Question about ViewSonic VA1912wb 19" LCD Monitor
The screen is black even though the green light is on
I have a viewsonic VA1912wb. One day everything was perfect and now the screen is black even though the green indicator light is on and the sound is great. What do I need to do to fix this problem? The monitor is only a couple of years old. Same here Power LED will not turn on, along with everything else to do with the monitor. Tried unplugging it overnight, rebooting everything...nothing - May 29th, 2009 -
  • 822 Answers
The inverter is damaged or loose connections. check it.
Posted on May 30, 2009
  • 489 Answers
Try with another cable, pc if nothing. need to get service.
Viewsonic va1912wb-3 has solid green LED but a black screen
This is a very common problem on this series on monitors. The problem is caused by filter capacitors in the power supply board that have failed. You can rebuild the board and the monitor will be as good as new. Here is a link to repair information for the VA1912wb monitors.
http://www.ccl-la.com/catalog/product_info.php?products_id=90
Apr 14, 2013 | ViewSonic VX922 19" Monitor Flat Panel
I have a VA1912wb viewsonic monitor (A couple of years old). While playing any movie, the screen instantly goes black though the green light indicator is still glowing. Im able to hear the sounds from...
i think your monitor is going to expired soon , i u have valid warranty then try to contact service center if not then buy a new one LED monitor is best than LCD and LED has more life expectancy and woks very well so bye t.c
Sep 03, 2011 | ViewSonic VA1912wb 19" LCD Monitor
Hi, I have a ViewSonic VA1912wb monitor. Yesterday, the screen on my monitor went blank and it never came back again. I checked the power cable and the graphic cable, everything seems fine but still I...
It can be the power supply DC caps for the backlight inverter circuits or the inverter circuits have failed, you will have to open it up.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Sep 13, 2010 | ViewSonic VA1912WB 19" WideScreen Monitor
What cable do I need to buy to connect my Dell computer to my ViewSonic monitor (VA1912wb) for sound?
You just need to get an audio cable with male stereo mini phone plugs (1/8 inch) on both ends.
Radio Shack: P/N 42-2497, 42-435, 42-436
Green jack to green jack.
Apr 01, 2010 | ViewSonic VA1912wb 19" LCD Monitor
I cannot get any sound from my ViewSonic VA1912wb Monitor. I have everything plugged in the mute turned off showing 100% volume the green jack in back of monitor and green match on computer. No sound from...
You may need to load the monitor drivers.
I assume your PC sound is OK.
When you are plugging the green lead in the Moniotr / PC do you hear any noise from the monitor?? if not may be faulty.
Try plugging a friends set of speakers into the back of your PC.
Mar 09, 2010 | ViewSonic VA1912wb Monitor
ViewSonic VA912b monitor fading out during boot
It is probably the power supply, or the inverters.
Similar problem with solution, though it requires you to know something about electronics.
http://www.badcaps.net/forum/showthread.php?t=6876&highlight=*va912*
Jun 12, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Your inverter or backlight need to be replaced those are the main components that light up the display.
If you find this helpful please rate so.
Thanks
May 04, 2009 | ViewSonic VA1912wb 19" LCD Monitor
ViewSonic VA1912wb 19" LCD Monitor Logo
424 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
