Question about GE Energy Star SDL20KCSBS Bottom Freezer Refrigerator
Slow condenser and evaporator fans on SDL20KCSABS GE ref. mod# PFS22SISBSS. Freezer isn't at zero deg. can only get ten deg. liquid line is hot not warm to the touch. Cond. fan isn't rotating fast at all, blades are clean cond. is clean. Where are the controlls board for the cond motor? What is the prodecdure to check the cond motor?Are these variable speed motors?
2 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: Slow condenser and evaporator fans on SDL20KCSABS
Newer GE refrigerators use variable speed DC fan motors to improve energy efficiency. Fan speed is determined by the electronic control board. Your refrig is working as designed.
Please don't rate solution, as anything but a Fix-Ya lowers my overall score. Thanks.
Posted on Mar 03, 2009
WRS6R3EW8 Refrigerator and freezer not cooling. Evaporator coil 60 deg. only. Compressor, evaporator fan and condenser fan running. Some frost on the tubing coming from condenser at the evaporator. ...
Where is it frosting, condenser or evaporator? If you mean frosting on evaporator line to compressor, probably iced up evaporator. If you mean frosting after condenser by capillary, unit short of gas/ blocked.
Apr 27, 2012 | Refrigerators
Ice forms on bottom of Freezer drawer on Mod. GB2FHDXWBo1
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 18, 2011 | Sub-Zero 650 / O Bottom Freezer...
Water collects in the bottom of the refrigerator,,, where is the drain line located that I need to clean out? Mod: ET1MHKXMQOO
Leo Ponder
imufo2
Aug 20, 2011 | Whirlpool ET1MHKXM Top Freezer...
The water is slow coming out of the dispenser but the ice maker works normally model TFX25PP
Leo Ponder
imufo2
Aug 09, 2011 | GE Profile Performance 25.2 cu. ft....
The freezer is slowly rising in temperature(0-18 deg in a week, still set at zero) and either side of the unit by the freezer door are very, very hot. Unit is about two years old. Fridge temp is slightly...
Check the condenser fan motor in the back, bottom of unit. pull off lower panel. Fan should be running when unit is running. Also check the condensor coils underneath or in back to make sure they are clear.
Jun 02, 2010 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
Can a chest freezer be used in an unheated garage where the temeprature falls below freezing for an extended period? The garage is insulated so it doesn't get as cold as outdoors but it does drop below...
why not then when its down to zero shut the unit off and open the lid and free freezing...no electricity required....remember pop machines sit out in all types of weather
Sep 15, 2009 | Kenmore 5 cu. ft. / 142 liter Chest...
Slow compressor fan
You need to remove the fan and test it somewhere different. The compressor is in need of the condenser fan. Everything will overheat without that fan working. You should also test the power at that pin plug. Let me know what you find. Sea Breeze
Jul 22, 2009 | GE Energy Star SDL20KCSBS Bottom Freezer...
2001 GE side by side refrigerator model TGX26KRDA WW Beginning about a month ago the refrigerator temperature rose to 60 deg. F. Freezer remained well below 0 deg F. Checked baffle which was open and...
Is the fan that moves the air from the freezer to fridge running If there is a switch in cabinet somewhere the freezer door would contract it, with door open push in switch hear the fan both are good. Don't hear fan check evaporator or freezer fan and that switch it may be a duel switch open light closed fan run. Tricky there are light switches, when out light on or when switch is in its lights out
Mar 17, 2017 | GE Refrigerators
Ge side by side tpx24biyaww freezer not cold enough.
hi there,
have check the current rating,this can determine if your freezer is under charge,use a clamp ammeter hook it up on common line of compressor,set ampere on tester to 50 amper so you can read clearly,compare this on rated current on manuals or theres a description tag on backside of your freezer look for rated amperes .this should be done by aircon / ref technician if you can't do this,have check also the leak , have a nice day don't forget to rate me,thank's
May 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Mar 03, 2009 | GE Energy Star SDL20KCSBS Bottom Freezer...
GE Energy Star SDL20KCSBS Bottom Freezer Refrigerator Logo
64 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
