Question about LG WM-2277HW Front Load Washer
How to replace the bearings ?
I have WM2277HW that is just out of warranty and when it is spinning it now sounds like a jet airplane in your pocket.  Totally unimpressed with this "reliable new design".
Even spinning the tub slowly it now soundslike dry bearing so it would appear that one or both of the bearings are worn out. I can see how to remove the motor but lacking a service manual I don't clearly see how to extract the bearings.  Should I simply remove the screws from the mounting plate and use a puller to push against the drum shaft and pull the plate back to free the bearings?
Does anyone know where I can get a service manual?  LG does not seem to be very forthcoming with information other than saying to call their qualified service guys that are an hour away.
We had a similar problem on our WM2277HW about a year ago. I was sure it was bearings and LG covered a service call even though it was a few months out of warranty. It turned out that an "underwire" from one of my wife's bras had gotten lodged between the drum and something stationary. They removed it and it's been fine.
Posted on Mar 07, 2008
  • 58 Answers
Changing the bearing is a huge job. it requires taking the whole washer completly apart
Posted on Oct 31, 2007
Loud noise during spin cycle
Yes unfortunately. but it's not terribly difficult to do. There are many how-to videos online
Mar 16, 2015 | Maytag Bravos MTW6600T Top Load Washer
Spin cycle makes jet airplane takeoff noise. assume main bearing on spining tub is out. What part replaces this bearing? Diagrams do not mention bearing!
Bearings do exist but need a special puller to remove. If techs i n your area have it part numbers are 22002934 , 22003441 also needed is spacer 22002935 and seal kit 12002022 or else you need to order the whole outer basket
Jun 04, 2011 | Maytag Neptune MAH6500A Front Load Washer
Maytag Neptuen Washer makes loud noise when spinning. Sounds like an airplane taking off.
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle.Get the spin bearing and motor checked.Replace the faulty. You can get required parts from
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 30, 2010 | Maytag Neptune Washer
Sounds like a jet on spin cycle, I suspect rear bearing - how can we be sure ?
To decide on the bearing just listen to when you hear the noise. Is it when the unit is draining then its the drain pump. And if its making a bad noise that gets louder and louder as the drum spins till you cant hear yourself think your bearing has gone bad. Check your owners manual because unfortunatley the only way to replace the rear bearing is to replace the rear half of the tub. The bearing is mounted into the rear tub and cant be replaced otherwise. Sometimes the tub is covered for longer than the original 1 year warranty. Hope this helps.
Jan 31, 2010 | Frigidaire FWT449
I have a maytag neptune washer model# mah300aww.
Your tub seal leaked water into the tub bearings causing them to fail. Maytag only offers the bearings as part of the outer tub assembly and the repair can be pricey. A little research may turn up a service company in your area that has the tool to replace only the tub bearing. The repair becomes more affordable that way.
Jan 25, 2010 | Maytag Washing Machines
Washer is extremely loud
defective back bearing and spin basket..onthejob
Feb 03, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Most likely a failed "spinner" assy. The roaring that you hear is the bearing telling you it's had enough and has gone on strike.
MAJOR job! If it's over 5 years old, I recommend calling a professional and get quotes. Then decide what you want to do.
If it's less than 5 years old, it should be under warranty. Contact Sears. Tell them you have a failed spinner and tub bearing assy. and have them do the repair.
*Just a quick note. You should use only HE detergent in these machines.
Oct 28, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I have a maytag neptune super stack model: ML2000 when it spin drys the clothes it sounds like an jet airplane ready for take off.
it sounds like the main bearing in the back of the drum (under the big pulley). make sure you replace it and the water seal soon before the starts to damage the plastic tub.
Jun 27, 2008 | Washing Machines
Loud noise on spin cycle
How did that answer get an 83% rating? It is absolutely useless. My washer has the exact same problem as described above.During the spin cycle it sounds like a jet engine. It kinda sounds like the belt hitting the drive wheel but may be bearings in the motor.
May 03, 2008 | Maytag Atlantis MAV6000 Top Load Washer
LG WM-2277HW Front Load Washer Logo
951 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
