Question about HP Compaq Presario v4000 Notebook
I am unable to see dvd/cd drive since yesterday. I removed lower filters from HOT_KEY_LOCAL MACHINE (I do not see any upper filters).. still problem persists after rebooting the computer. . please help ..venkat
  • 159 Answers
Reinstall the operating system
Posted on May 30, 2009
Cd drive error "please insert disk"
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard.
If this does not fix the problem it might be a registry problem
"you only need to do the following"
if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and typeregedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computerOpen My Computer and check to see if your CD or DVD drives have returned.
You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
if this fails to fix the problem It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it
http://www.nextag.com/dvd-lens-cleaner/shop-html
http://www.infopackets.com/news/hardware/2005/20050315_clean_cd_or_dvd_rom_lens_with_a_brush_part_2.htm
Also
There are several general categories of symptoms of CD/DVD drive malfunctioning from the drive not lighting up all the way to drives that burn, but with errors. You can diagnosis and repair your optical drive with simple fixes.
Restart your PC before checking or doing anything.
Sometimes simply restarting your PC will solve the problem.
If your drive doesn't appear in the "Computer" dialog or Explorer, press the "F5" key to refresh the list.
If that doesn't work, download and install a freeware program such as CDGone (aumha.org/downloads/cdgone.zip) to get the drive to reappear in the Device Manager or Explorer.
You should subsequently reinstall third party CD/DVD playing and burning software.
If your CD/DVD drive connects with an IDE ribbon cable, try each drive attached on the IDE ribbon separately.
If they do work separately, both drives probably have their jumpers set as master drives.
Make sure that one drive is set as the master drive and the other to the slave drive.
If the CD/DVD drive door won't open, determine whether the tray is obstructed.
Stick a straightened out paper clip in the little hole and try to push out the tray.
With a removable laptop drive, pull it out and shove it back in solidly.
Also clean the contacts of the drive with a pencil eraser.
With a drive installed in a desktop computer, unplug the machine and pull the data and power cables and then reseat them firmly, being sure to connect completely.
With a volt meter, test the power cable going to the drive.
It should have two wires with a 5 volt ~1 amp circuit and the other two with a 12 volt ~1 amp circuit.
From these tests, you can determine if the drive is mechanically and electrically sound and if the power supply needs replacement.
Note that there are usually several spare power supply drive leads which can be tested and used to replace a faulty one.
Purchase and use a CD lens cleaner or use a compressed air cleaner can.
If the drive doesn't light up when a CD/DVD is placed in it:
With removable laptop drive, pull it out and shove it back in solidly.
With removable laptop drive, clean the contacts of the drive with a pencil eraser.
With a desktop model, unplug the machine and pull the data and power cables and then firmly reseat them.
If the drive functions perfectly well without an indicator light, the drive light may be defective. Failure to light up may indicate a problem with the inner workings of the drive, such as a short in the drive motor, drive train, laser or another kind of electrical failure. In that case, you probably need to replace the drive.
If the drive initially lights and then "dies" after a disk is inserted and you keep receiving a message "Please Insert Disk," this may indicate a dirty laser lens.
Use a CD lens cleaner or a compressed air cleaner.
A drive light that is intermittent could indicate loose cables.
To verify, remove the cover of your computer and make sure the drive cables are firmly attached. If you have a laptop, a technician may need to take apart the machine to make sure the drive connections to the motherboard are secure.
Many laptops have modular CD/DVD drives that you can sometimes reseat by pulling them out and pushing them back in firmly.
With removable laptop drive, also clean the contacts of the drive with a pencil eraser.
If the CD/Drive Lights Up but Fails to Appear in the Device Manager:
Try right clicking on My Computer and choosing "Manage."
Click on Disk Management on the left hand side and then under the "Action" Menu choose "Rescan Disks."
Also go into the Device manager, click on the root of the tree or on any of the items and choose "Scan for hardware changes." *
A dying motherboard, for instance one that has a dead IDE channel, can cause this.
A way around is to buy a PCI IDE or SATA expansion card and hook your CD/DVD drives to that. *Viruses can also cause Device Manager disappearances.
Do a virus scan. *
Remove the upper and lower filters from the registry keys at:
HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Control/Class/4D36E965-E325-11CE-BFC1-08002BE10318.
You may have to reinstall burning and viewing software.
If you use ITunes, remove the lower filter and set the upper filter to the value of "GEARAspiWDM" without the quotes. *
See the Additional Resources at the end of the this article and try the popular CDGONE patch. This removes the upper and lower filters and changes some additional keys.
Any third party burning and viewing applications may have to be re-installed.
Using search, find the afs.sys and/or afs2k.sys files.
Rename them with a "bak" or "old" extension.
These Oak Technologies cd driver files conflict with Windows cdrom.sys, the CD-ROM driver.
If the CD/DVD drive appears in the Device Manager but fails to appear in Explorer:
Remove the upper and lower filters from the registry key at:
HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Control/Class/4D36E965-E325-11CE-BFC1-08002BE10318. You may have to reinstall the burning software.
If you use ITunes, remove the lower filter and set the upper filter to the value of "GEARAspiWDM" (without the quotes).
Look at the registry settings for the value "NoDrives" at HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer and HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer.
If the values are anything other than zero, Group Policy may be hiding the drives.
You may have to ask your administrator to change things, but if it is a local machine not in a business setting, you can change Local Group Policy yourself by running gpedit.msc in the "Run" command in the "Start" menu.
In Device Manager, uninstall your CD/DVD drive and then have Windows rediscover the device by rescanning for hardware changes. In Device Manager also uninstall and reinstall the IDE port on which you drive is located.
http://aumha.org/downloads/cdgone.zip
Mar 23, 2014 | E-Machines emachines (emachinees) CD-ROM...
My DVD writer is not working at all. in the device manager it shows an error. i tried to reinstall it as recomended by the trouble shoot. would u please help me .
If you oare using a windows based operating system.
On your keyboard hold the windows logo and press the letter R
When the run box comes up type in regedit
go to this key
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
delete the upper and lower filters
Reset the computer and check if the cd/dvd drive will now work.
Hope this helps!
Jul 19, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
My lg dvd rom is not reading dvds
Try deleting upper and lower filters of your optical drive. To do that, run regedit on start search. Then, follow this path: local machine, system, current control set, control, class, 4D36E965- E325 - 11CE - BFC1- 08002BE10318. then on the window under Name, look for upper and/or lower filters. right click on it and delete. restart pc. then you're good to go.
May 26, 2010 | LG GSA-H55N DVD-RAM Burner
DVD and CD drive don't work
STEP 1:
Go to device manager:
START - RIght click on my comp - manage - device manager :
When in device manager, look for:
IDE ATA ATA/ATAPI controllers
click on plus sign to expand the tree
right click on the IDE controller that is handling the CD/DVD drive in question
select uninstall
reboot your computer .
STEP 2 :
Delete Upper and Lower filter :
start : run -
type in regedit -expand hkey local machine -
expand system - xpand current control set - look for control , expand it - under control - expand class - look for the address ::: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
- click on the address - towards the right pane you would find upper and lower filters - right click on both and delete it - after uninstalling the upper and lower filters restart the system - aftre the restart check for the functionality of the drive -
Step 3: if bot the steps above does not work then a firmware update on the dvd drive can be performed - the firmware is a software update for the dvd drive and you would be able to find it on the manufacturer website -
Hope the information provided above was helpfull .
Thankyou .
May 06, 2010 | Gateway 503GR PC Desktop
When first start my laptop, my CD drive works OK, but after a bit, it stops and doesn't even show as a drive on the Computer window
try deleting upper and lower filters of your cd/dvd drive. run regedit on start search. follow this path: local machine, system, current control set, control, class, 4D36E965- E325 - 11CE - BFC1- 08002BE10318. then on the window under Name look for upper and/or lower filters. right click on it and delete. restart pc. then you're good to go.
Apr 13, 2010 | Acer Aspire AS7730-6542 PC Notebook
Machine says drivers are installed but cd n dvd driver not found wont play anything ??help
Mar 29, 2010 | E-Machines emachines (emachinees) CD-ROM...
My Optiarc cd-rw crx880 doesnt work, tried to delete those two regisrty but nothing change.. pls help..
Hi, Before deleting the registry key (most probably the upper and lower filter) try to locate your cd drive in the Device Manager. If it is present, delete it and then delete the upper and lower filter registry key.
If you are unable to find the cd drive in the Device Manager, then there is an issue with either connection to the cd drive or else cd drive is itself faulty.
Feb 14, 2010 | Microsoft Windows Vista Ultimate Edition
The computer can not read the DVD rom, its not listed in the drive
try to run system restore. but if it doesnt work. check the functionality of the drive in safe mode (by pressing f8 when the computer turns on, dont wait for the windows logo to come up, you need to press f8 before the windows logo screen) try to explore whats on the disk and if it works. delete upper and lower filter by following the path. click start, click run, type regedit, hkey local machine/system/currentcontrolset/control/class/4d36e965-e325-11ce-bfc1-08002be10318
if you upper filter and lower filter, delete both. restart th computer and that should do it.
Sep 26, 2009 | LG GH22LS40 DVD-RW Burner
How to delet value data from upper lower filters of the key
The easiest way to remove the filters is to use the tool that Microsoft supplies at this link. http://support.microsoft.com/kb/314060
Jul 02, 2008 | Panasonic Matshita- | CW-8124-B | USB 2.0...
HP Compaq Presario v4000 Notebook Logo
48 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
