Question about Dryers
Dryer not blowing heat
Not blowing heat
  • reons2002 May 30, 2009
    model # is 76712691 76712
    i'am not sure if you got the make it's a kenmore 70 series
    President:
  • 1,136 Answers
Hi, Could you get em a mosel # so I can see exactly what dryer yuo have so I can assist you further?
Vic
Posted on May 30, 2009
  • Victor
    Victor May 30, 2009
    Ok Thanks
    If this model starts with 110. here is what to look for. Remove the little cap on the lower left front panel. start the dryer in heat cycle and look inside the hole you just uncovered and see if the ignitor is golwing. If it glows and then shuts off before you see a flame, you will need to follow these instructions:
    UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post thecoils slides onto.
    If you do not see the ignitor glow, you will need to follow these instrutions:
    UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it.
    Please let me know if this help or if I can assist you further.
    Thanks
    Vic
Maytag Bravos XL Dryer not heating- blowing thermal fuse
The thermostat is controlling the temperature, however the Heating Coil may be defective. Check the COIL.
Feb 27, 2014 | Maytag MEDB950YW Electric Dryers
Dryer heats in a 'no heat' selection
it sounds like you have a grounded heat element and the heat will stay on all the time,very easy to check,unplug the dryer,pull the two wires off of the heat element,with a meter touch one lead to the outside metal cover of the heater and the other lead to one of the element,then check the other side of the element the same way,if it shows continuity on one end of the element it's grounded and needs to be replaced with a new heating element.and every year or 18 months you have to clean out the dryer,i use a shop vac and a leaf blower,unplug the dryer,remove the bottom panel,remove the lint filter and the metal duct that the filter slides into,vac up all the lint you can see,brush out the hole where the filter goes and with a long thin screw driver dig out the lint that's in the right and left sides of the plastic slots where the filter slides in,now with the shop vac set it to blow and blow all the lint from the back forwards and blow the motor off and vac up the lint,after you clean out the cabinet go to the back and remove the vent line from the dryer,stick the leaf blower into the vent line and blow it out to the outside,if you do this every year you'll have less problems with the dryer,your clothes will dry on time and you don't have to worry about a dryer fire.
Feb 01, 2014 | Kenmore Elite HE4 Electric Dryer
Dryer has no heat
If it is blowing but no heat at all check the thermal fuse, cutout fuse, all thermostat's & centrifugal switch on the motor. Check the heating element also check if the heating element is grounded to the heater box. First clean the vents inside the dryer and all the way to the outside completly. Hope this does the job
Dec 18, 2013 | Whirlpool Dryers
Mt Moffat clothes dryer keeps blowing thier own fusses
You have heat sensors on the Heating Element. If one allows the heat to get to high it can trip the Breaker. It more than likely is a bad Circuit Breaker in the Breaker Box. These can go bad. It is a Double switch, one is for the heat, one is for the Motor.
Jan 18, 2013 | Dryers
The dryer doesn't blow any heat 11074972300
Check heating element with Ohm meter should read something.
Infinite reading means the coil has burnt out. replace.
Nov 04, 2012 | Kenmore 95087 Gas Dryer
My Whirlpool Super Duty Imperial drier won't produce heat. I made sure the outside vent was unclogged; it is blowing cold air.
When a dryer doesn't heat, either the heating element is bad, or the flap inside the venting of the dryer is opened allowing air to bypass the dryer instead of blowing the air into the dryer.
Jun 24, 2010 | Dryers
Dryer isn't heating. It turns and blows air but
make sure lint screen and vents are clean. next shut off electric and check heat element for broken element. then get model # and serial # order and change thermocutoffs located on heater box and fanhousing ck these steps one by one
Dec 09, 2009 | Kenmore 75962 Gas Dryer
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
Kenmore Dryer
I am sorry to hear this, my name is Marc White, i am self employed and it seems as though you have a bad timer, bad timer will cause the timer not to go to the off position and blow your fuse......change your timer..
thanks
Apr 03, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
177 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
