Question about SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue
My simpletech 320gb is looking for a driver
Hello Please help me. i just borrow an external hd to my friend and works for a two day period but when i bought it back its now looking for a driver and we cannot i access the files anymore. It will promp you to search some drivers but it cannot find the specific one. We tried it also to other pc's and laptops but still the same. Please i need some help. The files are very important for a business, im in big trouble.pls help. I have the same problem and lost all of my contacts and calander information and Simpletech will not warranty it because of purchasing it at BJ's Wholesale Club.....beware!
  • 696 Answers
Hi guys,
This type of problem is fairly common.
There are two common reasons why this happens:
1. The drive may not have been properly ejected causing corruption of the files. This can be fixed by running the command prompt and typing in CHKDSK ?: /F where ?=damaged drives letter.
2. Hardware failure, either the circuit board on the drive or the one in the simpletech case may be damaged. Generally with a driver issue it is the latter and can be solved easily by stopping in at your local computer store and having them transfer the actual drive into a new drive enclosure.
If neither of these solutions work, then you will most likely need the help of a data recovery pro in your region. If you are in North America I suggest Armor-IT Data Recovery, India www.diskdoctorsindia.com or if you are elsewhere comment back with your region and I will make another recommendation.
Hope this helps FixYa,
Chris
Posted on May 31, 2009
SimpleTech SimpleDrive Pininfarina 320GB, I just need a driver for the external HD. I have moved and I cannot find my disk for my computer. OS is Pro XP
http://www.hitachigst.com/support/index-files/simpletech-legacy-downloads. I am unsure which SimpleDrive version you have, but if it's the regular (not deluxe, mini, or 3.0), it should be the first driver on that page, assuming that Windows XP doesn't install the drivers itself when you plug it in.
Jul 18, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
I have a 320 Simple Tech 320GB with nothing on it and am trying to do a back-up 87 GB in size and it keeps telling me I do not have enough room?
Hello, thanks for using FIXYA,
have you had try to format the external drive, do that then try to copy again.
Let me know if that works
Thanks
Rate this solution please
May 27, 2011 | SimpleTech Signature Mini 320GB External...
Lost power cord for simpletech pininfarina 320gb external hard drive. Where can I buy a replacement?
Hi
Please the the adepter for the mention below Inputs
Input 1000-240v-1.0aMAX
50-60Hz
Output +12v 1.5a
that's help u
May 05, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
All my files on simpletech harddrive show as 0
you mean you HDD does not show the capacity it holds? try using it on another pc, or even try using it on your friends pc, see if it works?
Mar 28, 2010 | SimpleTech SimpleDrive 160 GB External USB...
SimpleTech SimpleDrive Pininfarina 320GB Power up problem
It could be that it's internal power supply burnt out,
in which case the drive itself could still be fine.
Try opening up the external case, and removing the drive.
Once you do, plug it in to your computer directly using its SATA cables, and see if that works.
Hope I helped,
Tom
Jun 21, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
My simpletech 500gb cant be open
I was going to tell you that you need to download a driver from the simpletech web site that allows it to run under Vista. But, I went to the simpletech web site for you and took a look. All of the products I could find (ie: simpleshare, thumb drive, desktop drive, network drive...) haveonly drivers for Windows 98 or WIndows Millineum! If you have one of these, they probably dont support it under Vista. It is usually the way companies get us out of older technologies and push us into their newer products. SOunds like a conspiract theory, but its the truth. Anyway, if you have a newer model I havce not run across on the site, may i havce the model number to check? Or you may do it, if you feel comfortable with doing such research. Here is the link: http://www.simpletech.com/support/support_downloads.php
Jun 13, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
USB not recognized
Sometimes it helps to reinstall the drivers for the USB hub/controller in the Device Manager.
For other ideas, have a look at these external HDD troublshooting tips.
Hope it helps.
Jules
When my simpletech 320GB External Hard Drive starts up, it starting clicking, and won't be recognized by my computer.
Hello
OK, at the link below you will be directed to a tip i wrote on this exact error.
Click HERE.
Feel free to let me know if you have any further questions.
Kind regards
Andrea
Apr 05, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
I had the same problem. Since the warranty had expired I opened up the casing and found that the plastic braces from holding the harddrive had broken and the drive had disconnected from the circuit board. Simply reattaching it solved the problem for me.
May 09, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue Logo
365 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
