Question about Garden
Help With Troybilt Ride On Lawn Tractor
The tractor won't start with any consistency...turn key, flywheel begins to spin and then seems to get stuck...wont move...I can turn the flywheel with some effort...sometimes this helps...usually doesn't...has gas, battery is charged with good connections...don't see any grass obstructing blades either....I think it's a fuel system issue though...any suggestions???? Oh yeah...seemed to happen more in the past when it was damp outside...now, it seems to do it always!
  • Samuel Charles Spriggs May 11, 2010
    "don't see any grass obstructing blades either"
    Is this unit supposed to start with the blades engaged? Usually there is a switch which disables the ignition switch when the blades are engaged?
    Sergeant:
  • 353 Answers
Check your crank case for fuel,
bowls stick open an fills it up
if this is the case , you can buy a plastic fuel cut valve from lawn mower shop
todays fuel isn't very good
also try sta-bil fuel coditioner
Posted on Jun 20, 2009
When I try to start my 60" Ariens rider all I get is a loud clattering sound. I just replaced the battery 2 months ago. What's wrong with my mower?
Joel, Recheck battery to make sure it has good charge >12 v and all battery and starter wiring,plugs,connections are clean,tight and undamaged. If you remove spark plug and engine spins freely from the key, the engine compression release or valve clearance needs adjusted. It is probable the solenoid or starter is faulty, the starter Bendix/drive may be sticking. If you can, give the starter a couple sharp raps with a hammer or bar and then try to start.
Check the attached links,instruction and guides to help diagnose starting issue. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://troybilt.custhelp.com/app/answers/detail/a_id/86/~/clicking-sound-while-attempting-to-key-start---riding-mower
What Are the Symptoms of Bad Starter Motor on Riding Mower Engine
My Bolens lawn tractor won start It just clicks when turn the key even...
Craftsman riding mower won start Just clicks the starter motor
Aug 27, 2016 | Ariens MaxZoom60 60" 25HP Kohler Zero Turn...
Solenoid clicks but starter does not kick in to start tractor
Clicking Sound While Attempting to Key Start - Riding Mower
troybilt.custhelp.com/.../clicking-sound-while-attempting-to-key-start---r...
Jul 19, 2002 - Why does the tractor make a clicking sound and not start? ... Thesolenoid connects the battery to the starter motor when the solenoid is energized. ...It can click, but not make a complete connection. ... Starting - Riding Mower · Professional Shop Manuals · Basic Troubleshooting - Lawn & Garden Tractors.
How Do I Tell If the Starter Solenoid Is Bad on My Kohler ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
Most large Kohler engines on riding lawn mowers use an electric starting system. ... A bad solenoid can deny electricity to the starter motor and prevent engine startup. ...Lawn Mower Will Fire but Not Start · Replacing a Solenoid on a Craftsman Lawn Mower or Tractor · How Does a Starter Solenoid on a Lawn Mower Work?
My Bolens lawn tractor won't start. It just clicks when I turn ...
Dec 03, 2015 | Garden
Cub Cadet SRC 621, won't start. New spark plug, cleaned carburetor and air filter, Whiffs of smoke occasionally
Sounds like a sheer flywheel key. Common on the SRC 621. Kawasaki motor, correct. The flywheel key is under the recoil. Pull the flywheel and check the key. A very small key is there. Breaks and puts the engine out of time
Oct 16, 2012 | Cub Cadet Street Sign- tractor lawn riding...
MTD Lawn Tractor: Flywheel hard to turn in one spot.
sounds like rust build up on the magnet flywheel remove the cover from the top of the engine and clean it
Aug 09, 2012 | Yard Machines MTD Gold 20 HP Lawn Tractor ...
Starter motor spins won't engage flywheel on lawn tractor
take it off and see if the gear is broken (you can buy the gear at napa)or did the shaft the gear rides on got a little rusty over the winter
May 11, 2012 | Craftsman Garden
My craftsman lt 1000 lawn tractor will not start. When I turn the key the starter motor spins but the gear will not raise up and engage the flywheel. Do I need a new starter? (18 hp b&s 42 Inch cut) If...
Starter motor spins, but does not engage
  1. Check the starter motor for a seized or binding pinion gear.
  2. Remove the flywheel inspection plate and check for a damaged ring gear.
  3. Engine stalls immediately when started
    1. Check the ignition switch condition and operation. The electrical contacts in the run position may be worn or damaged. Try restarting the engine with all electrical accessories in the off position. Sometimes turning the key on an off will help in emergency situations, however once the switch has shown signs of failure, it should be replaced as soon as possible.
    2. Check for loose, corroded, damaged or shorted wires for the ignition system and repair or replace.
    3. Check for manifold vacuum leaks or vacuum hose leakage and repair or replace parts as necessary.
    4. Measure the fuel pump delivery volume and pressure. Low fuel pump pressure can also be noticed as a lack of power when accelerating. Make sure the fuel pump lines are not restricted. The fuel pump output is not adjustable and requires fuel pump replacement to repair.
    5. Check the engine fuel and ignition management system. Inspect the sensor wiring and electrical connectors. A dirty, loose or damaged sensor or control module wire can simulate a failed component.
    6. Check the exhaust system for internal restrictions.
May 12, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Craftsman 17.5 HP B&S 42" lawn tractor that won't start. When I turn the key, the flywheel turns nearly one rev and then seems to stick. I turn off the key and manually turn the thing about 30...
Ift.ts very possible you key is stripped on the crank shaft. Raise the hood and pull the air shroud which will expose the fly wheel, Remove the large nut holding the fly wheel and check for the shesred key. If it is sheared install anew one even if it has aneck in it.
Apr 30, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I cant shut off my lawn tractor with the key
I actually had the same problem with my tractor and it turned out to be that I had to run a second ground wire (ground to a separate point) that forces the coil to ground). My suggestion is to remove the flywheel cover and attach a wire (at a different point) to the coil and then start the tractor and when you go to shut it off. Turn the key and then just find a metal point on the tractor to touch the wire to and hopefully the tractor will shut off.
Jul 22, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
129 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
