Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Need to remove weed line (recessed inside) so I can install new 1
This is for a Ryobi connect system with a yellow/ orange housing.
    Problem Solver:
  • 16 Answers
If i know which head you are talking about then, it is a self feed that you wind the line in at through the holes right?? the black center nut comes off. using pliers twist it off, it is threaded.
Posted on Jun 13, 2009
Connecting a new stereo with red for AC power, black for ground, Yellow for battery fuse wire. The car stereo wiring has orange, black, yellow but no red wire. it has 3 others as well
Orange is your steady power source and Yellow is your switched power source so your new stereo would connect Red to Yellow and Yellow to Orange in most cases but it is best to use a test light to check before making connections.
May 04, 2016 | AC Cars & Trucks
Tip
Telephone jack wiring
Most cheap jacks have 4 wires, red, green, yellow & black. Most modern houses have wires paired up (twisted pair) like blue & white with blue line or stripe. Line 1 is red/green or blue/white. Line 2 is yellow/black or orange/white(with orange line/stripe).
on Feb 21, 2015 | Lands Phones
I have a Ryobi CS 3635 chainsaw. The chain guide bar is held in place by 2 studs that screw into threaded sleeves embedded in the plastic housing . Somehow I have managed to strip these sleeves to the...
Contact you local Ryobi Dealer / Stockest, and obtain spare replament parts . Other options --- Ryobi Website ( Best ) Yellow Pages to find local Dealer
Mar 17, 2015 | Ryobi Garden
Battery not charging. Orange and Green light on charger. 18V Plus one system
The air holes on the bottom of the batteries are there for the battery to vent. Downside is, these vents can also allow moisture to get in and prevent contacts from letting the battery charge and causing the "defective" display on the charger.
I work on pool and spa equipment and I had dropped my batteries in a small puddle of water where I was working, both went dead immediately and both showed "defective" on the charger even after drying them out for a few days.
Tried using a can of air and gave each of the vent holes several shots... The batteries charged and are now working perfectly.
I'm sure even overnight condensation could be the culprit for a charger to display "Defective"
Jun 24, 2011 | Ryobi Multi-Volt Battery Charger
Ryobi charger model # 140295003 has a red and yellow light. When charging red light is on what does the yellow light mean? Also how long should the battery be left in the charger?
Completely wrong. Quoting from the user's manual:
"The charge indicator light (LED), located on the charg- ing stand, will light up red and glow when the char- ger is properly connected to power supply. This light indicates the charger is operating properly. It will remain on until battery pack is removed from charging stand or charger is disconnected from power supply.
After normal usage, 3 hours or less of charging time is required to fully recharge battery pack.
If both red and orange LED indicators glow, the battery pack is deeply or completely discharged, and 6 hours or longer of charging time is required to fully recharge battery pack.
Note: If charger does not charge battery pack or orange LED continues to glow after more than 30 minutes of charging, return battery pack and charging assembly to your nearest Ryobi Authorized Service Center for electrical check."
So to summarize: red = charging. orange (yellow) = fully discharged battery. orange after 30 minutes - bad battery or bad charger.
Apr 23, 2011 | Garden
I have purchased Carozzeria Pioneer DEH-P700 from a Vendor. I want too install the system in Car. Can you guide me for Yellow , Orange and Red Wire purpose? Thanks
Yellow
Connect to the constant 12 V supply terminal.
Red
Connect to terminal controlled by
ignition switch (12 V DC).
Orange
Power antanna
Nov 22, 2010 | Pioneer DEH-P700BT Car CD Player
I want to see the cheats of guitar hero2
Secret Guitars
  • Snaketapus Guitar: Complete Hard Mode.
  • The Log" Guitar: You must achieve 5-Star every song on Expert.
  • Battle Axe Guitar: Complete Expert Mode.
  • Casket Guitar: Complete Medium Mode.
  • Eyeball Guitar: You must achieve 5-Star every song on Hard.
  • Fish Guitar: Complete Easy Mode.
  • USA Guitar: You must achieve 5-Star every song on Easy.
  • Viking Guitar: You must achieve 5-Star every song on Medium.
Unverified. On the main menu, directly depress the colored key without any other input.
Performance Mode ... YELLOW, YELLOW, BLUE, YELLOW, YELLOW, ORANGE, YELLOW, YELLOW
Hyper Speed ... ORANGE, BLUE, ORANGE, YELLOW, ORANGE, BLUE, ORANGE, YELLOW
Air Guitar ... YELLOW, YELLOW, BLUE, ORANGE, YELLOW, BLUE
Eyeball Heads ... BLUE, ORANGE, YELLOW, ORANGE, YELLOW, ORANGE, BLUE
Moneky Heads ... ORANGE, BLUE, YELLOW, YELLOW, ORANGE, BLUE, YELLOW, YELLOW
Flaming head ... ORANGE, YELLOW, ORANGE, ORANGE, YELLOW, ORANGE, YELLOW, YELLOW
Horse head ... BLUE, ORANGE, ORANGE, BLUE, ORANGE, ORANGE, BLUE, ORANGE, ORANGE, BLUE
Air guitar ... BLUE, YELLOW, ORANGE, BLUE, YELLOW, YELLOW
Eyeball Heads ... YELLOW, ORANGE, BLUE, ORANGE, BLUE, ORANGE, YELLOW
Hyper Speed ... YELLOW, ORANGE, BLUE, ORANGE, YELLOW, ORANGE, BLUE, ORANGE
Monkey Heads ... YELLOW, YELLOW, BLUE, ORANGE, YELLOW, YELLOW, BLUE, ORANGE
Flaming Head ... YELLOW, YELLOW, ORANGE, YELLOW, ORANGE, ORANGE, YELLOW, ORANGE
No HUD performance mode ... YELLOW, YELLOW, ORANGE, YELLOW, YELLOW, BLUE, YELLOW, YELLOW
Horse Head ... BLUE, ORANGE, ORANGE, BLUE, ORANGE, ORANGE, BLUE, ORANGE, ORANGE, BLUE, ORANGE, ORANGE, BLUE, ORANGE, ORANGE, BLUE, ORANGE
To unlock everything in the game, insert the following code on your guitar at the title screen: Blue, Yellow, Orange, Red, Orange, Yellow, Red, Yellow, Red, Yellow, Red, Yellow.
Jun 05, 2009 | Video Game Consoles & Games
Panel yellow light flashing and also nothing showing on screen"
Make sure outside box is in auto mode. If you pop the display off of the wall you will see four wires connected to the panel. Make sure all are connected. Next, go out to the panel by the pool and make sure the four wires are connected there. If his didnt work the next step would be to ohm out the wires. Disconnect the wires from both ends (house and pool), On one end twist the red and black together and the green and yellow together, on the other end (with a ohmmeter) check for continuity (red-black and orange-yellow). If they check out then you either have a bad display panel, or a faulty main logic board in the box by the pool. In this case just pray that it is the display panel.........
Mar 23, 2009 | Jandy Aqualink Rs4 One Touch Control...
Please send me cheats in guitar hero II
To unlock everything in the game, due the following code on your guitar at the title screen: Blue, Yellow, Orange, Red, Orange, Yellow, Red, Yellow, Red, Yellow, Red, Yellow.
Jan 06, 2009 | RedOctane Guitar Hero 2 Game For...
Wiring problem
Yellow/black
If you use a cellular telephone, connect it via the
Audio Mute lead on the cellular telephone. If not,
keep the Audio Mute lead free of any connections.
Orange/white
To lighting switch terminal.
Blue/white
To system control terminal of the power amp or
Auto-antenna relay control terminal (max. 300
mA 12 V DC).
Nov 30, 2007 | Pioneer DEH-P3500 CD Player
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
151 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
