this link has install sheets just match the model number of you amp to the list of mtx amplifiers to find appropriate wiring diagram
http://www.mitekasia.com/support/Default.aspx?sid=257&aid=2
Is it a 2 or 4 channel amp???? Does it have a lpf (low pass filter)??? If its a four channel it prolly wont sound too great. If its a 2 channel you need to bridge sub to amp. Usually its the 2 outside terminals on the amp. Might have a diagram on the bottom of amp
1995-97 Nissan Maxima Stereo Wiring
Constant 12V+
Pink/Blue
Switched 12V+
Blue/Black
Ground
Vehicle Chassis
Illumination
Red/Blue
Dimmer
Red/Orange
Antenna Trigger
Black/Red
Antenna
Right Rear
Front Speakers
6 1/2" Doors
Left Front (+)
Blue/White
Left Front (-)
Blue/Yellow
Right Front (+)
Brown
Right Front (-)
Brown/White
Rear Speakers
6 1/2" Rear Deck
Left Rear (+)
Red
Left Rear (-)
Green
Right Rear (+)
Blue
Right Rear (-)
Pink
Diagram for any aftermarket head unit
Black: ground
Red: switched 12volt (accessory)
Yellow: 12v Constant
Orange: Illumination (Dimmer)
Blue: Remote
White & White/Black: +/- Front Left
Gray & Gray/Black: +/- Front Right
Green & Green/Black: +/- Rear Left
Purple & Purple/Black: +/- Rear Right
A better solution would be
1: Get a seperate amp for the sub itself
2: Run 2 speakers on ch 1 and 2 speakers on ch 2. I assume your speakers are 4 ohms, in stereo mode that amp is stable to 2 ohms. The bridge the subwoofer on ch 3 & 4. That will work if you just want to use that amp. If you need more help you can email me @ [email protected] Hope this helps...
dowload both .jar and .jad files and store it in Others folder in ur memory card then get out of the menu and type *#9998*4678255# then it shows ACTIVATED then u can install the jar files
Here is the wiring diagram. The factory amplifier is behind the glove compartment on the right. Just open the glove compartment, push in the right side so it swings down (take things out of it first), and the amp is right there. 2000 Suburban Wiring Diagram (It's for the '00 Suburban/Tahoe, but the wiring did not change from '00-'03.)
You can download the installation manual from the link below:
http://www.sony.co.id/support/product/xm-554zr?site=hp_en_ID_i
It has the following diagram plus other hookup info...
Please update the question & let us know if the information given was useful to you - Good Luck!
