Question about General Electric WJRR4170GWW Top Load Washer
Washer fills and drains but won't aggitate or spin
Washer is less than a year old and just stopped spining suddenley wjrr4170gww wont spin took front panel off pc is blinking 7 times what does that mean?
  • 56 Answers
Take the 3 or 4 srews out of the top console panel and lookinside console there is a tech sheet to verify but I think it means you need a motor. 877-262-1479 parts
Posted on May 30, 2009
  • 1,543 Answers
Seven flashes means the washer did not sense a lid opening. Check the lid switch.
My washer fills with water on starting a load but then it does nothing won't start spining to empty water
If the machine loads ups with water and does not stop then the water level sensor is fautly . But if the inlet valve stops on fill up but there is no spin of the motor or thereafter there is no spin/rinse or drain then the program controller / drain valve/pump must be checked.
Jun 14, 2011 | Washing Machines
Kenmore top loader washer aggitates but does not spin out the water it drains but no spining any ideas?
The spinning coil might be not received power supply properly please check it then check spinning coil if it faulty means kindly change the motor
May 18, 2010 | Washing Machines
Top loading washer that won't aggitate, or rinse.
without knowing more details, and considering it's age , my guess is that you have a disconnection (or a loose wire) to the solenoids under the tub. these solenoids activate the clutch system that pulls it into agitate and spin modes. it might be the solenoids, but rarely do both go out at the same time. it might be the timer contacts or connections behind the control panel. or, it might be the timer its self.
try unplugging the unit and check all the connections.
hope this helps jay
Dec 04, 2009 | Maytag Washing Machines
Front loading washer won't spin
my amana washer wont spin and does not drain
Sep 11, 2009 | Kenmore Washing Machines
Have a wjrr417og1ww washing machine. it is about
if ther was a power surge or power went out machine needs to be reset unplug for 1 minute then replug unit in and open lid 6 times in 12 seconds it should reset . that is what i had to do with mine
Jun 15, 2009 | General Electric WJRR4170GWW Top Load...
Since the washer is less than an year old it must be under a warranty.Try contacting the customer care and get it replaced.
Generally for such a problem,the following checks need to be done.
* Test the lid switch
* Test the timer control
* Test the centrifugal switch
* Test the water level switch
* Inspect the motor coupler
* Inspect the drive belt (belt drive only)
* Inspect under the washer for soot (clutch)
* Test the motor
* Inspect the pulley
* Test the transmission
In your case I would advice to get your machine replaced with a new one.Good luck,Please do rate the solution if accepted.
Apr 10, 2009 | General Electric WJRR4170GWW Top Load...
GE commercial washer wont spin or drain
If your washing machine is 20+ appliance years old, it's probably due for replacement.
Jul 15, 2017 | GE WNRD2050DWC 3.5 Cu. Ft. Commercial...
Washer will not spin or aggitate
1. unplug for ten minutes.
2. plug back in.
3. open/close lid 5 times.
4. wash clothes!
Sep 18, 2007 | GE WWSE5240G
General Electric WJRR4170GWW Top Load Washer Logo
362 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
