Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
Wurlitzer 3600 series wont select a record ?
Hi My wurlitzer 3600 superstar lights up and carousel and turntable rotate in the scan position but cannot select a record? grpper arm etc all remain in the 'home ' position over the carousel.??
    Champion:
  • Wurlitzer Expert
  • 211 Answers
If the buttons don't latch in, the machine is not in credit. Put on free play or put some money in.
Dave F.
Posted on Jun 25, 2009
45 (record) Jukebox. While playing the jukebox was changing records, the arm lifted the record slightly off the turntable. the credits and song selection would not clear off the readout, even after...
Have you checked all the fuses or circuit breakers on the jukebox?
Are all the power supply led's lit?
Make sure that all the connection plugs into the boards are fully seated and making good connections.
After checking the above if the fault remains you will need to contact a Wurlitzer service engineer.
Regards
Alan Hood
ami-man
UK
May 23, 2011 | Wurlitzer Jukebox 1015 One More Time...
Hi' I have just got a rowe ami r-83 disco jukebox. All is ffine apart from when you select say 120, it picks up and plays 168. Any ideas. Regards Chris
you need to check the Home signal to make sure the opto is activated at position 99. When the unit powers up the mechanism scans one complete cycle so it re-indexes the computer and starts scanning from position 00. If you want a quick test, turn the power off and scan the carousel to position 99 by releasing the latch on the left side of the mech just under and behind the mechanism motor. then power up the unit and it should pick the right selection. You can also observe the optic indicators on the mechanism control board under the turntable. The Home signal only operates at 99, the Index pulses between each record as it scans. Good Luck
Nov 29, 2010 | Wurlitzer Jukebox 1015 One More Time...
My wurlitzer 1015 cd jukebok carosel continually
There's a little light like a torch bulb light called the "light gate lamp" which you should be able to see shining at 6 oclock on the edge of the record carousel. It is on the lip where the serated toothed edge of the carousel passes through a small upright bracket. If you can't see it shining then that's your problem. Have a look in the original documentation and it shows a diagram how to change it.
Dave.
May 22, 2010 | Wurlitzer Jukebox 1015 One More Time...
This is a problem is with the Wurlitzer 1015 One
Make sure the Service switch on the jukebox Credit Unit (computer) is in the off position.
It actually sounds like a Selection and Credit computer fault.
Apr 24, 2010 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 3600 Jukebox turntable problem
The 3600 has a hub that is supposed to play dinked and undinked records. They had 33rpm and 45 rpm records back then, so to change the record speed the undinked (small hole ) records pushed down the hub flat when it landed on it, which changed the gearing. When a dinked (big hole) record lands on it falls onto the larger part of the hub. So if the hub is down and stuck there that's your problem. After the hub has been pushed flat (because of a small hole record) it is supposed to rise up again when the record is returned to the carousel. Have a look under the turn table and push up the centre rod.
Dec 20, 2009 | Wurlitzer Jukebox 1015 One More Time...
Hi, I have a Wurlitzer 3600 Superstar that I am working on. I am having trouble figuring out why the carousel won't stop spinning. It is looking for it's "Home" position, but won't stop. If I select a...
Look at the switch and solenoid assembly at 1 oclock on the carousel. That is what activates to set it going and it then clocks off a ratchet wheel to do two full cycles looking for a selection then stops. If it gets stuck the carousel wont stop.
Oct 07, 2009 | Wurlitzer Jukebox 1015 One More Time...
My jukebox doesn't play
The machine knows where the Cds are on the carousel by counting as it turns. The sensor that does this is a light gate situated at about 6 oclock on the edge of the carousel. There is a little light in there like a torch bulb. If you cant see a little light in there then thats yiour problem. The machine rotates continuously because it is trying to find position zero and can't.
Jun 09, 2008 | Wurlitzer Audio Players & Recorders
The microswitch at the base of the gripper arm is what enables the scan motor when the gripper is over the carousel. You will probably find that the small lever on the base of the tone arm is not clicking the microswitch properly.
Dave .
May 20, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 3600
email me at philhemmings@hotmail.com so i can send you an attachment for the jukebox that may help you
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
520 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
John Robertson
John Robertson
Level 1 Expert
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
