Question about Genius G-Shot DV1110 Flash Media Camcorder
SDHC 4.0GB Memory Card
It doesn't seem to work with the G-shot DV1110 Flash Media.  Is this not compatible, I bought it when I bought my G-shot.
0 characters
1 Points
I have a DXG 5B1 HD and need to replace the card. What specific card is compatable?
As per this page:
DXG USA DXG 5B1V HD DXG Sportster 1080p HD Underwater Camcorder
SD Card (Up to SDHC 16GB Class6)
This is probably one of the best you can buy:
SanDisk Ultra 16GB SDHC Class 6 Flash Memory Card Speed Up To 30MB SDSDH...
If you don't need 16GB, you can buy cheaper cards with less storage space.
Jan 29, 2015 | DXG 5B1V HD Sportster 1080p HD Underwater...
My SanDisk 16 gb memory card keep saying the card is blank and it is not allowing me to put things on it
What device are you putting the card into? Is it compatible with SDHC cards, or only with SD cards?
Feb 14, 2013 | SanDisk Mobile Ultra - Flash Memory Card -...
Canon Legria HF200 SDHC Initialization problem
This totally sucks. I have a similar issue with my Canon Vixia HF R20 and I'm using a Lexar Pro 64Gb 133x SDXC card. When trying to initialize the card, its fails and says "Process terminated with error." It also says "check the memory card" when I first put it in. Write-protect is off. My other SanDisk class 4 SDHC card seems to work ok.
I could have sworn it worked before and I was able to transfer videos to my Mac on 10.6, but I can't remember for sure if I was using the SDXC card or just the built-in memory. Very frustrating.
Apr 12, 2010 | Canon Legria HF200 Flash Media Camcorder
How do you get images onto the computer from the memory stick or print pictures
You should be able to use a USB cable to connect the device to a computer, or take the memory stick from the device and use an adapter with your computer to access it like a flash drive or external hard drive. If you are using an SDHC memory card, you must buy a SDHC compatible adapter and meet the criteria for the adapter.
Dec 02, 2009 | Sony Handycam DCR-TRV320 Digital Camcorder
SD Compatibility
nope. The largest it'll take is 2GB SDIO-compliant SD flash media. SDHC is right out of the window with this model.
Jun 07, 2009 | JVC Everio GZ-MG21 Camcorder
SD vs SDHC Card in Aiptek ASDV2.4 Camcorder
No return the card before you open it and get a regular SD card! this card will not format in your camera! Please rate my answer!
Jan 15, 2009 | Aiptek ISDV2.4 Flash Media Camcorder
Is the vivitar dvr 530 compatible with sdhc cards
Plug the SD card with contact terminals facing away from battery. It most likely is using internal memory which is much smaller. All cards under 4gb are normal SD. The camera should be able to format the card, or use an adapter and windows will format (default settings).
Jan 03, 2009 | Vivitar DVR 530 Flash Media Camcorder
Memory full message
the problem Probably is that the memory card isn't the right kind, so it just records to the "Built in memory". The only way to fix this is to format the Memory card
Aug 16, 2008 | Aiptek A-HD 720P Flash Media Camcorder
User manual
1. Go to: Click on "Service & Support"3. Click on "User's Manual"4. Click on the tab labelled "DV"5. Find your camera model on the page.6. Click on the appropriate language listed opposite to your camera's model. The download of your camera's user manual will start.
Nov 27, 2007 | Genius G-Shot DV1110 Flash Media Camcorder
Genius G-Shot DV1110 Flash Media Camcorder Logo
24 people viewed this question
Top Genius Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Genius Video Camera Expert? Answer questions, earn points and help others
