Question about Yamaha DSP-AX1 10-Channel Amplifier
Audio thump on changing any parameter
Audio thump on the DSP AX 1 on switching inputs, muting the circuit or changing the sound field
  • rankcr Jun 01, 2009
    The area of the damaged pcb does not contain one of these capacitors. I am attaching the diagram with the damaged area marked by my audio technician Thanks rankcr sorry could not insert image !The damaged area is in the lower right corner of VIDEO PCB (4)
  • Anonymous Mar 18, 2014
    How to prevent thump noise when switching off
  • Yamaha Master
  • 5,056 Answers
My bet is a faulty electrolytic capacitor! Don't know which. but would look around the circuit of those stages.
Posted on May 31, 2009
Need Help
I think you've answered your own question, circuit power is not going from one side of the DSP chip to the other and that suggests that the DSP's core is at-least partly DOA. You are indeed correct that functional power should be at 3.3V and yes 0.3V does make a difference to the components that rely on a 3.3V feed, however if the DSP is fried you are not going to see normal functionality or be able to diagnose further.
Sep 04, 2007 | Audio Players & Recorders
I have an RCA rear Projection TV model # p60812BL manufactured in 1998, no sound is coming from the tv when watching cable TV via a digital box. When the mute button is pressed and unpressed you can hear...
Tries tv and cable box unplug,replug it back like about an hour.For the tv resetting itself and the cable box to upgraded it softwares.Go into the tv menu go to Audio SETUP.Go down to audio ressetting,these steps should solved ur problems,but not call ur cable companny replaced the reciever box,it have problems.
Mar 16, 2011 | RCA P52926 52" Rear Projection Television
There is a music button on the front panel that allows you to select Jazz Club, Live and concert hall. It cycles between these 3 options and every time it switches, the audio cuts out
Momentary cutout is normal when you switch between DSP modes (Digital Sound Processing). The unit has to crunch the numbers anew each time you change the parameters.
Nov 28, 2009 | Sony STR-DE997 7.1 Channels Receiver
JVC AX-66 Integrated Amplifier seems to be muted?
You need to have a jumper between the 4 standalone jacks on the right side of the column of stereo connectors. A stereo RCA cable would work for this.
Oct 14, 2009 | JVC Audio Players & Recorders
Amplification does not work
It sounds like a source slecton issue. Try the following and if that does not help I would start with a simple stereo setup and source and work up from there.
The RV-8 is powered on, but there is no audio.
1. Make sure volume level is audible. Volume level can be
increased with the front-panel volume knob or the remote
control VOL �� and �� buttons.
2. Make sure audio has not been muted. The message “MUTE
ON” or “FULL MUTE ON” will appear in the on-screen and
front-panel displays when audio has been muted. To deactivate
mute, press the Mute button or adjust the volume level.
3. Check the INPUT SETUP menu DIGITAL IN and ANALOG IN
parameters to ensure the appropriate audio connector is assigned
to the selected input.
4. Make sure the RV-8 is receiving an audio signal. To do this,
follow the instructions that begin on page 2-29 to open the
STATUS menu for the current input source. Hint: (Use the "STAT2" Button on the remote.)
Apr 29, 2009 | Lexicon RV-8 V2.0 Amplifier
HTR-5240 Will not play audio when switching to DSP
Most likely your DSP board is bad, usually a pretty costly repair and sometimes the board is hard to find in stock.
DSP--Digital Signal Processor
Dec 01, 2007 | Yamaha HTR-5240 Receiver
Need Experts Help!!
My receiver is experiencing the same issue now. I was thinking it was an amplifier output stage going out. I only took the hood off and measured some typical voltage areas, nothing too in depth while on the living room floor. What was your conclusion? I'd much rather fix mine than buy a new one.
DENON AVR 2802 (NO SOUND)
If "Digital" sign blink on front panel, it means DSP do no start properly. If DSP do not start, main UC mute audio. Change IC, AT49LV002-70TC (IC 817 ) at DSP board (Denon P/N: 262 3010 006).
Jan 01, 2007 | Denon AVR-2802
Thumping Subwoofer
Ive seen this problem in alot of audio setups in vehicles but most peeps dont know this is not a good thing and will cause damage to your woofers or amp. 99% of the time it turns out to be as you said that bad boy muting circuit. alot of these curcuits do use separate transitors or diodes as mute switches but most of them are directly from the Microproccessor. Only way to trouble shoot this is with a schematic and a good car stereo tech. Good luck
May 25, 2006 | Yamaha RX-V2200 Receiver
Yamaha DSP-AX1 10-Channel Amplifier Logo
145 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
