Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Ryobi RLT 30 CES Strimmer - Won't run properl7
I have just bought a Ryobi RLT30CES 2 stroke strimmer on ebay. It was advertised as a factory returned item that had obviously be sent back under warranty. It was described as in fully working order. It is, but it also plays up. It appears to have little use judging by the overall condition.
The machine fired up easily and ran well until it reached temperature after a few minutes use. Then it started to run roughly at revs until it just died. I re-started it and it did this a couple of times. I left it to cool down and it started again and did exactly the same thing. From cold it's fine, when it gets hot it plays up.
Carburettor adjustment has been recommended by the guy I bought it from but I am not exactly sure how to do that as I don't want to mess with it and make it worse.
My local mower repair place said they will not touch Ryobi propducts as they cannot easily get the spares.
Any ideas on what the problem could be, or if my hunch is correct, how to adjust it correctly would be gratefully received. It came without a manual etc.
Thanks.
Http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
Posted on Jun 20, 2009
  • joe_florek Jun 20, 2009
    sorry, that's the solution to the wrong problem
  • 1,041 Answers
I'm not sure about the carb. adjustment being removed. The newer carbs. only have one dial for adjustment, not the two screws like the "old school kind".It probably needs the carb. cleaned. Disassemble the carb. and clean with carb. cleaner. Use a Den Tek Brush, (used for cleaning teeth), to clean the small portals. Make sure the small screen in carb. is free of debis. The smallest of particals can cause your problem. Reassemble and try starting. If it still acts up, buy a carb. kit for trimmer and replace the needle valve, appropriate gaskets, diaphragm, and small screen. This should solve the problem.
Jim
Posted on May 30, 2009
  • Jim Parker
    Jim Parker Jun 04, 2009
    Did my suggestion solve the problem?
    Jim
Ryobi rlt 30 cesa petrol strimmer will not start
Keith you have got to make sure the gap is right between the coil and the magnetic flywheel. Use a buisness card to set the gap and make sure the coil is on the right way.
May 14, 2014 | Garden
I inherited this trimmer and do not know how to add new string. There isn't any kind of a manual that we can find. The trimmer is a RYOBI 137R. Thank you.
hi i have a ryobi rlt 30cd strimmer and when i was useing it it just stopped it as fuel in it but ive cleaned the carb but i still cant get it to run as any one got any ideas thanks
Jul 15, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
I have the ryobi rlt30ces strimmer and cant find a piston ring anywhere any help???????????????????????
Here is a 30CC Ryobi 2-stroke trimmer. Your ring is item number B-53 in the diagram. The part number is 03179. They have these in stock also. Hope this helps you!
http://www.ereplacementparts.com/ryobi-ss30-ry30002a-string-trimmer-parts-c-7931_15633_15652.html
Jul 14, 2011 | Ryobi 15" Electric Factory Reconditioned...
What is the 2 stroke petrol mix for a garden strimmer, Ryobi 25cc PLT 2543 please?
hi there keithprobert
the ratio to use if using top quality 2 stroke oil is 50:1 that is 20 mills of 2 stroke oil per 1.0 litre of petrol that you mix.
but if not using top quality 2 stroke oil use ratio 25:1 that is 40 mills of 2stroke oil per 1.0 litre of petrol that you mix.
cheers pauly46
dont forget the thumbs rating
Jun 02, 2011 | Garden
Ryobi RLT30CET difficulty starting and when running doesn't power up sufficiently to do job. Has 50:1 unleaded fuel The machine was bought 18 July 2009
Hi...Ryobi RLT-30CET...I have a newish strimmer which I dropped 2 ft. Changed the spark plug...as it seemed to have no spark. Now I think its flooded. How do I sort the flooding problem. and are there delicate parts that could break? many thanks...Phil
May 15, 2010 | Ryobi Garden
Starting problem with a Ryobi rlt30ces petrol strimmer
Hi
I have had the similar problem & spent a day stripping the unit down
(dismantled & re-assembled the carb, seemed OK fuel reaching & flooding the plug) I unscrewed the spark plug from the body, but left it connected to the lead and found that there was intermittent spark when pulling the cord. and tested it with a continuity meter - no signal/measurement. bought a new spark plug, meter reading showed signal/measurement, now starts every time. It may be that Ryobi has been installing rather cheap nasty plugs. So test the plug first by watching the spark when pulling cord, test with a meter, if no continuity, buy new plug....
Check also that little gauze air filter behind the roto choke is not blocked.
this solved it for me.
Please remember to give me a rating ...ta
Jan 25, 2009 | Ryobi 15" Electric Factory Reconditioned...
Ryobi RLT30CES
I also tried this.
  1. Clean the carb wire gauze air filter behind the roto-choke knob. (undo the nut/washers & long bolt)
  2. Deteremine if fuel is being fed to cylinder - Fully depress & prime the bulb about 7 times, turn to full choke. Pull start cord about 7 times. Remove spark plug see/smell fuel fumes/vapour present in cylinder
  3. Determine if compression is weak - remove plug, put finger over plug port, pull start cord. Should be evident of resistance/pressure build up when cord is pulled.
  4. Of course brand new plug!!! as above (I would try this first)
Hope this helps
please rate my comments - Thanks
Aky1967
Jun 24, 2008 | Ryobi 15" Electric Factory Reconditioned...
"warm" starting
Hi
You may have tried this already, Apologies if you have.
I have had the same problem & spent a day stripping the unit down
(dismantled & re-assembled the carb, seemed OK fuel reaching & flooding the plug) I unscrewed the spark plug from the body, but left it connected to the lead and found that there was intermittent spark when pulling the cord. and tested it with a continuity meter - no signal/measurement. bought a new spark plug, meter reading showed signal/measurement, now starts every time. It may be that Ryobi has been installing rather cheap nasty plugs. So test the plug first by watching the spark when pulling cord, test with a meter, if no continuity, buy new plug....this solved it for me
Jun 15, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi RLT30CES
I have one of these and I have to admit they are a bit of a bug*er to start. Following the instructions though on the sheet for trying to start it eventually should kick it off and then you should be away. I start mine by alternating between no choke and the half choke with about half a dozen pulls each. generally pull with the throttle held but try a few with it off every now and again. If you get to 10 mins without success, put it down, have a drink and a rest and go back in 30 mins and try again.
I wouldnt have thought a straight petrol mix would do it any harm though, if you had over mixed with oil then that could have been a differnt story.
May 25, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
1,309 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
