Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Where to add automatic transmission fluid for 1997 Chevrolet 1500
Where do i add transmission fluid
  • 67 Answers
Get a funnel and add it through the dip stick tube! yes that easy! hope this is helpful to you !
Posted on May 30, 2009
How do i (a girl) add transmission repair fluid to '97 Automatic Ford Escort?
Open the hood and look for either a red handle for a dipstick or one marked trans. Remove the dipstick and ,with a funnel, pour the fluid into the tube the dipstick came out of.
Mar 31, 2012 | 1997 Ford Escort
Were do I add transmission fluid on 97 nissan truck xe with 2.4 L engine. Automatic transmission...
Through the dipstick tube that you check the fluid level at. Use a fine tube funnel to add transmission fluid.
Jan 26, 2011 | 1997 Nissan Pickup
I changed the fluid and filter on my 1997 dodge 1500 and the same day the transmission stopped shifting gears....what could be the problem?
it is possible you either did not add enough fluid, added too much fluid, or the fluid you replaced the old with was the wrong type for the trans. was there a problem with the trans before you replaced the trans fluid? make sure that when you change the trans fluid you are working on a flat surface. if you pull/check the dipstick while the truck is on jack stands, or otherwise elevated, you reading will be off. and you may find that after pouring in the new fluid and setting the truck down to test drive and circulate the new fluid that you have put too much fluid in the pan. this will show up as bubbles on the dipstick, or fluid coming out of the fill tube. also make sure the fluid you use is the right type. chrysler transmissions require different fluid than ford, or chevy. though you did not specify if your trans is manual, or automatic.
Dec 24, 2010 | 1997 Dodge Ram 1500 Club Cab
Where do i add transmission fluid on a 1997 breeze
If your automatic transmission in the dip stick tube located under the engine compartment.If you have manual transmission you might have to hoist the car up to service the transmission with fluid.John
Dec 23, 2010 | 1997 Plymouth Breeze
How do add fluid to a 1997 Dodge Ram 1500 standard
if you go under the truck you will find a 3/4" pipe plug on the side of the trans case, revoce it, fill the trans to just below the threads of that plug, use your pinky to check the level..
Sep 29, 2009 | 2001 Dodge Ram 1500 Truck 2WD
Where is the transmission dipstick for a 1997
its a 5 speed, there is not dipstick. there is a fill plug on the side of the tranny you remove to check fluid level, level should be just below the opening.
Sep 23, 2009 | 1995-1997 Chevy 1500 Truck Ignition...
I have a leak in my 97 automatic subaru legacy and need to add some fluid to my transmission just to get it to a shop. It doesn't say in the manual or on any site I've been to where to add it or what kind...
The type best used is "Genuine Subaru Automatic Transmission Fluid Type-HP or IDEMITSU ATF HP. you add it through the dip stick hole. You may also wish to add a transmission leak oil to swell the gaskets and stop the leak add it the same way if you choose to use it. both of these should be available at your local auto parts store like NAPA. Raz,...
Aug 21, 2009 | 1997 Subaru Legacy
1997 Chevrolet 1500 transmission
It varies a bit depending on the tranny, safest way is to buy a couple 1-gallon jugs to be sure you have enough. (Be sure to catch all the fluid that comes out) After putting in the first gallon to replace it, fill the empty jug, then fill it again and put that much of the 2nd jug in. (This is for doing the pan drop, filter change, refill, likely to be more if you do a complete system drain).
Oct 23, 2008 | 1997 Chevrolet K1500
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
570 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
