Question about Emerson MW8106W Microwave Oven
Frigidaire microwave (FMT148G1B2) surface light crct inoperative
Frigidaire Gallery microwave (FMT148G1B2 / Canadian model CFMT148G1B2; built 1999) lost function in surface light circuit during power surge.  Suspect blown fuse, but which and where?  Can't find service instructions for fuse replacement.  Surface light bulbs and all other functions are OK.
SOURCE: Lost power suddenly
Could be; replacement fuses avail @ RadioShack or a similar place for a few bucks, so it's worth trying. Just remove the outer casing, look for the white plastic snap-on container (might say "FUSE" on the side). See this also:
http://www.partselect.com/microwave+replace-fuse+repair.htm
Posted on Jan 17, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Blown Fuse
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
Posted on Apr 01, 2008
  • 89 Answers
SOURCE: Emerson microwave light out
There is a way but.... you will have to remove outer cover generally held on with screws at rear and under microwave be sure the oven is unplugged and when you take cover off there is a capacitor in there thats holds a charge stored even when oven is unplugged so dont touch nothing except the light bulb would prefer if you dont have much electrical experience to take to repair shop or have someone do it who has a little electrical knowledge hope this helps
Posted on Sep 05, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Emerson MW8106W Blew internal 20A fuse.
You almost certainly have a shorted high-voltage capacitor.
Here is a link you or someone you know can use for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating a servicer or parts at 1-800-695-0098.
Emerson parts are distributed by Fox International and their number is 800-321-6993. Or you might try e-mailing researchdept@fox-international.com
Many Emerson microwave owner's manuals are available for free download here.
Posted on Oct 21, 2008
  • 234 Answers
SOURCE: Replace Emerson Microwave Ove Fuse
Most of the manufactory has put them in the back where the power cord comes in.
Posted on Mar 14, 2009
Check fuse inside microwave oven (usually 8-10-12 A) on power supply board or main board, depending on model.
Dado
Aug 10, 2014 | Electrolux Frigidaire Gallery 30" 1.7 cu....
What are the Reasons why One touchy door open button is sticking on FGM0205KBB microwaves
Good afternoon friend, thank you for the post!
I understand that you are stating the door open button is continuing to get stuck on your Frigidaire microwave. I would like to ask some additional questions to make sure I can provide additional assistance. First, which button are you referring to that is sticking? When I pulled up your model FGM0205KBB, I do not see a door open button. Could we verify the model number is correct? Once I have that information I look forward to assisting you. -Matt
Aug 08, 2014 | Frigidaire FGM0205KB Gallery 2.0 cu. ft....
How to change a bulb in fgm0205kf
part # 5304440779
you will need to take the cover off the unit for that.
the bulb is on the right side mount to a black plastic.
FYI your Model # is FGMO205KF
Good Luck
Mar 14, 2013 | Frigidaire FGM0205KF Gallery 2.0 cu. ft....
Model FMT148G1B2 - over range microwave will not heat food. Clock, lights, rotating plate in M/W all work, just will not heat/warm.
well that depends on the current. If the current is a fluctuating type then microwave wouldn't heat or else if high...please check..
Jul 23, 2010 | Frigidaire FMV156EM Microwave Oven
Frigidaire microwave not heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101=--=-=
May 19, 2010 | Frigidaire FMT148G1 Microwave Oven
Microve turns on, but will not heat Model number is FMT148G1B2 Everything seems to work except there's no heat. Clock works, countdown timer, light, turntable, etc., just no heat.
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Apr 16, 2009 | Frigidaire FMT148G1 Microwave Oven
Surface lights
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 18, 2008 | Frigidaire FMV157GM Microwave Oven
When you hit Start to cook, do the inside light and turntable come on? Yes
Any unusual noises? No
Is it louder or quieter than usual? No change
Sep 14, 2008 | Microwave Ovens
Emerson MW8106W Microwave Oven Logo
306 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
