Was using camera about a week ago at Chelsea Flower Show, took 4 shots and went to turn on again for another shot and absolutely no power. Changed batteries and still no power. Got home from holiday, plugged in mains adaptor and still no power.
Screen totally blank and no beep to say any power getting through.
I suspect totally dead camera ready for the bin!!!
Camera is about 18 months old and not been used much at all.
Any advice
C
Remove your memory card from camera then check .
May be there issue with memory card.
pull memory card and start camera without memory card.
The Finepix S5600 consumes battery power like crazy... I made this experience as well. I guess your batteries will be dead and you just need to replace them to run the camera again. Power is supplied to the camera by four AA batteries. Running throughfour AA batteries at a time can soon add to the running costs. To keepthe costs down it is worth using rechargeable batteries with thecamera. Fuji estimates you should be able to take around 250 photosbefore needing to replace a set of standard alkaline batteries. I recommend you to use the new Sanyo Eneloop batteries, they are technology leader in the rechargeable battery market (http://www.eneloop.info/) You can get them here or at ebay (maybe best place)
First reply did not answer the question as to why camera did not work ( no power ) even with the mains adaptor plugged in.
Also I did put new batteries in the camera the day the fault started and this did not solve the problem.
