Question about GE Cooktops
Ignitors are igniting on their own
I have a GE Profile gas cooktop. The gas ignitors are constantly igniting on their own.
  • Anonymous Mar 17, 2014
    Profile JGP962 Gas Cooktop ignitor problem. Ignitors constantly fire when ALL KNOBS ARE OFF. Started when water splashed onto control knob. Can't stop ignitors w/o sitting off electrical breaker
  • 530 Answers
They are not lighting they are sparking on there own right? No actual flame? if they are sparking on there own you need a new spark module.
Posted on Jun 02, 2009
Two of my burners are clicking even when the stove is off. what should I do?
There is a switch that slides onto the shaft for each burner. When you turn the knob to a certain area it completes the circuit to the ignitor module. It sounds like you have a shorted switch. Unfortunately with most 'cooktops', these are not easy to get to.
It's also strange that only 2 are igniting, usually one module runs all the ignitors. When you turn one of the non-problem burners on, does it click when it supposed to and stop when it's supposed to?
The ignitors running constantly is annoying and may damage the module, but should not be dangerous unless you have other issues, ie., fuel leaks.
If you have access to basic hand tools and a multimeter I can walk you through the diagnosis.
Sep 15, 2011 | GE Profile JGP636 Gas Cooktop
My GE Profile propane gas cook top was just installed yesterday. When I go to turn on one of the burners, all of the ignitors click. This can't possibly be normal. Anyone else have this issue?
Yes, thats okay when you turn the knob voltage gets sent to the spark module, Then the module sparks all the burner igniter. And frame ignition only happens on the single burner of the knob you turned that sends gas to the burner associated with that knob.
Please rate me a "4" if this information was useful.
Dec 14, 2010 | GE Profile JGP636 Gas Cooktop
My GE Profile JPG636 cooktop has an ignitor problem. It clicks constantly, and all the ignitors on all 5 burners are 'going off'. It happens every 8 or 10 seconds whether we're cooking or not. If anyone...
The most common cause for this issue is from liquid getting into the ignition system for the range. If someone has spilled water or other liquids into the burner knobs or the ignition system it will cause an electrical short in the system causing the igniters to come on constantly when the knobs are off. The fix to this is to unplug the range and wait 24 hours for the liquids to dry up. You can speed up this process with a hair dryer pointed at the burner stems(knobs removed). Once the liquids have dried up the problem should stop. I would not leave it plugged in until then because the ignition system could be damaged from the constant sparking.
Feb 23, 2010 | GE Profile JGP636 Gas Cooktop
Spark ignitors on ge jgp636 either don't work or lght wrong burnr
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Dec 19, 2009 | GE Profile JGP636 Gas Cooktop
Ge jgp337 ignitors continue to click after gas ignites
You have a bad ignitor which will have to be replaced. Unplug one ignitor at a time until you find the faulty one.
Jul 24, 2009 | GE 30 in. JGP337 Gas Cooktop
Ignitors keep making ticking sound, all burners turned off, won't go in lock position, and one burner will not ignite gas despite constant ticking
Probably a spillage or boil over has clogged the burner and some of the liquid has dampened the shank switch mounted on the burner post. Get a shop vac and clean the burner. Wait a day or 2 and see if the switch stops. OR disable the ticky ticky by removing the bottom drawer and looking for the spark module. Remove one of the hot wires and tape it up. Light the burners like granny does with a match. LOL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 17, 2009 | GE 30 in.Profile JGP945 Gas Cooktop
G.E Profile gas cook top #JGP640 ignitor.
It is sparking because the module does not sense the heat which would normally cause the sparking to stop.
It can be caused by a poor ground, make sure the ignitor at that burner is clean and free from any obstructions. If it is then it could either be a defective ignitor or spark module.
Mar 12, 2009 | GE Cooktops
GE ZGU650 EM1BG Gas Cooktop
On any range I've seen with electronic ignitors, the valves have a position that closes a contact to turn on the ignitor and manually moving the dial to the 'Hi' setting opens the contact again and the ignitor ceases to spark.
You don't mean the ignitors run even when the burners are off, do you?
I'm surprised to read that this has been happening for 'years,' the transformer for the ignitors must be really tough to withstand that and it doesn't sound like an electrode or transformer problem but rather a contact not opening as it should or you not advancing the control past the ignite point.
Oct 18, 2008 | GE 30 in. JGP336 Gas Cooktop
One of four dials doesn't spark ignitors...
its a spark switch gone bad, 1 switch will turn on all four burner electrodes(its just easier 1 module)sometimes model dependant you can eplace justone switch, sometimes they come as a complete set
Feb 24, 2008 | GE 30 in.Profile JGP945 Gas Cooktop
Cooktops Logo
224 people viewed this question
Top GE Cooktops Experts
Dave Harrison
80stech
Are you a GE Cooktop Expert? Answer questions, earn points and help others
