Question about Palm TX Handheld
My palm t/x was set in water on one side, the power button side. I have let dry for 4 days and inspected for any moister and found none with only a very small indication that a slight amount of water had been there. Now palm will not power on and the computer does not acknowlege it when connected. I know water is a bad thing but I do not feel it was that much. Is it gone for good or is there something that can be done short of sending it in ?
  • kiloii May 30, 2009
    Hoping for different solution, but expected this one. Thanks
  • 355 Answers
If you TX is in a constant loop and will not hard reset and clear the loop this is a indication of possible water/moisture damage which will need to be repaired. If it is determined to be water damage then it is a out of warrenty repair which thru Palm will cost $199. You can also check pdaparts.com, they have parts and do repairs as well.
Posted on May 30, 2009
  • Rohit  Asthana
    Rohit Asthana May 30, 2009
    try to reset your palm....
Ac won't turn on after cleaning and E1 appears on control panel
E1, The e1 error code could mean multiple things. The most common fault with the unit is a stuck button on the access panel. Gently push each button in and out to ensure none of them are stuck. The panel may have malfunction due to moister. See that the unit is installed properly, and then leave it off for a few hours so the moister can dry up. if these two things dose not work then the temperature sensor could be bad. Heir 1-877-337-3639
Oct 01, 2014 | Haier 5200 BTU Window Air Conditioner...
How to fix my mother board from wet?
As with most electronic equipment, as long as there was no power to it when it got wet and none since, dry it completely (use a blow dryer and let it sit in a dry environment for several days).
As long as nothing has corroded or still has moister in it it should work fine. I would try to use an old drive and a live CD to avoid frying the HDD if there is in fact damage to the board.
hope this helps
Aug 09, 2012 | ASUS MOTHER BOARD M5A88-M
Dehumid....ad70usso....runs all the time auto settings don't seem to working collects fine ..but won't turn off when air is dry thanks
There are 4 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2. Also, keep in mind, basements stay moister longer than upper rooms.
1. The humidity extraction level is set to HIGH. Lower it to 32-35% and disable the auto mode.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Jul 14, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
Fell in water, how to dry out and recover?
First DO NOT TURN IT ON NO MATTER WHAT
If you do turn it on when wet then there is a high chance you will short the device
I would lay it out in some towels for a few days and let the water dry out. You can help it by blow drying every so often.
Wait at least 2 days before trying to power it up. IF it does power up, try to use the Palm Desktop software and get all the data out of the device before you actually start using it.
Mar 05, 2011 | Palm Zire 31 Handheld
My phone has water damage i can here stuff when i push the buttons but nothing comes up on the screen
try putting the phone in a bag of dry white rice...and seal it..use a plastic zip lock bag.put it away for a few days .the rice will draw the moister out..that might help good luck
May 12, 2010 | Cell Phones
My palm centro fell into some water last night and now none of the buttons are working the touch screen works. What should I do? Can I take off the keypad so I can try to dry it out under there?
try this..shut the palm off..get a plastic zip lock bag full of dry white rice..put the palm in there and seal it..wait for a few days then open it up..the rice will **** the moisture out of parts.i hope it works..it did for me
May 09, 2010 | Cell Phones
I washed my lexus sc 400 engine now runs rough. found water in #5 plug sucked it out and dried it, still the same.
Power wash???...let her dry out a few days and do not do it again...inspect the air filter too.
Mar 30, 2010 | 1993 Lexus SC
Pal m centro touchscreen disables after receiving
Hello 150pilot,
To manage an active call when the touchscreen is disabled, use the hardware buttons on your Centro (on left side of the Centro).
- OR -
The keyguard feature might be accidentally enabled. To turn off Keyguard, do the following:
• When the screen is off, press the red power button to wake up the screen.
• Press the center (Palm) button to turn off Keyguard.
You can change how quickly Keyguard turns on, or you can disable this feature altogether. To change the Keyguard settings, do the following:
• Press the Home button
• Select System from the category drop-list at the top of the screen
• Select Prefs
• Select Keyguard.
• Select the Auto-Keyguard pick list, and then do one of the following:
-Select how quickly you want Keyguard to turn on: When power is turned off, 5 seconds after power off, or 30 seconds after power off.
-Select Disable to completely disable the Keyguard feature until you turn it on again by pressing Option + Power/End when the screen is on.
4 Select Done.
More information about the keyguard feature canbe found in the Palm Centro User's Guide:
http://www.palm.com/us/support/handbooks/centro/centrosprint_ug.pdf
Have a great day,
martyshaw152
Jan 16, 2010 | Sprint Palm Centro Smartphone
Runs but does not remove water
If only the bottom part if your coil is geting cold or freezing, it's low on Freon.
Please rate solution
Sep 05, 2009 | Fedders R6DH45X Dehumidifier
Camera dropped in a kiddie pool (NON-CLORINATED)
Well you are right , water and electronics don't mix but you may be able to save it. I did this just the other day with my digital recorder that fell out of my pocket and into a tub ow water. chances are 50-50. i quickly grabbed it and removed the batteries. Opened op the case as best I could and let it sit for a few days. Moister rises. If you place a plastic sandwich bag in an area of humidity, say outside, it will collect moister. people say to place carpet in the garage to stop moister but this just collects it as it drops from the car as it rises in the air. Anyway, a hair drier will speed things up also. It may or may not work again but it is worth a try. Be careful, the electronic flash device will give you a shock you will never forget if the photo flash capacitor is still charged. My digital recorder works great after taking it apart and letting it dry out. If using a hair dryer put it on the lowest setting. Wait a few days and re-charge or re-place the camera battery and give it another go.
I hope this helped some and let me know the outcome.
Kevin
May 29, 2008 | Kodak EasyShare V1003 Digital Camera
Palm TX Handheld Logo
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
