Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
Hoover Floormate wheel assembly
The wheel assembly on my Hoover Floormate broke so I ordered the replacement part, only I can't get it in place.  Is there some sort of trick to getting the darn thing to fit how it's supposed to?  With the machine face up, I can get the bottom part or the top part in place, but once I get either part in place I can't get the other to fit.  There is a piece at the top that is supposed to fit into what looks like a hoop, which is part of the solution wetting mechanism, but nothing bends or moves in order to get the piece in place.
In replacing the front wheel assembly, I incorporated a couple of hints from here - first, taking the gray top off by releasing the 6 tabs - 2 front - 2 back - and one on each side - carefully. Then stand the machine up - you need to remove two screws on each side, by the rear wheels and pull those black pieces up some so you have room on the under side for the wheel assembly round things that hold the assembly in place. Turn the machine over and work the round tabs on the assembly in the holders - you need to work it, putting the longest side in first. After getting that in place, carefully - carefully - align the screw thing in the front to where it is suppose to go and carefully work it in place by pushing the screw head carefully through the hole on the arm where it belongs. Be careful not to break anything! After your assembly is in place - stand the machine up and get those black holders along side of the rear wheels back in place and screw them in - 2 screws each. Then carefully snap the gray piece back in place and you are good to go. I don't have a parts list to know exactly what all the names are for the parts, but I hope you get the jest of it. I tried not to use words like do-ma-hicky and thing-a-ma-jig (I'm a woman) haha
Posted on Jan 23, 2008
You must remove the top gray piece it has six tabs 2 in front, two in back and 2 on sides where the foot pedals are. Be very careful not to break them. Then you cn remove screwsa nd install the piece.
Posted on Oct 25, 2007
  • k3asf Jun 30, 2011
    After reading all your comments, as I had the same problem with the front wheels, I carefully spent 2 days (no....not all at the same time) to carefully remove the gray top housing as I would rather take the time to understand WHY. Having said that...there are an additional to locating tabs in the front that should actully be PUSHED out once the other 6 have been released in order to remove the gray top.
    Front wheels can be replaced from the bottom without removing anything. Simply remove the plastic pin (carefully ...that's the only mechanical connection there is to the wheel assembly) with the aid of needle nose pliers and a screwdriver for torque......re-insert the front wheel assembly (either left to right or right to left....goes in easily) and simply re-attach the plastic pin.
    Re-attaching the plastic pin can be tricky and may require some dextarity but, ....what I have found is that if you take a 2.5 mm allen wrench (there is an allen slot in the back of the pin) shorten the short side by about half you can position the pin into place and with minimal pressure get it locked into position.
    Sounds complicated but if you read thru this proceedure again it's really quite simple.
    Been a mechanic all my life (of sorts) used to invent tools when nobody made what I needed. Just sayin............
    Reading with interest the proceedures others went thru I found several steps un-needed.
How do I Replace reservoir and tubing assembly on a hoover floor mate?
Hello, this is Ava with Think Crucial.
You may check the online manual for Hoover Floormate in this link: Hoover FloorMATE Hard Floor Cleaner Owner Manual Also, you may call Hoover for assistance which is 800-944-9200
You can order replacement filters for your Hoover Floormate directly to us. You can check the filters in this link: http://www.thinkcrucial.com/search?type=product&q=hoover+floormate
As a special offer here is an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Think Crucial Customer Care
Oct 13, 2016 | Hoover Vacuums
How do you change the scrub heads on a Floormate SpinScrub 500?
Hey there! To change out your brush heads simply follow the instructions below.
1. Remove the nozzle by pulling the two nozzle release buttons.
2. Tilt cleaner back so handle rests on floor.
3. Push two brush release buttons and remove the brush assembly.
4. To replace brushes align post on brush block with hole on bottom of cleaner. Turn brushes slightly until post fits easily into hole. Press brush assembly firmly to snap into place.
Hope this helps!
Jul 05, 2014 | Hoover H3030 FloorMate SpinScrub 500...
How to fix clog on hoover floormate fh40010?
I was having the same issue with my NEW just out of box Hoover FH40010. First run on the floor was great then the water/cleaner stopped dispensing!!! I found that when is assembled it out of the box I did not have the handle "plugged-in" properly!! I reattached it to where there is NO gap in the handle when pushed firmly into place and locked in the base. WATER SOLUTION NOW WORKS PERFECTLY!!!
Nov 30, 2012 | Hoover FloorMate Hard Floor Cleaner -...
Vacuum not releasing liquid for floorr wash
There are two reasons this might occur. First is that the wheel assembly is broken. Turn the machine over and check for breakage at the rear edge where the wheel carriage attaches to the housing. If it is broken, water will not be released, and the wheel assembly must be replaced. The soap tank on this model was also prone to problems. Sometimes it would fail to release fluid for unknown reasons, and had to be replaced.
Feb 23, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
Water won't come out
There are two common reasons for this. First is that you have a broken attaching lug on the wheel assembly. Look at the bottom of the machine and check for breakage at the rear of the wheel assembly where it attaches to the base. Less commonly, the upper tank will fail on these units and will require replacement.
Jan 28, 2011 | Hoover H3030 FloorMate SpinScrub 500...
Floormate does not disperse wet cleaning solution on the floor. brushes and vacuum pickup all work
First check to see that the wheel assembly is not broken. The assembly must move correctly to allow the fluid to be dispensed. Check for breakage at the rear of the wheel assembly where it attaches to the base. If this is not the problem, you may have a defective soap tank.
Jan 22, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
My son dropped the Hoover Floormate hard floor cleaner and a black piece with a spring came out. I dont know where it goes, and now the handle wont stay up.
From your description you have an issue with the pedal release in the base. this model is the original series, and I would not put too much money in the repair. not an easy cover to remove. check the base wheel assembly. the black pivot points break on these when dropped. If it is broke the part itself cost about $18. Cosider the overall performance and other repair items to determine worthwhile repair.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Oct 03, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Reassembly of FloorMate
You must take the top off to put the part installed it will not go in from the bottom.
Sep 26, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
The floorplate broke off my Floormate H3000
I'm assuming that the floor plate your referring to is the wheel assy. This is a common problem on the H3000 series. You will have to remove the two pivot brngs on either side of the handle where it pivots on the base. Once removed, flip the machine over and you will have the necessary clearance to insall the new wheel assy. The difficult part will be attaching the front arm assy using little plastic pin provided. You can use a small pair of needle nose pliers to guide the pin into place and then use a larger pair of needle nose to squeeze GENTLY to push the pin into place. Once done, re-install the pivot brngs and your done.
Jan 11, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
416 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
