that operates the gas valve .. or more likely a bad igniter .. thats a module that heats up or sparks to ignite the gas .. the igniter is a replacable item mounted near the gas flame. . the heated type fail frequently on some dryers ..
Aug 18, 2009 | Dryers
My Maytag Altanis Gas Dryer, does not heat for the whole cycle.
replace your gas valve. not opening up completely. check wires for good connection inside the male and female harness
Jun 22, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Gas Dryer doesn't heat up
The igniter is the part that ignites the gas in the Maytag gas dryer. Long time a go the dryers use to have a pilots. The pilots where on all the time, even when the dryer was not been use.
This wasted a lot of gas and a new design was needed. That is when the igniter or glow bar as is also known, came to be. A bad igniter could be the reason for your Maytag gas dryer not heating.
The radiant sensor is a small black box that attaches to the combustion funnel. The job of the radiant sensor is to allow the igniter to glow until it is real hot, then it shuts the igniter off and opens the gas valve to start the heating process. A bad radiant sensor could the the reason for your Maytag gas dryer not heating.
The gas valve has two coils or solenoids. These coils job is to open the gas chambers inside of the gas valve.
When one of the coils goes bad, the symptom is that the igniter glows, but the gas valve won't open to let the gas flow through the gas chamber to be ignited.
A bad set of coils could be the reason for your Maytag gas dryer not heating.
The hi-limit thermostat is located on top of the combustion funnel, and its job is to open the circuit to the gas valve if the airflow to the dryer is restricted for any reason.
The cycling thermostat is use to control the temperature inside of the dryer. It is factory preset at 155 degree, in other words it will open the circuit to the gas valve when the temperature reaches 155 degrees.
This thermostat is opening and closing all the time the dryer running. A bad cycling thermostat could be the reason for your Maytag gas dryer not heating.
The timer is the part that direct the electricity to the other parts in the dryer. This part works very hard and the contacts wear out and some times they burn out. If the timer contacts won't close, the dryer will not heat.
The motor switch is another safety device that only closes the heating circuit when the motor is running. When the motor is not running the circuit of the gas valve is open and the dryer will not heat. A bad motor switch could be the cause for your Maytag gas dryer not heating.
As you could see, there are a lot of parts inside of the dryer that have to be in good working condition for the dryer to produce heat.
May 27, 2009 | Maytag Dryers
Maytag Neptune MDG 5500 AWQ heats sporatically
your dryer has a safety feature that it will not run or heat when the door is opened. It is so no gas fumes are exhauseted into your home. Once the safety is engaged, It will not allow the dryer to restart for a short while. It should clear itself after only a few minutes. Hope this helps, good luck.
Apr 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
No hot air for dryer
this is most likeky thermostat you can find here http://www.partstap.com/
Feb 25, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer does not maintain heat and clothes smell
Check coils on burner assembly. Often when a dryer heats initially and then stops heating a coils has gone bad.
Nov 09, 2007 | Maytag MDG7600AW Gas Dryer
Maytag MDG2600BWW Gas Dryer Logo
931 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
