Question about Western Digital Caviar SE WD1600JS (WD1600JS20PK) 160 GB Hard Drive
Slow The data rate is to slow to capture dvd from usb port. How can I fix that?
    Novelist:
    Champion:
  • 382 Answers
I take it youre on a PC. You can install a pci or pcmcia card ( whether youre on laptop or desktop ) that has firewire which is 40 x faster than usb1. It must be video youre attempting to capture because still photos only require usb. Most digital video camera come on board with firewire. Check your computer for a port labeled "1394" or "ilink" thise are the name of firewire ports found on PCs.  Anything slower and you run the risk of droppede frames of having to compress the video to capture.
Hope this helps.
Posted on Oct 22, 2007
SOURCE:
External hard drive slow
Well, an external harddrive is always slower than an internal one. A USB-port is checking on a regular basis for other devices, which might got hooked up. It's a common mistake a lot of people oversee. So while transfering data, there are other tasks / jobs done at the USB-port, slowing down data-transfers.
Oct 08, 2013 | Computers & Internet
I am simply making a copy and it is printing super slow.
hELLO IDEAL58ST,
While printing from the USB Port sometimes slow printout/data transfer will result in slow printing of print jobs. SOLUTION: Solution After the printer is installed on the USB Port, check the description under the Ports Tab what is selected. Please refer to the figure below : c00873625.jpg Using the USB/ Virtual Printer Port and DOT4/ HP Laserjet 2420, under the Port/Description Tab printer speed will be as per the standard. Whereas using the DOT4/ Generic IEEE 1284 under Port/Description Tab, Printer speed will be very slow. If DOT4/ Generic IEEE 1284 is selected by default, then you have to uninstall the USB driver from the Device manager and plug in the USB cable again. Then it will detect the printer and USB port with respect to the printer model.
THANKS.
Sep 06, 2011 | HP OfficeJet 6110 All-In-One InkJet...
I have a 4 gb hp v165w pendrive. its data transfer rate is very slow(120kbps). how can i speed up it? please help me
Hi
This not the problem with the pen drive but with your USB port. Check and make sure you are connecting the pendrive to a USB 2.0v. if you connect to older USB port then your data transfer would get effected. If still you are connecting it to USB 2.0v only then try to un-install the ports in Device manager and restart the PC once done the windows will automatically install the USB ports again and this will solve the problem.
NOTE: IF YOU ARE USING USB KEYBOARD BE CAREFUL NOT TO UNINSTALL THE USB PORTS OR YOUR SYSTEM MAY NOT ACCEPT THE KEYBOARD SOMETIMES. DO AT YOUR OWN RISK.
AND DO RATE MY SOLUTION
Jun 30, 2011 | Computers & Internet
Its become mega slow. i plugged it in and it was not recognised then it asked to format. i did it as there was very little data on it and it was all backed up. so i formatted it an now its mega mega slow!...
If it's working but slow, it sounds like it's running at the USB 1.0 data rate.
Is the cable plugged directly into the USB port on your computer, and not into a USB hub.
Or it might be the cable. Have you changed the cable?
Both cable and hub, if you really need a hub, need to rated for USB 2.0
Jan 30, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
None of my usb ports function as "high-speed" 2.0 , and I constantly get the message that my device can perform faster if I connect it to a high speed USB 2.0 port. I bought this computer brand...
you usb ports are to slow for the usb 3.0 device that message keeps coming up saying that the device is better then your usb ports you have on your computer...almost every computer now have 3.0 usb ports that have very fast transfer rates for data back and forth. well i tell you the message you get is not trouble with your usb port it just trying to tell you the transfer rate will be slower with your usb 2.0 port... i hope this helps you.
Jun 13, 2017 | Sony VAIO Digital Studio PCV-RZ22G PC...
My sandisk 8gb cruzer blade is a very slow one,,n givs a max data trnsfr rate of 2.8 mb/s. How can it b solved??
Hi sayak.
When you plug in the card reader, does a little bubble pop up on your screen saying that it could work faster if plugged into a USB 2.0 port?
2.8mb/s is actually a pretty fast transfer rate for a card reader, but it is possible, if you are using the front USB ports of your computer, that you could get a faster rate by plugging it into the rear ports, as they are 2.0 in most boxes.
Sky_Signal
Oct 30, 2010 | SanDisk 8GB microSDHC Memory Card with...
It shows this device can perform faster. the pen drive is slow
this is usb issue
your computer usb has a lower version than your pendrive
you cannot use better drivers because this is from mainboard chipset
Also you can put a pci usb card version 2.0 for your pendrive
Jul 24, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
USB transfer speed is low
THERE WILL BE A DATA TRANSFER RATE PROBLEM IN YOUR LAPTOP ONE OF THE USB PORT.TRY IT ON ANOTHER PORT .IF THAT DIDNT WORK I SUGGEST THE BEST THING TO DO IS TO CONSULT WITH A CERTIFIED TECHNICIAN IN YOUR AREA.IT MIGHT BE A HARDWaRE PROBLEM.IF U FIND THIS SOLUTION USEFUL PLZ RATE IT.
THNXX
Apr 03, 2009 | Acer Aspire 5610-4648 Notebook
USB 2.0 ports behave as USB 1.0 also DVD player behaves same
I would uninstall the USB drivers and the DVD drivers from device manager the reboot and allow Windows to reinstall them: I would also make sure DMA is enabled until your secondary IDE channel.
Nov 08, 2007 | HP Pavilion dv1000 Notebook
Open Questions:
YAHOO password recovery phone number +1800 365 4805 KO RAJAN Get YAHOO 1800 365 4805 password recovery phone number easy steps to forgot or change YAHOO password recovery via phone number #1-************ just follow some steps to recover YAHOO password while you want. In varoius conditions many people lost their account password and much more secure information or information may be hacked by anyone so in that case people want to configure YAHOO with YAHOO or other microsoft account services. Their are many certified officer to suggest people that how to change or recovery YAHOO voicemail password using phone number in easy mode wih simple procedure. Hence search engine suggest many combinations to recovery YAHOO password to recovery or change it quickly, if you have any of them so contact to get well YAHOO support form us. YAHOO password recovery not working YAHOO password recovery phone number YAHOO password recovery contact number YAHOO password recovery help YAHOO password RECOVERY support YAHOO password recovery wont work YAHOO password RECOVERY wont work YAHOO password recovery link YAHOO password RECOVERY issues YAHOO password recovery usa YAHOO password RECOVERY customer service. YAHOO email account password RECOVERY ' free YAHOO email password recovery ' cannot RECOVERY YAHOO email password ' YAHOO email password recovery ' YAHOO email password recovery download ' YAHOO email password recovery software ' free YAHOO email password recovery. YAHOO email password change, YAHOO email hacked password changed, YAHOO email hacked can't change password, change YAHOO email password on iphone, change YAHOO email password on ipad, change YAHOO email password on android, YAHOO email account hacked can't change password, how to change YAHOO email password on droid, YAHOO email password problems, YAHOO email password not working, YAHOO email account password recovery. YAHOO password recovery phone number.
Apr 26, 2019 | Microsoft Computers & Internet
See all Western Digital Caviar SE WD1600JS (WD1600JS20PK) Questions
Western Digital Caviar SE WD1600JS (WD1600JS20PK) 160 GB Hard Drive Logo
122 people viewed this question
Top Western Digital Computers & Internet Experts
Alun Cox
Marvin
Marvin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
