Question about Fisher Paykel EcoSmart GWL15
Maytag washing machine
I put water running and clothes in washer, the water level is right, but the washing machine does nothing on any cycle, like there would be no power.  It is a top load washing machine.  It is now filled with water and won't drain or spin, or anything for that matter.
  • Anonymous Mar 29, 2014
    machine will wash, spin, and recycle water, but will not put out to waste
  • Anonymous Mar 30, 2014
    It stops and still has water in it. I have to rinse and spin several times.
  • 100 Answers
The lid switch is bad on your washer. Either replace it or bypass it.
Posted on Oct 30, 2007
SOURCE:
I bought a new Maytag washer and I can't figure out what cycle to use for blue jeans. When I put it on normal and had a full load it. The water didn't even cover the blue jeans. What am I doing wrong.
read your operators manual
the machine is not designed to put all of your clothes in at once to start with and second the water level for a full load is high not normal
the normal refers to a normal mix of clothes and not water level
special wash is for delicates ( undies , silk etc ) or heavy wash is for heavy soiled clothes --coveralls , jeans , heavy jackets
Sep 22, 2018 | Maytag Washing Machines
I have a Maytag Performance series washer. Model MTW5740TQ0. It agitates during Wash cycle, but will not spin during after the Rinse cycle. It does this more times (95%) than not, but not everytime.
It may be falsely sensing water in the tub. Do you hear the pump running after the rinse (trying to pump out water that isn't there)? This would indicate a fault in the water level sensor. Does it seem to sense the water level correctly after the wash cycle? It could also be a timer problem.
Feb 01, 2017 | Maytag Washing Machines
Maytag bravos mvwx600xw0
It is possible that poor water flow may be the culprit. Most washers operate on a water level system. The water levels have to be reached before the next cycle begins . If the water flow is slow this can extend the run time. To remedy this shut water off to unit disconnect hoses at unit. There usually are screens inside each hose connection on washer gently remove these and clean them.reinstall in washer. Before reattaching hoses put the unattached ends in a pail and turn the water on to flush out the hoses. Then reattach them and see if this solves the problem. Hope this helps.
Dec 31, 2013 | Washing Machines
OL error code
Hi jbrundage1. I believe you have a UL error code on the washer. It means that the sensors in the washer are sensing the unit is unbalanced. When the washer is empty, set it to a spin or rinse and spin setting. Run the washer through the cycle empty, as it will help to remove any excess water in the tub. Also, make sure the washer is level, as it is balanced on springs, and that could be throwing the sensors off. I hope these suggestions prove helpful. Sincerely, Melanie, Maytag Social Media Representative.
Jun 03, 2012 | Maytag Bravos MTW6600T Top Load Washer
Washer immediately goes into wash cycle when filling with water on initial start.At the end of the spin cycle ,washer dumps water back in to drum.Also,it's not getting the detergent out of clothes. Maytag...
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 26, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
My maytag topload washer overfilled,
It isn't a sensor problem, it sounds more like your water level tube has pulled loose. This is attached to the outer drum itself. You can see it when you remove your front cover to the right of the outer tub. This tube uses the pressure generated from your tub water level to push air up to your water level selector, which has a rubber membrane that flexes and closes 2 contacts as the water level makes the rubber expand. If that tube is off, the water will just keep running.
Mar 18, 2010 | Maytag MAV3905EWW 13 Cycle Washer
Can''t get my clothes out... water still inside
does it have a dial that you can manually turn to start the next cycle? You can usually drain the water by pulling the drain hose out from the wall drain behind hte washer....( usually just shoved in the drain not attached) but be aware that when you hold the hose below the water level in your washer it will start to drain. Then perhaps the door will unlatch.
Sep 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water fills the tub then nothing happens.
it does not aggitate? Thats the cycle that allows the water to wash the clothes. It may be broken, I have had that happen a couple times. I would take the aggitator off and see if the teeth in the groves are worn out, It happen's when used alot. Commen problem and easy to replace.
Apr 05, 2009 | Maytag Ensignia MAV2757AWW Top Load Washer
Maytag neptune front load odor
its better do a maintenance, or put it to wash without cloths, only water and clorox, and varsol with the max level (water)
Nov 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer water level low, clothes come out dry !!
This is the water saver feature and the only solution may be to put it on the maximum wash cycle to get clothes really clean.
These washers normally get the clothes almost dry.
Mar 04, 2008 | Frigidaire GLTF1670A Front Load Washer
Fisher Paykel EcoSmart GWL15 Logo
101 people viewed this question
Top Fisher Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
